2018 Factory Alarm Question
Discussion in '3rd Gen. Tacomas (2016+)' started by banzaikid1, Mar 20, 2018.
  1. Mar 20, 2018 at 7:33 PM
    banzaikid1
    banzaikid1 [OP] Well-Known Member
    Has anyone added the glass break sensor (PT398-35160) to a 2018 with the factory alarm.
    I looked at the directions and it shows that a jumper plug is needed to replace a dummy plug on the hood latch but I have a plug that goes to a cable.
    Also will I need to enable the GBS with techstream if the factory alarm is already enabled.
    The dealer said it isn’t compatible with the 2018 but I think they are just trying to sell me their system.
    Thanks
  2. Mar 20, 2018 at 9:02 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    My understanding on a 17 is it needs to be enabled with tech-stream and you don’t need the jumper.
  3. Mar 21, 2018 at 8:04 AM
    banzaikid1
    Ok thanks I’ll go ahead and try to install
  4. Jun 1, 2018 at 7:23 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Did you end up needing a tech-stream to set up the factory alarm on your 2018?
  5. Jun 1, 2018 at 8:44 PM
    banzaikid1
    No I didn’t I just had to turn the sensor up to 8
    I have a TRD Sport so I guess if you have the factory alarm it’s already activated
    02Duck likes this.
  6. Jun 7, 2018 at 1:02 PM
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Did you have the V5 wiring harness or the V2 wiring harness? I have the V5 harness.
  7. Jun 7, 2018 at 1:09 PM
    banzaikid1
  8. Jun 7, 2018 at 1:16 PM
    okichewy1
    Ken
    Kimberly, Idaho
    Cool, so I also have a 2018 TRD Sport. Basically the only thing you didn't hook up was the wire plug under the hood then? I took that same picture you did with the harness under the hood. Was confused with that part.
  9. Jun 7, 2018 at 1:31 PM
    banzaikid1
    Yeah didn’t hook up the hood plug
    Just make sure u turn up the sensitivity on the sensor
    okichewy1 likes this.
  10. Jun 7, 2018 at 2:00 PM
    okichewy1
    Ken
    Kimberly, Idaho
    Cool, thanks for the info.
  11. Sep 16, 2018 at 5:32 PM
    dano3131
    dano3131 New Member
    Dano
    2018 Tacoma TRD Sport
    Ok all you experts? I bought a 2018 Tacoma TRD Sport like two weeks ago. Kind of got screwed I feel by the dealer? I thought I bought one with an (ALARM) in it since it has stickers saying TOYOTA ALARM on the windows. But in the finance office the guy that wanted to get me out the door cause he wanted to go home said do you want to pay for the alarm or we will disable it? I didn't pay more so some things seen to work and others don't?
    I have 2 remotes with panic and unlock and lock with keyless entry. Now the panic button works but if I open the door with the window down and the doors locked with remote no alarm sound and If I bang on windows no alarm sound. I went back to customer care they said my truck was traded from another dealer and didn't come with the KARR alarm Toyota dealers install on their vehicles! Funny thing is if you remove the kick paned there is aftermarket alarm wires installed going to what looks like a mounted box behind the knee panel on the left side along with a Valet button installed that looks like a fake obII but smaller and has I believe a green button in it. My question is How do I re in able the missing functions or do I have to pay Toyota a lot of money to restore what they removed?
    Thanks
    Dano3131
  12. Sep 17, 2018 at 6:04 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  13. Sep 17, 2018 at 7:38 AM
    Flash1034
    Flash1034 Well-Known Member
    Southern California
    2018 Toyota Tacoma TRD Pro, Cavalry Blue, Automatic
    DuraTrac Tires HID Headlights MESO LED Taillights ARB Recovery Point
    Does a truck equipped with the factory alarm already have the glass break sensor?
    mds08 likes this.
  14. Sep 17, 2018 at 2:56 PM
    VicNic3
    GA
    Mine has the alarm but do not have the GBS installed. Installed at a later date.
  15. Sep 17, 2018 at 4:00 PM
    daveometrod
    daveometrod Well-Known Member
    18 TRD OR 4x4 DCSB Blazing Blue
    Was the key fob well away from the vehicle when you tried to see if it had an alarm? Won't work if key fob is near vehicle. Been there done it redid it.
    To minimize noise, keep the actual key in the door lock. Use it to disable the alarm instead of the extra time to get the fob.
    My 18 DCSB OR didn't come with the GBS. I added it myself, plug and play, and it worked.
  16. Sep 17, 2018 at 10:26 PM
    Flash1034
    Southern California
    Where do you get a GBS? How much does one cost? Where and how do you install it?
    Thanks
    PeeDeeTaco likes this.
  17. Sep 17, 2018 at 11:48 PM
    PeeDeeTaco
    PeeDeeTaco Custom Title
    Effingham, SC
    2017 TRD Off Road 4x4 DCSB Blazing Blue Pearl
    5100 + OME 888 + Headstrong AAL SOS Offroad Concepts Streamline Winch Bumper Smittybilt XRC 9500 winch Method Race Wheels MR308 Roost Falken Wildpeak AT3W Image Dynamics speakers/sub Tacotunes Amp and sub enclosure
    I didn't even know my truck had an alarm. I just tested it by sitting in the truck and locking the doors with the fob, waiting 30 seconds, and then manually unlocking the door at the inside handle. Loud noises and flashing lights. Now to see if I have a gbs.
  18. Sep 18, 2018 at 3:35 PM
    daveometrod
    Purchased at the dealer I bought the truck at $167 before tax. Toyota part number PT39835160. Make sure it fits your vehicle because there are variations out there. This requires keyless entry.
    It goes under the driver side dash. Microphone goes in the empty(unless you filled it with something else) spot to the lower left of the steering wheel. Not hard to do at all, have them print the directions for you or search the web for them. Use care with the trim clips in removing and replacing.
  19. Sep 18, 2018 at 7:10 PM
    Flash1034
    Southern California
    Thank you Sir.
  20. Oct 6, 2018 at 12:26 PM
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Adam
    Denver, CO
    2017 TRD OR MGM DCLB
    Can you use these (factory security system and GBS) in addition to an aftermarket security system like a clifford? Just installed a clifford 3706x and it is located underneath the truck attached to the frame.
