2018 Bed Rail System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rpoint16, Jun 29, 2018.
  1. Jun 29, 2018 at 9:08 AM
    rpoint16
    rpoint16 [OP] Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    I picked up my 2018 Tacoma last week & just noticed something...
    The deck rail system for the bed does not have a deck rail against the cab, only the sides. It that the same on all? It does have two holes in the center that look like there for a factory accessory.
    I might pull the one off my 08 before I sell it...
    Socal562 likes this.
  2. Jun 29, 2018 at 9:10 AM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    The 3rd gens don't come factory with one. I installed it separately. The holes you see there are for the factory tonneau cover mount
  3. Jun 29, 2018 at 9:14 AM
    Boricua
    Boricua Well-Known Member
    Jack
    2018 TRD Sport
    I bought mine from Amazon at a good price.
    remgu2000 and tonered like this.
  4. Jun 29, 2018 at 9:16 AM
    rpoint16
    Tempe, AZ
    Bone Stock
    Thanks. I feel stupid not noticing it. I used the back rail somewhat often.
    When you installed one separately, did you use an old one or order a new one? Did youy grind down the "hole" ridges for a snug fit?
  5. Jun 29, 2018 at 9:26 AM
    Boricua
    Jack
    2018 TRD Sport
    No grinding is necessary and you will utilize the same bolts as well. Both 2nd and 3rd gen are the same rails. I bought the 2nd gen rail because it was less $.
    Marbleyard, tonered and tAcomaPueblo like this.
  6. Jun 29, 2018 at 9:27 AM
    FirsTaco
    FirsTaco Well-Known Member
    Jeff
    Reading, MA
    '22 Ford Bronco Badlands
    You do not use those holes. There will be torxheads that hold that part on. Remove those and bolt the rail and the factory piece that is there on. Use the hardware that is holding it on now. The old one is the same part, just take it off your 08.
  7. Jun 29, 2018 at 9:28 AM
    rpoint16
    Tempe, AZ
    Bone Stock
    Got it. I did not look closely. It mounts below the upper rail.
    Thanks.
  8. Jun 29, 2018 at 2:21 PM
    Ossaris
    Aliens
    SoCal
    Yup. You can get the rail off Amazon if you really need it too. I think its only $50 (but you already have an '08 so you're probably good)
  9. Jun 29, 2018 at 2:28 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Another little tip. I was annoyed with the height difference between the front and side rails. When you install the front accessory rail, look under the existing upper rail. There is some foam tape there. It is not very thick, but makes a slightly noticeable difference in height with it removed.
    Socal562 and toyotatacomaTRD like this.
  10. Jun 29, 2018 at 2:38 PM
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
  11. Jun 29, 2018 at 2:44 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Hambone437 likes this.
  12. Jun 29, 2018 at 4:03 PM
    Hambone437
    Hambone437 Well-Known Member
    Northern California
    2018 Tacoma TRD Off-road
    Pop & lock power tailgate Passenger Door Smart Key System mod (thank you @Victory) HomeLink garage door rear view Mirror Pro front grille swap Letter inserts on tailgate and glovebox “Tacoma” TSB-0063-18 and TSB-0058-18 performed.
    Perfect. Thanks dpippel. I just ordered one.
  13. Jun 29, 2018 at 11:59 PM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  14. Feb 11, 2021 at 7:42 AM
    Lodom89
    Lodom89 Active Member
    Larry
    2017 TRD Off-Road 4x4
    Reviving an old but relevant thread. I needed the head bed rail for my 2017 and have had one on my Amazon list for months. Then I saw it was only $43 at my local dealer. Called and he said it would be $300+ for the 2017! I went by and showed him the part number and testimonials that it fit to which he replied that the 2017 is totally different than the 2nd Gen, according to his computer. So we both took the "2nd gen" part out to my truck for a test fitting and proved it fits. He was still skeptical but I just popped it on with a perfect fit. I've looked and can't even find the one that is officially 3rd gen.
    Vbpiper likes this.
  15. Feb 11, 2021 at 7:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is no official 3rd Gen part. We just order the 2nd Gen just like you did.
    shakerhood likes this.
  16. Feb 11, 2021 at 8:38 AM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    This is on our list of items to add to our 2021. Used the front rail all the time on our 09.
