2017 Tacoma TRD Pro Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Low Range Off-Road, Feb 12, 2016.
  1. Oct 17, 2016 at 8:30 PM
    #61
    TejasTaco
    TejasTaco Grab a taco
    It's a shame it didn't come with those wheels. Looks great. Who's Dustin? What did you pay for the wheels, tires,etc.???
  2. Oct 17, 2016 at 8:40 PM
    #62
    TRDPugz
    TRDPugz Instagram @trdpro_pugz
    dimitri
    2017 White Tacoma TRD Pro
    I wish they came with the 4runner TRD pro wheels, though these are better. Dustin is the guy who runs Fn wheels, look up Fn wheels on the Tacoma forums, you will find a lot about them. Not sure what a set would run with shipping, i assume around 700-800$, I found out he was local and I picked them up from the store with no shipping cost. I got the tires for 208 a piece though they usually cost around 219.
    TejasTaco[QUOTED] likes this.
  3. Oct 18, 2016 at 8:03 PM
    #63
    2017TACOPRO
    2017TACOPRO Well-Known Member
    Billy
    Delaware
    White 2017 Tacoma TRD PRO TACO
    TRD exterior cab badges, 3D TACOMA tailgate emblems, Weather Tech trailer hitch step / bumper guard.
    TRDpugz,
    Amazing looking truck and congratulations.
    Update...I got mine on 11/02/2016 and love it! It's a great truck and I am so glad I didn't go the Tacoma TRD Sport and attempt to clone the Pro.
    I love the FN wheels and I plan to do the same upgrade. Why 265/70r17? Will 275/70 or 285/70 fit without rubbing? Did make any other modifications or does your current set run? I would like to get the biggest tire without having to modify or lift it. Yours look pretty flush with the fender and the white lettering is killer with that color combo.
    It sounds like anything over 265/70R17 "C" tire becomes an "E" rated tire and they have a harsher ride?
    drift2this likes this.
  4. Nov 9, 2016 at 10:49 PM
    #64
    TRDPugz
    dimitri
    Congrats man, i think a 275/17 should fit though I'm not certain and E rated will be a harsher ride than a C rated, heavier so i would assume it might effect mpg a bit.
  5. Nov 9, 2016 at 10:50 PM
    #65
    TRDPugz
    dimitri
  6. Nov 10, 2016 at 2:23 AM
    #66
    rcw65
    rcw65 Member
    Rick
    SC
    2017 Toyota Tacoma TRD PRO - Super White
    275 x 70 x 16 BFG KO2, removed charcoal filter, K&N filter, LED for; interior lights, bed, back-up and license plate. Pioneer 8200 NEX / car play / Idatalink, Raised Tacoma black letters ( tailgate) Red line Tuning hood quick lift Elite, Factory roof rack.
    1bad2k and Taco Fan like this.
  7. Nov 10, 2016 at 2:27 AM
    #67
    rcw65
    rcw65 Member
    Rick
    SC
  8. Nov 10, 2016 at 2:32 AM
    #68
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    what ply are the stock tires.?
  9. Nov 10, 2016 at 2:52 AM
    #69
    rcw65
    rcw65 Member
    Rick
    SC
    I'm not sure but they are rated as a passages car tire as apposed to the BFG KO2 has a LT rating.
    Taco Fan likes this.
  10. Nov 10, 2016 at 3:30 AM
    #70
    bludweiaer
    pa
    i thought so, they are rated as 112t, but ive seen some other 112t rated as 6 plys,,, im getting ready to buy new tires for my pro, i guess i will get another set of C-rated toyo's open country's,, they will be alittle heavier than the stock goodyears,,, toyota put 8 ply's on the 15 pro's which i traded for my 17 Pro,,, and 4 ply's on the 17 pro.. maybe they never heard of 6 ply's...
  11. Nov 10, 2016 at 5:53 AM
    #71
    motozachl
    motozachl Well-Known Member
    Jacksonville FL
    Wow those look great!
    Is there a difference between the stock toyota pro wheels and the fn fx?
  12. Nov 10, 2016 at 6:11 AM
    #72
    rcw65
    rcw65 Member
    Rick
    SC
    I think the stock tire weight is 33lbs and the KO2's are 50lbs. KO2 tire has a snow rating and they are very quiet on the road. Heavy side walls. I'm running 30lbs of pressure which put me at 33 lbs on the road. I used a infrared thermometer after the tires came up to road temperature to get a good flat tire patch on the road. Trial and error until I got a good even heat range across the tire. Look them up on Tire Rack! They give you the spec's of almost all the tires. BGF KO2 pasted with flying colors. Much better then the BFG AT I had on my 2012 Tacoma.
  13. Nov 10, 2016 at 7:13 AM
    #73
    TRDPugz
    dimitri
    The stock wheels are a 16 by 7 while the normal pro 4runner wheels are a 17 by 7 with a +4 offset, the Fn FX pro wheels are very similar to the 4runner wheels but are 20lb lighter, they are a 17 by 8 with a 0 offset and 4.5 backspacing
  14. Nov 22, 2016 at 6:13 AM
    #74
    amirak
    amirak Well-Known Member
    I love the stock trd pro wheels but needs bigger tires. What is the latgest tire that can go on those without rubbing?
  15. Nov 22, 2016 at 6:28 AM
    #75
    Taco Fan
    Taco Fan Well-Known Member
    Fort Worth, TX
    2017 White TRD PRO AT 5 ft bed
    Console Organizer, black tailgate letters, chrome glove box letters.
    Black letters on tailgate looks great.
  16. Nov 22, 2016 at 6:30 AM
    #76
    Taco Fan
    Fort Worth, TX
  17. Nov 22, 2016 at 7:58 AM
    #77
    TRDPugz
    dimitri
    With 17 you can run 267/70 with 16 I believe you can run 275/70 maybe even 275/75
    amirak[QUOTED] likes this.
  18. Nov 25, 2016 at 2:14 PM
    #78
    Shake
    Shake Active Member
    Adam
    McLean, Va
    2017 Pro-Sticky Shift
    275/70/16 Ko2's
    Pro family. I need help. My 2017 pro makes a weird noise when brakes are applied. It's like a humming/vibrating feeling. It happens for like 2-4 seconds then goes away. It's mainly when stopped or decelerating. Any ideas of why this could be? Or is this happening to anyone else? ✌️
    Connorcc10 likes this.
  19. Nov 25, 2016 at 2:15 PM
    #79
    TRDPugz
    dimitri
    Never had any issues. Not sure sorry man
  20. Nov 25, 2016 at 2:18 PM
    #80
    josefmd
    josefmd Well-Known Member
    Springboro OH
    2017 4R TRD Pro Cement. 2024 Ford Ranger Raptor
    No I haven't experienced that either. Sorry to hear about your issue. Unfortunately it looks like a trip to the dealer.
