2018 piston value issue updated 8/14/22
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djgynee, Jun 24, 2022.
  1. Jun 24, 2022 at 10:28 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Smell BS, if they were correct and thought the engine needed to be tore down, they would push hard to do so. Typical extended warranty thievery . Could be a faulty injector leaking down when the truck is shut off. Fuel system is pressurized I believe. So in theory that cylinder may be getting a bit more fuel upon start up, and then levels out once it"s running. If it bothers you swap out the injector. Get OEM replacement.
    Mikeh80, davidstacoma and tstack22 like this.
  2. Jun 24, 2022 at 10:33 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If he would elaborate on the code it would help us guess less. P11EC is my best guess on what it is. That has popped up on quite a few 2016-2018s and even a few 19's and I've seen one 20. That code is for too much difference in air/fuel ratio between any two cylinders. The reason for that code is a bad valve causing the differences in A/F ratios between cylinders. Considering he says he needs a valve replaced, this code is likely the reason.
    Very likely the explanation of "fuel a fraction of a second before the next cylinder" was something lost in translation between what they told him and what he told us. Either that or they didn't quite explain the problem to him, which is very possible too.
  3. Jun 24, 2022 at 10:33 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Staring at the dash while stuck on the side of the highway isn't going to make you feel any better about the situation.
    Sharpish and Superdave1.0 like this.
  4. Jun 24, 2022 at 10:43 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Sure
  5. Jun 24, 2022 at 10:43 AM
    fourfourone
    Yea, that aint true
  6. Jun 24, 2022 at 10:57 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Hope in one hand and shait in the other and see which fills up first.
  7. Jun 24, 2022 at 10:58 AM
    fourfourone
    What
    AxisCab, 0xDEADBEEF and Superdave1.0 like this.
  8. Jun 24, 2022 at 11:02 AM
    ryanvar42
    None
    It’s def true they have diff detergents and that said detergents clean differently
  9. Jun 24, 2022 at 11:02 AM
    Gen3TacomaOBX
    S
    Just responding to a what-about troll in a deserving fashion. You want me to start posting threads where your glorious 4.0 shit the bed?
  10. Jun 24, 2022 at 11:05 AM
    fourfourone
    What is a what-about troll?
    my 4.0 hasn't shit the bed. Its been very reliable.
    AxisCab likes this.
  11. Jun 24, 2022 at 11:08 AM
    Gen3TacomaOBX
    S
    Just like I haven't been "Staring at the dash while stuck on the side of the highway" like you said. So WTF are you doing here?
    Junkhead and AxisCab like this.
  12. Jun 24, 2022 at 11:08 AM
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    well considering how engines work all of the pistons are getting fuel before the others...
    Thatbassguy and WV_Taco like this.
  13. Jun 24, 2022 at 11:11 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    3.5 makes more horsepower, but the 3rd gen weighs 500 lbs more. Negates any power increase.
    Plenty of 3.5 motors have been failing recently. As they get higher up in mileage, there will be much more failures. Enjoy your truck and don't get so triggered. The 4.0 is proven reliable. 3.5, not so much.
    IEsurfer, AxisCab and fourfourone like this.
  14. Jun 24, 2022 at 11:12 AM
    fourfourone
    Oh boy. Here come all the triggered 3rd genners!
  15. Jun 24, 2022 at 11:21 AM
    #35
    WV_Taco
    WV_Taco Well-Known Member
    2022 Tacoma TRD Off-Road
    Exactly my thought.
    With the engine options in the Tacoma's, there shouldn't be two cylinders getting fuel at the same time. I would take it to a different mechanic.
  16. Jun 24, 2022 at 11:26 AM
    #36
    Gen3TacomaOBX
    S
    OP, I'm sorry this is happening to you. We definitely want to hear what error codes the dealer is pulling.
    I apologize for the few 2nd gen whining bitches that show up in every troubleshooting thread. Apparently they're attempting to compensate for something they're lacking. Dick size, horsepower, dated interior.. we're not sure exactly why they do it.
  17. Jun 24, 2022 at 11:40 AM
    #37
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Fuel delivery timing has nothing at all to do with pistons and valves. Is this a Toyota tech who told you this?
    Thatbassguy and Junkhead like this.
  18. Jun 24, 2022 at 11:46 AM
    #38
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    If its under warranty then let them fix it and decide later if you want to trade it in. But obtaining the code and finding out what they are doing to the motor before the work is a better idea.
  19. Jun 24, 2022 at 12:04 PM
    #39
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    4.sl0w owners crashing the thread, pleb-spec 3rd gen owners thumping their chests about lack of interior chrome, I haven't seen a 3rd Gen Friday thread like this in years hahaha
    OP, that sounds a little suspicious. You can't get a true diagnosis from the online truck forum, but I'd suggest having someone else look at it. Even if it's a trusted mechanic and you eat the diag fee, or another dealership. Fueling issue requiring a teardown seems sketchy.
  20. Jun 24, 2022 at 12:11 PM
    #40
    turbosix
    dfw
    2024 TRD Pro
    OP be like
    Junkhead, AxisCab and JSB10 like this.
