2017 Tacoma tech package Bluetooth problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bluelaguna, Jan 6, 2017.
  1. Feb 8, 2017 at 6:52 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Weird. Any friends or family you can take for a drive and see if their phones exhibit the same issue? Maybe other bluetooth music sources such as an ipod nano?
    Try to figure out if the problem is with your phone or with your headunit. The behavior isn't normal.
  2. Feb 8, 2017 at 11:58 AM
    pharah
    pharah Well-Known Member
    2017 4x4 ORSB
    TRD PRO GRILL
    This is my next step. After reading this thread though, it sounds like this is not an isolated incident. I was hoping someone here may have had their head unit replaced under warranty and had the problem solved. =\
  3. Feb 8, 2017 at 12:11 PM
    gpb
    Atlanta
    I remember reading of an instance or two like that. Doing some testing on your own will help make the case to the Service Adviser.
  4. Feb 8, 2017 at 3:28 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    tomwil likes this.
  5. Feb 8, 2017 at 4:02 PM
    gpb
    Atlanta
    Good video. He deletes the pairing on each end, talks about resetting the phone, shows how to reset the Entune headunit, then re-pairs them. Good detail on ensuring Show Notifications is turned on.
  6. Feb 8, 2017 at 4:25 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I suck at speaker installation however this looks pretty straight forward. Did you have to modify any wiring?
  7. Feb 8, 2017 at 6:20 PM
    Boosted_IX
    Boosted_IX New Member
    2017 Quicksand Tacoma TRD OFF-ROAD 4X4
    I had the same issue for awhile then I read somewhere that if you have two profiles on your Entune then this is a very common issue. Just deleted my wife's profile from it and now everything works like its supposed to.
  8. Feb 8, 2017 at 8:06 PM
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    Not bad, Metra brackets (fronts didn't fit without modification), wiring harnesses, new screws and hardware. Had to also modify the door panel.
    If you're not good at it... probably would pass on this one. This is the 5th car I have done so I didn't panic or get too nervous when I ran into some issues.
    LivinOnEdge[QUOTED] likes this.
  9. Feb 8, 2017 at 8:43 PM
    pharah
    2017 4x4 ORSB
    TRD PRO GRILL
    Awesome, thanks. Will try this tomorrow. Will report back if issue is resolved after deleting wife's profile.
  10. Feb 9, 2017 at 6:50 AM
    LivinOnEdge
    Land of The Lost
    Thanks for the honesty.
  11. Feb 11, 2017 at 1:48 PM
    pharah
    2017 4x4 ORSB
    TRD PRO GRILL
    Update for others who may stumble across this thread.
    I deleted my wife's phone which was paired to the stereo per a tacomworld users recommendation in this thread and the issue is now resolved.
    Big thanks to Boosted_IX for the suggestion.
    MasterTJ and gpb like this.
  12. Feb 11, 2017 at 9:03 PM
    MasterTJ
    MasterTJ Active Member
    2016 Tacoma TRD OR
    BAMF Grill
    Ah I thought it was my phone!! I have the same issue! It only started happening after a friend paired their device to my truck too. Well now I know the solution is to only have one device paired! But seriously, Toyota...how could you let entune screw the pooch on this? Did no one think to pair two devices???
  13. Feb 12, 2017 at 11:54 AM
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    I just deleted all other devices from my car, I will have to wait and see if that solves the problem, I will update when I know more. but like @MasterTJ said, How does Toyota miss this kind of stuff? Hope it gets fixed soon
    MasterTJ likes this.
  14. Feb 12, 2017 at 12:00 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Just tossing in my two cents
    I have had this issue a number of times. I find it most commonly happens when the phone is connected to my home wifi and i get in my truck and it connects to bluetooth.
    when it looses my home wifi it freaks out..... WITH THAT BEING SAID.
    There is a radio firmware/software update for our trucks that i got recently and it solved alot of issues in my system including that occasional reboot cycle it can do.
    Also, after you do an update on the iphone to the new OS i would recommend doing a disconnect of the iphone and re-adding it back into the truck as well.
  15. Feb 12, 2017 at 1:01 PM
    #35
    gpb
    Atlanta
    @Caboose117 could you post version numbers from the headunit?
  16. Feb 12, 2017 at 8:04 PM
    #36
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Yep I'll grab it in the AM
  17. Feb 12, 2017 at 8:08 PM
    #37
    gpb
    Atlanta
    No hurry, just curious. I'm due to go in for 5K svc in the next 3-4 weeks and want to ensure my to-do list is complete. :D
    Caboose117 likes this.
  18. Feb 12, 2017 at 8:20 PM
    #38
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Make sure the dealership does a cab mount chop while you have it in :p
  19. Feb 12, 2017 at 8:22 PM
    #39
    gpb
    Atlanta
  20. Feb 12, 2017 at 8:28 PM
    #40
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Lol a cab mount chop is a common Tacoma mod to fit bigger tires without rub
    It cuts the portion of your frame that houses the cab mounts
    Just pump it into YouTube and watch the one by total chaos
    gpb likes this.
