2017 Taco Rattling noise when driving over bumps.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lucky Taco 187, Feb 19, 2017.
  1. Feb 19, 2017 at 5:40 PM
    Lucky Taco 187
    Lucky Taco 187 [OP] Member
    2017 DCLB TRD OFF ROAD 4WD
    Just wanted to know if Im the only one having this issue. Truck only has 1600 miles and has never had a fender bender. Somwhere underneath the front, whenever I hit a moderately sized bump it sounds like something plastic is loose. By loose i mean only light loose, but enough to make a irritating rattle. I think it might be the front bumper.
  2. Feb 19, 2017 at 7:44 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Sure its not in the dash on the passenger side... that's THE common rattle... and its super annoying and only does it when its cold out..
  3. Feb 19, 2017 at 7:57 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Check the Cab Mounts, the Passenger side front one seems to fail a lot on these trucks.
  4. Feb 19, 2017 at 8:02 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Oh yeah there's that rattle too!
  5. Feb 19, 2017 at 8:03 PM
    shakerhood
    Southern Ohio
    There are a couple Threads on here somewhere, that passenger side front one is always tore up.
  6. Feb 19, 2017 at 8:05 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Yup the dealer replaces with same part! o_O
    shakerhood likes this.
  7. Feb 22, 2017 at 12:28 AM
    Lucky Taco 187
    Thanks for the info guys, unfortunately here in Oahu you have to wait about 30 to 40 days to get your Toyota into the Service Department. So.... I have tried to find the rattle, but no luck. Over less moderate bumps or just highway driving I hear nothing. Usually takes a pot hole like a 3 inchs deep so it maybe just the way it is.
    By the way, it is definitely not the dash, its outside in the lower front part near the front suspension. And it doesnt get under 65 here even in the winter nights with the coldest wind chill.
  8. Feb 22, 2017 at 2:12 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    could be the crappy cheap plastic inner fender hitting also,,
    over60 likes this.
  9. Feb 22, 2017 at 2:20 AM
    Lucky Taco 187
    Do you hear anything in the front when driving over pot holes? My rear suspension is super quiet, nothing rattles or squeaks back there. Thanks for the reply.
  10. Feb 22, 2017 at 2:36 AM
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Op is your truck a standard transmission?
    Nevermind just saw your a LB
  11. Feb 22, 2017 at 2:39 AM
    Lucky Taco 187
    Automatic Trans
  12. Feb 22, 2017 at 7:01 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    quoted "Check the Cab Mounts, the Passenger side front one seems to fail a lot on these trucks."
  13. Feb 22, 2017 at 5:11 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    What he said..?? ^^^^^^^^
    Some cheap plastic pins on them. Mine will make noise if I reach in and hit them with my hand... Try that to see if it's the sound.
