2017 Tacoma Front Brakes... suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by danwilk, May 15, 2023.
  1. May 15, 2023 at 9:06 AM
    danwilk
    danwilk [OP] New Member
    Daniel
    2017 Tacoma SR5
    I'm about to do the front brakes on my 2017 Tacoma SR5 for the first time and I was wondering if you guys go with OEM products (pads and rotors) or is there some brands that are just as good that are used by you guys? My truck is used for daily driving and not much towing at all.
  2. May 15, 2023 at 9:12 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Welcome to TW! You may get a few replies here recommending this or that, but my unprofessional opinion is nothing beats stock. I intended to go the TRD performance pads with Stoptech cryo rotors, since its the tried and true recommendation around here, but the rotors have doubled in price and the pads are essentially discontinued, or out of stock everywhere. That would be my recommendation if the prices weren't through the roof, so stock is pretty much the best value for the money. Aftermarket drilled/slotted rotors and pads are pretty much a waste of time if you're after some kind of notable performance gains.
  3. May 15, 2023 at 9:13 AM
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    I heard good things with Akebono pads.
    kshoots, LeakyAC and Chew like this.
  4. May 15, 2023 at 9:24 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Swapping in some braided brake lines are known to help firm up the pedal feel too
    Speedbird and 02TRDXTRA like this.
  5. May 15, 2023 at 9:30 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Oem
    Speedbird and Chew like this.
  6. May 15, 2023 at 9:32 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    you didn't mention how many miles, but the old pads lasted 6 years,,,, I'd stick with what works.
    Some folks around here would modify their mammie's Walmart electric shopping buggy, if they were allowed to take it home.
    joeyv141 and danojeno like this.
  7. May 15, 2023 at 9:34 AM
    Tucker2020!
    Tucker2020! Well-Known Member
    I have HAWK HPS STREET BRAKE PADS and STOPTECH SPORT SLOTTED CRYO-TREATED ROTOR, so far so good because of parts availability.
  8. May 15, 2023 at 9:35 AM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    I'm up to 45k on my stock brakes all around and everything still looks and feels good. That's enough of a test for me to buy OEM again when I inevitably do replace them.
    I should add that I used OEM brakes on my Scion years back as well and they were pretty cheap. Things have changed since then, though.
  9. May 15, 2023 at 9:51 AM
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    I've never met OEM brakes that I liked. I'm partial to Power Stop on most vehicles I've owned when it came time to replace rotors and pads - readily available, low cost, good performance with less pedal effort, outlasts OEM. At 52k miles, I just did the Power Stop K137-36 kit on the front (drilled/slotted/carbon ceramic pads) and my stoppers are feeling great. For under $200 shipped (on Prime), hard to beat. It comes with quality hardware (springs/pins/clips). I didn't use the cotter pin style retainer clips for the pins - I cleaned and reused the OEM 1-piece spring clips, and I don't ever use supplied grease, because Permatex purple stuff is the truth.
    I don't tow, but I do lug around (and have to stop) big wheels/tires. I'm pretty religious about doing the "bedding" or "break in" procedure. I don't know if it's as critical as the supplied instructions make it out to be, but I've never had warping or any other common brake problems, so I'll keep doing it.
  10. May 15, 2023 at 9:58 AM
    twtaco$
    twtaco$ Well-Known Member
    Duralast gold is your best bet for a daily driver. $60 I use these always. Rotors also I always bed my pads also.
  11. May 15, 2023 at 11:01 AM
    eurowner
    eurowner Duke Sky
    Scoty
  12. May 15, 2023 at 5:45 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Curious if you have some data points or research on the issue?
  13. May 15, 2023 at 5:54 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I used to buy OEM Toyota and Honda pads, but switched to Raybestos Element3 a while back for the coated rotors. Price for the rotor/pad kits on Rockauto is cheap, and they stop and last just as well as stock. Coated rotors are definitely the way to go if you're near the rust belt.
  14. May 15, 2023 at 6:02 PM
    BillyE
    BillyE Well-Known Member
    What’s the story on Lexus pads? Heard it mentioned but no details.
  15. May 15, 2023 at 7:21 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Brake pads are brake pads right? All the same for the most part..
    I used non ceramic Wagner pads and rotors in my 2018 last year. OEM lasted 50k
    stops fine, no squeaking but the black brake dust build up on my front rims is driving me crazy! They never look clean anymore.
    OEM pads are ceramic and don’t cause that sort of brake dust, at least not that much. Last week I put OEM brake parts in my wife’s 4Runner and that’s what will go in the Tacoma next time around.
  16. May 15, 2023 at 7:27 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a vibration at 40K miles on OEM brakes so I when aftermarket. I am all pavement and little towing. Very happy with PowerStop.
    https://www.amazon.com/gp/product/B005FKS28C?ie=UTF8
    AustinNative likes this.
  17. May 15, 2023 at 7:30 PM
    02TRDXTRA
    02TRDXTRA Well-Known Member
    Long Island,NY
    '17 TRD OR
    Hawk LTS pads, Brembo blank rotors and braided stainless front brake hoses. You wont be disappointed...or go broke either
  18. May 15, 2023 at 7:34 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I just put duralast gold rotors and pads and man, they are so squeaky for some reason.
    Based off that, I would not recommend.
  19. May 15, 2023 at 8:42 PM
    twtaco$
    Wow I’ve never had that. Probably used on 10 +cars. Did you bed them?
  20. May 15, 2023 at 8:54 PM
    eurowner
    eurowner Duke Sky
    Scoty
    MadKatt[QUOTED] likes this.
