2017 Timing Cover Leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mopar2, Jan 17, 2022.
  1. Oct 26, 2022 at 8:42 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Another reason I wanna sell mine while I still can lol. 2800$ to fix this holy shit.
    InChrist likes this.
  2. Oct 27, 2022 at 6:03 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    It’s covered 100% using my extended warranty. I drop it off on Tuesday. 18 hours of repair time. They told me the problem has also affected other models, not just Tacomas.
    RedWings44 and doublethebass like this.
  3. Oct 30, 2022 at 6:47 PM
    Hooper89
    Just looked at mine and there's old oil there. Looks prehistoric and caked on so maybe it decided to fix itself.
    jmneill and JRE like this.
  4. Nov 3, 2022 at 5:52 PM
    Ronk44
    Rockerville, SD
    2017 MGM Sport
    Picked up Tacoma on 3rd day, $3200 billed to extended warranty company, all appears good with truck. Will see if I notice any problems over next few months.
    doublethebass likes this.
  5. Dec 19, 2022 at 10:07 AM
    JRE
    JRE Member
    James
    2016 Black Tacoma TRD Off Road 4x4
    None Yet.
    Just got this dreaded call on my 2016 Tacoma 4x4 Off Road
    62,000 miles
    The AZ Dealer wants $5,000 to fix it.
    WTAF ?
  6. Dec 26, 2022 at 5:30 PM
    tacomatrddave
    tacomatrddave Well-Known Member
    2023 Tacoma Access cab sr5 v6 4wd
    Sumo springs. Shocker air hitch.
    I had the dreaded timing cover leak at 130,000. I lucked out. Since I had just barely come off the extended warranty they repaired it for me for $500 my cost at the dealership. Sadly I’m now at 156,000. And the timing cover is leaking again in the exact same spot, near the power steering pump. Very disappointing. I know dealership said they managed to reseal it without removing the engine. So my guess is I’m a victim of poor quality resealing work. I cleaned it all up, added dye, sure enough it’s leaking again. I’m monitoring for now. While I cannot afford to replace this truck any time soon and it’s my daily driver, it runs perfectly, I’m hoping this is just a slow leak that can be lived with. It’s not dripping on any belts or hoses. Actually blows back so not doing any damage. Slight smell. Who cares. And when I changed the oil it was just under the full mark, at 5000 miles oil change. So I may just live with it. They quoted between $3500 and $5000 to repair it again at the same dealership. When I said why is it leaking again I got the sometimes this happens. But $5000 buys a lot of oil that can drip out if it’s only leaking less than 1/8 quart per oil change. Any tips or tricks anyone had to seal this area from the outside would be helpful. I would never put stop leak in these engines! Just too many small ports and spaces.
    Canadian Caber likes this.
  7. Dec 26, 2022 at 5:34 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Good call, change that MF while the engine is out. Even if it cost you $200.~ $300., just do it.
  8. Dec 26, 2022 at 5:39 PM
    Benny22
    20Tacoma
  9. Jan 18, 2023 at 12:12 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Just had my 95000 service done today. I was told there was a potential oil leak evidenced by "oil where it's not supposed to be." No idea why I didn't think to ask specifics about location. However, the dealer did suggest potential timing cover leak, which I got the impression he suggested because of how common it apparently is.
    I did ask if it was possible that it was part of my rust proofing since I used a lanolin based product and it has been unseasonably warm since Christmas. He said oil is usually thinner, but it was possible. However, we'll have to double check it at the next service and go from there. Luckily I do have the platinum warranty so I would think that would cover it. Although they've found every excuse to tell me why something isn't covered in the past so I'm definitely skeptical.
  10. Jan 18, 2023 at 12:20 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    be skeptical - I had a tech tell me all 4 of my shocks had blown because they were "covered in oil"..... it was my Krown undercoating
    RedWings44[QUOTED] and Junkhead like this.
  11. Jan 18, 2023 at 12:49 PM
    RedWings44
    Michigan
    Well, I don't plan to apply any more before the next appointment so we'll see. Although, I do think I put it on before the last oil change as well. He did admit it was entirely possible the previous tech got some oil on something and didn't clean it up all the way. But, all the more reason to follow up rather than jump to conclusions yet.
    Either way, if they want to do the job and it is covered, I'm all for it considering my platinum warranty expires in 15,000 miles.
    doublethebass[QUOTED] likes this.
  12. Feb 24, 2023 at 8:48 AM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    Edited: Same “coolant bypass issue” on my 22’ ever since I had it. Every 4K it would empty the reservoir.
  13. Feb 25, 2023 at 4:21 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Your power steering (I assume) reservoir becoming empty has nothing to do with the timing cover leak problem. If you're losing a full reservoir capacity in 4k miles there is a major leak somewhere. Are you inner tie rod boots leaking fluid or filled with fluid? No matter the cause, on a '22 it should be a warranty fix, neglecting it will only cause other problems or make things worse.
  14. Feb 26, 2023 at 7:46 AM
    danny15l
    nada
    Sorry I was referring to the coolant bypass issue.
  15. Feb 26, 2023 at 7:51 AM
    #35
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Since you were able to clean it well, why not try to apply Toyota black silicone outside . Is it permatex ? There’s a thread here where it’s been a success no further leaks .
  16. Feb 26, 2023 at 9:19 AM
    #36
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Yours is leaking oil a 2022?.
  17. Feb 26, 2023 at 10:09 AM
    #37
    danny15l
    nada
    No coolant bypass.
  18. Feb 26, 2023 at 5:42 PM
    #38
    Cazman13
    Cazman13 Well-Known Member
    Northern Minnesota
    2022 Tacoma TRD OR Premium Blue Crush
    I had the timing cover leak on my 2022 only 2,500 miles into it. Hopefully I don’t have to have it fixed again! Lucky it was all warranty work!
  19. Feb 26, 2023 at 5:45 PM
    #39
    Gfenza89
    How bad was the leak ?
  20. Feb 26, 2023 at 5:46 PM
    #40
    Cazman13
    Northern Minnesota
    There was a few decent size spots on my garage floor. About 2” in diameter.
