2017 Headlight Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MetrickMetal, Jun 19, 2017.
  1. Jun 19, 2017 at 10:00 AM
    MetrickMetal
    MetrickMetal [OP] Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    I need to adjust the headlights lower on my 2017, but after doing searches here and on the internet, the only thing that I found on the back of the headlight housing that looks like an adjuster is the round silver object in the picture with the notches on it.
    There's one on each headlight housing and it has an 8mm hex on it, and it does turn. So is this the vertical headlight adjustment screw, and if so where is the side to side adjustment screws located.
  2. Jun 19, 2017 at 10:20 AM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    There is only the option to adjust vertically. You may be able to do something if you open up the headlight but it would be permanent. IMO this is an odd thing to adjust, but I understand every individual has their own needs. Could you provide more info on what you're exactly looking to accomplish? There may be an easier solution to get the results you want.
  3. Jun 19, 2017 at 10:32 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I just need to lower the headlights as I raised the front 1". So is the silver notched wheel the up/down headlight adjusters, and if so is it turned c or cc to lower the headlghts
  4. Jun 19, 2017 at 10:40 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There is no physical horizontal adjustment mechanism. Any adjustment found would be for vertical aiming. You need to do this at night with the lights aimed against the wall.
  5. Jun 19, 2017 at 4:57 PM
    Ravnikar610
    Minnesota
    2016 OR DCSB
    Okay, so you're going to want to turn that silver screw counter clockwise. Like hiPSI mentioned, do it at night against a wall. After lowering the beam drive around a bit and make sure they are where you want them. The screw is pretty sensitive so do a 1/4 turn or 1/2 turn at a time. If you only raised the vehicle 1" it shouldn't take much to get it at a proper level. Hope that helps!
  6. Jun 20, 2017 at 9:26 PM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I marked a line on face of the adjusters with a felt pen and I initially went 1 1/2 turns after looking at the lights on the garage door, and I just drove it down the street to check it out and it looks pretty much like it did before I did the lift. :thumbsup:
