2017 Toyota Tacoma oil leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bbmaddox89, Nov 12, 2022.
  1. Nov 12, 2022 at 4:49 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    How long have you owned it? Miles, and time/months/days? Dealer or private party? Reason for asking. I hope not for your sake, someone didn't put stop leak in it gor resale value. I hate to think they would do so, even bringing it up to you.
  2. Nov 12, 2022 at 5:05 PM
    Bbmaddox89
    Bbmaddox89 [OP] Active Member
    2017 Tacoma off-road
    I bought it 3 months ago I've put about 5,000 mi on it ,bought it from a dealer in ca.... When I took the skid plates off it was super cleaner didn't look like it had been leaking before.... Everything was super clean like it had been pressure washed or deep cleaned
  3. Nov 12, 2022 at 5:09 PM
    Bbmaddox89
    I did wonder how a truck like that could end up for sale maybe I'll try an oil change tomorrow
  4. Nov 12, 2022 at 5:21 PM
    na8rboy
    WI
    Any warranty, from dealer?
  5. Nov 12, 2022 at 6:01 PM
    Bbmaddox89
  6. Nov 12, 2022 at 6:08 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    What brand of oil did you use? Was it some "high mileage" formula?
  7. Nov 12, 2022 at 6:11 PM
    Bbmaddox89
    Castrol 020 synthetic I stayed away from the bottle that said high mileage I went with the one that said full synthetic
  8. Nov 12, 2022 at 6:13 PM
    na8rboy
    WI
    High mileage oils have additives to help swelling of seals.
  9. Nov 12, 2022 at 6:19 PM
    Rusty66
    Rhode Island
    I'd drain it out, see how much you get (measure it) you never know if it's the wrong dipstick..... I've seen that happen.
  10. Nov 12, 2022 at 6:20 PM
    Rusty66
    Rhode Island
    Which is why I tell people never to use that crap.
    Starman2112 and Idaholandho like this.
  11. Nov 12, 2022 at 6:22 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You sure the o ring was in the proper place ?
    zoo truck, JmsWms and na8rboy like this.
  12. Nov 12, 2022 at 6:23 PM
    Bbmaddox89
    Appreciate the advice I'll try and oil change tomorrow and see if it helps I'll put in Mobile One 020 instead
  13. Nov 12, 2022 at 6:25 PM
    Northwoodshyun
    Northwoodshyun Well-Known Member
    St. Paul MN
    Hooper89 and KY_Rob like this.
  14. Nov 12, 2022 at 6:28 PM
    Bbmaddox89
    The oil filter housing is further up on the engine and where this leak is, above the oil pan below the transmission the oil filter housing is dry and I changed it out for a new one this morning no change in the leak so I don't think it's the oil filter or the housing
  15. Nov 12, 2022 at 6:34 PM
    #35
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    If it was drained and you dumped 6 back in, I highly doubt you over filled it unless it wasn’t completely drained. I always refill mine with exactly 6. Forget the extra bottle for the “.2” the manual talks about. When I put 6 in I literally can bet on the level when I check it to be about 3/4 to the top of the normal range on the dipstick.
  16. Nov 12, 2022 at 6:36 PM
    #36
    Bbmaddox89
    I didn't even think about maybe not all the oil drained out when I did the oil change that could be a possibility would overfilling cause the symptoms I'm talking about
  17. Nov 12, 2022 at 6:37 PM
    #37
    Northwoodshyun
    St. Paul MN
    Please don't feel bad if you made an error. When I was changing oil and filter on my 2016 4Runner, I was exact on o-ring placement and how I tightened the oil filter housing. It initially feels hard then gets easy before getting tight again. So I used a torque wrench whenever I changed the oil on my 4Runner. The tightening feel is much different on the cartridge type if you are used to can oil filter type.
    It is possible that you may have cracked the oil filter housing during removal or replacement.
    KY_Rob likes this.
  18. Nov 12, 2022 at 6:38 PM
    #38
    Bbmaddox89
    But it was only a little over the dot it really wasn't that bad and also that 020 is really thin especially when it's brand new
  19. Nov 12, 2022 at 6:40 PM
    #39
    Bbmaddox89
    I'm hoping I made a mistake I've watched countless how to videos on that caster filter I'm pretty confident I did it correctly and the oil leak is not coming from the canister filter it's further back towards the pan
    Northwoodshyun likes this.
  20. Nov 12, 2022 at 6:45 PM
    #40
    avi8or_co
    Anything’s possible. My suggestion is to start over.
    First attack it with degreaser/brake clean, whatever and get as much of the mess cleaned up.
    When you change it, be on level ground with the nose higher in the air. That’ll get as much as you can out. Make sure your o ring is on the correct spot on the can. Dump in 6 quarts…that’s it. Torque everything correctly. Drive it a bit let it sit and check the level. You’ll be in the correct range. Then keep an eye on things.
    Wouldn’t hurt to dump some UV dye in there too to find the leak if it is indeed leaking. That stuff is a few bucks and you can get a harbor freight UV flashlight probably free if you buy something else you need
