2017 E-Locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by traumahawk, Jan 4, 2019.
  1. Nov 12, 2023 at 12:27 PM
    #101
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Manual 3rd Gen Tacoma's all have the 8.75 inch differential. Regardless of TRD Pro, TRD Sport or TRD Off-Road all manuals have the bigger differential. Because of this, there is only one Air locker, 3 E-Lockers and an Open differential available for them. There is currently no limited slip or mechanical locker available yet.
    So your choices are
    Factory Open
    Factory E-locker
    Eaton E-locker
    Harrop E-locker. ( I believe this is an Eaton, not completely sure )
    ARB Air locker
    BLtheP likes this.
  2. Nov 12, 2023 at 8:23 PM
    #102
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I didn’t know this - thanks for the correction!
    I deleted the original post.
    Speedfreak[QUOTED] likes this.
  3. Feb 9, 2025 at 10:15 AM
    #103
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Be aware running a Truetrac takes some serious getting used to. If the road is wet, you can't take off from a stop very fast. If the road is wet and you are trying to take a turn out of a parking lot or a stop light, it will lock up on you and fishtail. I ended up installing a throttle commander in my other truck so when it was wet I could turn the throttle response down. Truetrac's are AWSOME offroad, with any wheel spin it locks up like a spool, you feel a split second of wheel spin then 100% traction and off you go. The only drawback is if you have one wheel off the ground it won't lock, e-brake usually will be good enough to get you rolling again. For a DD I highly advise not going with a Truetrac.
    hemlockz likes this.
  4. Feb 10, 2025 at 10:13 AM
    #104
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    That sounds somewhat unlike a truetrac/torsen diff. They are typically the best lsd option for on-road applications with very mild street manners compared to other locking and limited slip diffs.
    gudujarlson and jmneill like this.
  5. Feb 11, 2025 at 7:43 AM
    #105
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    probably the best option, but people need to know before installing one into your DD, you will have to change your driving habbits. If you have a heavy foot, you don't want any of the gear driven LSD's in the rear.
    the mechanical clutch driven LSD that was available on the TRD Sport Package #2 for years 2005-2008 was actually pretty good! I put a few through the ringer and never wore out.
