2018 Black Badges
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shacol, May 5, 2018.
  1. Oct 4, 2018 at 8:59 PM
    #161
    SnakeDoc
    SnakeDoc Well-Known Member
    Adam
    North County SD
    2018 TRD Off Road DCSB - Cement
    I second this. These are the same overlays Toyota sells as the ‘blackout package’ so it’s a factory-quality fit.
    Boyitz, ZubZub and shakerhood[QUOTED] like this.
  2. Oct 7, 2018 at 12:12 PM
    #162
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    What did you guys use to clean the badges before putting the overlays on? Also, how warm do you think it needs to be to get good adhesion? We are hitting about the 50s is all for highs here in MN and don't know if we'll get back to 70+ still this season or not. Looking doubtful. Debating whether to put them on now or wait until spring at this point.
  3. Oct 7, 2018 at 1:42 PM
    #163
    SnakeDoc
    Adam
    North County SD
    You’re fine in the 50s. Give the existing badges a quick wipe down with isopropyl alcohol to get rid of any wax/oils, then dry and apply.
    shakerhood likes this.
  4. Oct 8, 2018 at 1:34 PM
    #164
    deusxanime
    MN
    OK. What about the TACOMA insert letters for the tailgate? Is that safe to use on paint to clean those up too before applying?
  5. Oct 8, 2018 at 2:07 PM
    #165
    SnakeDoc
    Adam
    North County SD
    Yeah, I used a little 70% isopropyl to clean the tailgate insert area before installing mine. I didn’t end up using the tailgate inserts from this kit though. I already had the matte black inserts from @rrentrop (TVDvinyldecals.com), which I prefered over the raised gloss inserts.
  6. Oct 8, 2018 at 5:50 PM
    #166
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I used 92% Isopropyl alcohol, used a couple Q-Tips do get the sides and in between the letters just to make sure they were clean.
  7. Oct 12, 2018 at 10:10 AM
    #167
    WeezyODU
    WeezyODU Well-Known Member
    2017 MGM Sport DCSB
    I know they say 2018 and up... will they not fit a 2017? Are the emblems a different shape on the 18s?
    Boyitz likes this.
  8. Oct 12, 2018 at 10:31 AM
    #168
    SnakeDoc
    Adam
    North County SD
    They only say 2018 because it doesn’t include the grille emblem (because of the new TSS emblem on the 2018s). Everything in this kit will fit a 2017 - you’ll just be left with the chrome grille Toyota emblem.
    Boyitz and WeezyODU[QUOTED] like this.
  9. Oct 12, 2018 at 10:32 AM
    #169
    WeezyODU
    2017 MGM Sport DCSB
    Awesome, thanks!
  10. Oct 22, 2018 at 7:50 PM
    #170
    Fatty Msclimm
    Fatty Msclimm Well-Known Member
    Fatty
    2018 DCLB TRD Sport Cement
    I uhh...peeled the stickers off. Does that count?
    Has anyone just marked off the badge location, taken the badges off, painted then, and then glued them back on the truck? If so, how did that work?
  11. Oct 23, 2018 at 5:21 AM
    #171
    bgogue
    bgogue Gogweee
    Brandon
    San Antonio, TX
    2018 MGM Tacoma TRD Sport 4x4 DCSB
    I bought a set from Toyota McDonough on Amazon. Haven’t put them in as I’m waiting for weather to warm up this weekend. So far they look good though. Just beware on eBay because Sellers are claiming they’re selling overlays but they’re actually emblems. Had to return twice due to false advertisements before I found the right item on Amazon!
    Boyitz likes this.
  12. Oct 23, 2018 at 6:55 AM
    #172
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    If you glue them on, taking off the emblems after that will result in taking paint with them. You can use 3m tape, but you'll have to have surgeon like hands to cut it exact so you won't see the tape.
    I saw what they were charging for the overlays and said forget that, I just took all the emblems off. Looks much cleaner.
    Fatty Msclimm[QUOTED] likes this.
  13. Oct 26, 2018 at 1:06 PM
    #173
    Lanayru
    Lanayru Well-Known Member
    2016 Quicksand Tacoma OR
    Any reason people are preferring the overlays vs new black emblems? I’m with the OP and want my letter As and such to have holes in them. What’s wrong with the aluminum badges?
    Is the 4x4 that comes in the overlay kit an overlay also? I don’t like my V6 being lonely and would like to add the 4x4 emblem as well.
  14. Oct 26, 2018 at 1:10 PM
    #174
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    •TRD OR Tacoma•
    Here’s the part# for the OEM 4x4 Badge.
    Lanayru[QUOTED] likes this.
  15. Oct 26, 2018 at 1:28 PM
    #175
    Boyitz
    Boyitz Well-Known Member
    Baltimore
    2018 TRD Sport 4x4 DCSB Cement
    It's just easier, I think. I ended up taking my V6 off for that exact reason. Unless you get right up on the side overlays, you can't really tell there's not a hole there.
  16. Oct 26, 2018 at 1:28 PM
    #176
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    i have the SR5 (2), Limited (2), 4x4, and V6 overlays from the 2018 SE Toyota kit. I have no use for them and they're just sitting in a box. Let me know if you want any of them. Just pay postage or meet up locally (i think i'll send them in the small, 2 day, priority flat rate box).
    Edit: V6 has been claimed
    Soul Surfer and Boyitz like this.
  17. Oct 26, 2018 at 1:29 PM
    #177
    Boyitz
    Baltimore
    That was the only annoying part. Mine are just sitting around as well.
  18. Oct 26, 2018 at 3:28 PM
    #178
    deusxanime
    MN
    With the overlays you just stick them on top and you are done. With emblems you have to completely remove the originals (including the sticky tape) and then hope to place the new ones correctly. Much more of a hassle.
    407guy and Boyitz like this.
  19. Oct 26, 2018 at 9:27 PM
    #179
    Mhernandez182
    Mhernandez182 Member
    Michael
    16 Trd 4x4 off road crew cab long bed
    Stock
    I Have only heard horror stories about trying to paint the badges, Any solid success stories with the overlays? pictures maybe?
  20. Oct 26, 2018 at 10:08 PM
    #180
    Sarz42
    Sarz42 Member
    Arizona
    2016 TRDOR Inferno Orange
    Mbrp exhaust, 1 inch front spacer, go rhino front bull bar. Avs rain guards and weather tech matts
    Im looking for just the door "TACOMA" overlay in black if anyone is not using? I figure i dont wanna spend the money if im only going to use 2 of the 7 overlays.
    And i can pay or meet up locally in AZ
