2017 TRD Off Road now stock with an axle shim
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoskidmarks, May 24, 2017.
  1. May 25, 2017 at 9:56 AM
    #41
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    that would be pinion down... right?
  2. May 25, 2017 at 10:01 AM
    #42
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Welcome to the club.
    fdbyrne and trdsupreme[QUOTED] like this.
  3. May 25, 2017 at 1:44 PM
    #43
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    No , opposite . Come on guys this is basic stuff. It's a wedge it's thick in the back and thin in the front so it rotates it up in the front.
  4. May 25, 2017 at 2:30 PM
    #44
    Z50king
    Eric
    Southern California
    Stock and loving it
    I kept putting the shim above the leaf in my head. so confusing
    Hiluxski[QUOTED] likes this.
  5. May 25, 2017 at 2:35 PM
    #45
    -JDC-
    -JDC- Well-Known Member
    2017 TRD Off Road
    2017 DCSB TRD OR, has shims plus about 1 inch of extra lift and a little over 5k miles. No drive line vibes or unusual noise.
    Guess I'm one of the lucky ones.
  6. May 25, 2017 at 6:22 PM
    #46
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
  7. May 26, 2017 at 4:26 AM
    #47
    matts11
    matts11 Well-Known Member
    TN
    Why is this only on the off road? Out of curiousity I peaked under my non OR and there isn't a shim. I don't get any vibes or whine. Does the OR have higher ride height?
  8. May 26, 2017 at 4:41 AM
    #48
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    you dont need to drop the carrier bearing down, you need to shim the angle of the diff/driveshaft connection up so that the diff housing is more in line with the driveshaft. They sell "rear axle shims" in different sizes between 3 and I think about 6 degrees is the most Ive seen on a taco. If you have no lift probably 3 degree shims if any at all are needed, 2-3" lift would be where a 4 or 6 degree shim would be needed. The problem is that in order to get a vibe-less driveshaft, the angle of your fist shaft out of the transmission to the carrier bearing should be something like 4-6 degrees down, and then the angle at the diff going up needs to match that with 3-5 degrees up, up to one degree of difference between both is acceptable, but anything more than about 1.5 degrees is likely to have vibes. I know because my truck had terrible vibes before I had the axle shim installed, had a 3 degree shim installed first with a 2.5" lift and vibes arent totally gone but much better so I'm thinking a little more shim is needed. An angle finder can be used to quickly verify where all your angles are at before/after as well.
    -JDC- likes this.
  9. May 26, 2017 at 2:46 PM
    #49
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    No shims on mine. Built in January. :poking:
  10. May 26, 2017 at 3:10 PM
    #50
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Added a Toytec lift to my sons 17 TRD4x4OR DCSB MT6 build date Jan 17 and there was no shim, no noise.
  11. May 26, 2017 at 3:17 PM
    #51
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    Did you add spacers under the driveshaft carrier housing when you did the lift?
  12. May 26, 2017 at 3:55 PM
    #52
    Hiluxski
    Ventura California
    it would be helpful if people posted built dates maybe we can narrow it down . I'm also wondering if it's just the OR model getting the shims.
    shakerhood likes this.
  13. May 26, 2017 at 6:22 PM
    #53
    Syncros
    Syncros Well-Known Member
    Odd that they dont change the spring perches to correct the angle.
    Hiluxski likes this.
  14. May 26, 2017 at 8:54 PM
    #54
    sig916
    sig916 Well-Known Member
    2017 OR with shims. Notice it last month while lifting the truck. I said its a 1 inch degree shim. 6k on truck with no howling
  15. May 26, 2017 at 9:13 PM
    #55
    shakerhood
    Southern Ohio
    What month was your 17 built and was it from Mexico or Texas?
    sig916[QUOTED] likes this.
  16. May 26, 2017 at 9:16 PM
    #56
    sig916
    Dec 2016, in Mexico.
    shakerhood[QUOTED] likes this.
  17. May 26, 2017 at 11:00 PM
    #57
    Halena Molokai
    No I did not but I did order it, test drove it first to see if it was needed. So far all is good. I believe keeping the factory rake is important even when lifting. $.02
  18. May 26, 2017 at 11:35 PM
    #58
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    That's not a solution, and I'm pretty sure that guy had continuing issues. It takes time to get the angles right. Plus, that is a pretty long 1-piece driveshaft, balancing becomes critical. The rear vibrations started when Toyota took the CV out of the front of the driveshaft, which made it harder to adjust to the proper angles, and made it more sensitive to change.
    I've got Dakers and 2 1/2" tapered blocks (3*) and 3/4" Carrier Bearing Spacer. Zero vibrations, zero howl. That was with stock 3.92's and now with 4.88's.
    SilverII likes this.
  19. May 26, 2017 at 11:44 PM
    #59
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Thanks for posting this.
    As for the needle bearing, Tacoma's have had this issue since 95.5.
  20. May 27, 2017 at 5:49 AM
    #60
    matts11
    TN
    My Limited was built in Dec 2016 in Mexico and has no shims......must just be an OR thing.
