2017 TRD Off Road now stock with an axle shim
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoskidmarks, May 24, 2017.
  1. May 27, 2017 at 8:10 AM
    #61
    tacoskidmarks
    tacoskidmarks [OP] Member
    2016 Double Cab TRD
    OME 887-Nitrochargers 3 leaf Progresive AAL over 1 in block, Nitrochargers
    Only the off roads had the shims at my dealers lot.
    I think with the 2-1/4 inch lift I have in the rear, I will try some 2 or 3 degree shims.
    plus the OME spacer I have in there now and some more drop washers if needed. I will check the drive shaft angles, which is a bit confusing to me.
    I think it would be cool if members posted the lift heights at the rear and there solutions for how they solved vibrations. Mine are not horrible but, I would like to get this resolved. I did email Toyota care about the reason there in the 2017's, but have gotten no response yet.
    Off subject track, but I have not had any other issues with the truck, and at 20,000 miles now.
    I really like the Multi Terrain select, I keep it on the mud setting and when I climb my icy 300 foot long step driveway, the Taco spins all fours.
    Diablo169, Dude that's a nice looking ride, you must be at 5 inches in the rear alone.
    Diablo169 likes this.
  2. May 27, 2017 at 9:15 AM
    #62
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    11/16 Build date. No shims, no vibrations or howling from my OR.
    Prof_KeenBean likes this.
  3. Jul 8, 2017 at 5:09 PM
    #63
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    Did anyone ever figure out what degree shim is used?
  4. Jul 8, 2017 at 6:27 PM
    #64
    LJGIbbs
    LJGIbbs Well-Known Member
    Independence Missouri
    2017 TRD PRO Cement 6MT
    none yet/none planned! It's perfect!
    Mine has the shim. 4/17 build date in San Antonio.
    No vibration but very slight howl only detectable with the radio off.
    The control arm bushings were installed from the factory.
  5. Jul 8, 2017 at 7:01 PM
    #65
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I wish they had a part number.
    not0ny likes this.
  6. Jul 8, 2017 at 9:38 PM
    #66
    Boxerocks
    Boxerocks Well-Known Member
    Washington State
    2017 Tacoma TRD Sport DCSB Manual
    OV Tuned, OME 887 coils, Headstrong 3 leaf AAL, Bilstein 5100's, JBA uca's, Level8 MK6 wheels, BFG KO2's 275/70R17, mesh front grill, Rally Armor mudflaps
    No shims on my '17 trd sport, May '17 build. And I do have some driveline vibes on deceleration around 10 mph after doing a 2" lift
  7. Aug 7, 2017 at 10:14 PM
    #67
    not0ny
    it looks like a 2 degree shim. i looked under a few off roads at my local dealer and ended up purchasing 2 degree shims. actually fixed the drive line vibration i had from 10-35 mph.
    my truck is lifted on bilstein 6112/5160 with wheelers 3 leaf progressive aal. Also did the ECGS bushing swap, but still had vibrations. the 2 degree shim eliminated all my vibrations.
  8. Aug 8, 2017 at 12:16 AM
    #68
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Mine built March 17, ACC in San Antonio, has the shims, no howl, but haven't added the 6112/5160s yet. Now I'm worried about doing it.
    I can't imagine it would make a difference, but is there a difference between the effect on AC versus DC (San Antonio versus Baja builds)?
  9. Aug 8, 2017 at 12:48 AM
    #69
    #4TOY4ME
    #4TOY4ME Now driving #5
    Robert
    Kingman AZ
    17 MGM OR 4X4 AC
    Level 8 Mk6 16x8 0 offset , Bilstein 5100 G4 Elite Fold A Cover
    My A/C TRD OR A/T was built in Texas 10/16 and It has the shims. No diff howl with 7,800 miles.
  10. Aug 8, 2017 at 8:23 PM
    #70
    shackley
    Yeah, I'm wondering about the DC vs AC.
  11. Aug 9, 2017 at 12:15 PM
    #71
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    AC and DC short box has the same wheelbase and length.
    Hiluxski likes this.
  12. Jan 4, 2021 at 4:01 PM
    #72
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    I have a 2017 Sport 4x4 and it does not have stock shims. From previous Toyotas I've had (87, 99, 02), this is the first one that DOES NOT have a single piece driveshaft. I never had a second gen so I don't know if they also had a single piece driveshaft of the newer two segment style with a carrier bearing. My 2017 truck is not lifted (yet) and has no vibes. Depending on lift height, dudes are doing some combination of the following: ECGS bushing, diff drop, carrier bearing drop, rear axle shims. While the ECGS is a front end vibe fix, the rest all deal with the rear driveline itself. In the older trucks, a single long driveshaft and yoke seemed to be more resilient to changing from stock to lifted because of the longer length, the lift does not change the angles at the U-joints that much. Plus, there were only two U-joints which seems to create less issues with balancing/vibes. When Toyota switched to this two segment driveshaft and carrier bearing system, that's when it got annoyingly complicated. By anchoring at the carrier bearing midway under the vehicle, dropping the rear diff in the lift makes all of the angles much more severe when the back part of the driveshaft is so short between carrier bearing and rear diff. The various drops/spacers/shims are all just cheap attempts to straighten out a driveshaft that shouldn't be a two piece system in the first place. My conclusion is that all of these driveline vibrations are due to the more complicated physics of having a perfectly balanced two piece driveshaft versus a longer, stronger single piece driveshaft. Ideally, Toyota goes back to a single piece driveshaft in the future so there is less frustration on this topic. That said, if you can fix vibe issues with a few cheap shims here and there, it is way cheaper than a full driveshaft replacement, but if all else fails, I watched a TacomaBeast video last night where he got a new single piece driveshaft and deleted the carrier bearing so my theory may be coming true one truck at a time.
