2017 Tacoma brakes suck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by amosalan58, Jun 20, 2017.
  1. Jun 21, 2017 at 8:06 AM
    #41
    Wiggleattack
    Wiggleattack Well-Known Member
    Sean
    2017 Red Taco SR
    as in I could pick her out of a crowd, but yes. slack jawed, dead eyes, all of it.
    I wasn't doing anything wrong in that story apart from speeding a bit (speed limit is 75, no telling how accurate my speedo was but I doubt I was doing more than 80)
  2. Jun 21, 2017 at 8:12 AM
    #42
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    The brakes on my OR were great! They were very grabby and bit hard when applied. I had to get used to using little brake pressure to get a smooth stop. I liked how responsive they were, no problems getting stopped in a hurry!
    TheCookieMonster likes this.
  3. Jun 21, 2017 at 8:25 AM
    #43
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I have zero complaints about my Taco especially the brakes. Drive your truck for a couple thousand miles then see how you like it (and stop reading this forum!)
  4. Jun 21, 2017 at 8:49 AM
    #44
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Correct, my VSS light was on becasue of the lift and re-alignment. I didn't have Stability Control, Traction Control, and I found out I also didn't have ABS when I locked them up and almost rear ended the car in front of me.
  5. Jun 21, 2017 at 8:53 AM
    #45
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Adding some stainless lines, better pads, and slotted rotors you'll sort out the truck.
  6. Jun 21, 2017 at 9:29 AM
    #46
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Yes I do.
  7. Jun 21, 2017 at 9:42 AM
    #47
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Three points:
    1. The stock Taco brakes are powerful enough i.e. they are able to lock up the tires and trip ABS. So ultimate braking performance is limited by tire grip.
    2. Initial bite is more a function of pad compound. Toyota probably chose a compound that wears better and creates less dust than BMW. You can always change to a more aggressive pad from Hawk, EBC, etc.
    3. Pedal feel on the TRD Off Road is poor because of the electric pressure pump. Not a performance problem unless you need to modulate for track use.
    BAMA-256 and 9th like this.
  8. Jun 21, 2017 at 10:46 AM
    #48
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Bummer deal there, bad way to find out no ABS, when you're standing on the brakes.
    Diablo169[QUOTED] likes this.
  9. Jun 21, 2017 at 11:03 AM
    #49
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    First Manual trans to use less brakes, 2nd my wife would disagree with the brakes being shit, as I just tapped them the other day and lets just say she acted as I was doing a buck and slammed on them.
  10. Jun 21, 2017 at 11:18 AM
    #50
    amosalan58
    amosalan58 [OP] Active Member
    2017 DCSB OR 4x4 AT
    A very few of the commentators should really read and fully comprehend my original post before typing. Some are repeating what I have already stated in the original post. LOL. I thank the rest of you for your knowledgeable comments.
  11. Jun 21, 2017 at 11:23 AM
    #51
    Spare Parts
    Southern Maine
    Does anyone else think that it takes a long time to brake in their 3rd gen Tacoma? NO
    I'm also coming from a 3,000lb 2006 BMW 325i. Big difference.
    I understand I'm going from 4 disc to 2 disc/2 drum and added 1k lbs Thats important in this situation.
    but damn
    these brakes either suck I don't agree, they grab and hold.
    or
    Germans have their shit wired tight! I also don't agree, VWs where know at one time for shitty electronics and bad auto transmissions.
    I tried to show you that I read the whole post and attempted to show my reading comprehension, but that can sometimes be difficult for me at times.
    The hammer and TheCookieMonster like this.
  12. Jun 21, 2017 at 11:25 AM
    #52
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    My wife has had two Mini cooper S, which I drove all the time. The Tacoma brakes just fine. The negativity on this forum needs to end.
  13. Jun 21, 2017 at 11:27 AM
    #53
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    My 2017 OR has pretty decent brakes, in my vehicular experience. Can't compare with what others have felt on their trucks. I would like the brakes to be a bit better, sure, but they are more than acceptable as they are, to me.
    Compared to my previous vehicles:
    2014 VW Passat - about equal to my Taco
    2001 Dodge Ram 2500 - definitely not as good as my Taco
    1987 Ford F250 - definitely not as good as my Taco
    1980 Toyota Hilux - been so long, I can't say for certain, but pretty sure my 2017 Taco is a good bit better
    1976 Volvo 164e - been so long, I can't say for certain, but pretty sure my 2017 Taco is a good bit better
  14. Jun 21, 2017 at 11:42 AM
    #54
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    o_O
    The hammer likes this.
  15. Jun 21, 2017 at 11:46 AM
    #55
    amosalan58
    2017 DCSB OR 4x4 AT
    Last post and then I'm popping smoke.
    The bottom line is the brakes could be much better. Some would even argue that the rear drum brakes MIGHT of been a cost cutting move from Toyota and not a rear brake longevity issue. My 13 year old GMC Sierra 1500 SWB has 4 wheel disc brakes that are amazing.
    And if you don't understand the first line of this post...no worries.
  16. Jun 21, 2017 at 11:56 AM
    #56
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    :rofl:
    Oldman808 likes this.
  17. Jun 21, 2017 at 12:03 PM
    #57
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    That's a good thing in my opinion, ABS sucks. ABS has not made vehicles any safer according to insurance company statistics.
    I have no complaints about the braking power of my Tacoma other than the ABS in the snow. Using brakes too much wastes gas :).
    Gearheadesw[QUOTED] likes this.
  18. Jun 21, 2017 at 12:04 PM
    #58
    OkieYota
    OkieYota Unknown Member
    ‘18 TRD OR DCSB Cement
    None yet
    Yeah I just replaced my brakes on my tundra with green stuff pads , an improvement non the less , and even with 4 corner disc brakes my 3rd gen tacoma brakes way better. You gotta start slowing down from waaayyy back to get that full sized stopped. So I know what you mean by "cost of business " by owning a Toyota.
  19. Jun 21, 2017 at 12:08 PM
    #59
    VegasVic
    VegasVic Well-Known Member
    SinCity
    2017 Cement TRD Pro
    BAMF Recessed Grille 17" Ray10's 305/70/17 Nitto Ridge Grapplers Lots O' MESO
    ^This. I opened the thread thinking this was actually going to be the subject of conversation - that the brakes are so sensitive and grabby. Everyone I have let drive my truck has commented on how incredibly sensitive the brake pedal is (after almost sending us both through the windshield at the first stop we come to). I jump in my wife's Sienna once a month or so to run the kids somewhere and I have almost run into the back of people when coming to a stop because you have to push the brake pedal in SO much further before you begin to feel the vehicle slowing.
    Riding Dirty[QUOTED] likes this.
  20. Jun 21, 2017 at 12:12 PM
    #60
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    All these post on the Tacoma's brakes kill me. Was I bothered at first that a vehicle I paid over $35k for still had rear drums; yes I was, but that ended as soon as I had my first panic stop. They are good enough to lock the tires, so like what has already been said, it comes down to the tires being the limiting factor, not the brakes.
