2018 pre-collision disable?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kurpak, Nov 27, 2017.
  1. Nov 27, 2017 at 7:26 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    This is exactly why I don’t want anything with this stuff. My better half drives a Toyota for work and they hate the way tss operates. The system has nearly caused accidents by slamming on the brakes doing 70 on the interstate, and for non existent threats caused by a shadow.
  2. Nov 27, 2017 at 7:30 PM
    bottlecap
    bottlecap Well-Known Member
    Eric
    Philly/SJ
    2017 DCSB TRD OR
    My old work car was a Prius V. That damn thing would randomly beep and start braking hard because of rain, curves, reflections off shiny tankers, and UFO's (probably).
    More than once, I thought it was out to get me and it certainly didn't make friends with the people behind me.
    Riding Dirty[QUOTED] likes this.
  3. Nov 27, 2017 at 7:31 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    I just love threads like this -- the value of my 17 is going up with these posters -- if it stays high and gets higher with all of the no-experience drivers of TSS -- I will sell to one of these people and get me one with all of the safety stuff. BTW -- we have had a 15 Subaru Outback ( with the "Eyesight system) for almost 3 years --and both wife and I feel it has been some of the best money we have ever spent on an option.
    All of you inexperienced/no-experience TSS drivers -- keep on bad mouthing it -- my 17 goes up in value--thank you.
    Never a false alarm in 32K miles, system did shut itself down once when the inside of the car fogged up -once
    TUDBALL likes this.
  4. Nov 27, 2017 at 7:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Simple question: Have you driven a Toyota vehicle with this system? Another: Do you know and understand the parameters which activate the braking system?
    I have and I do understand the system. Tailgating at 80 mph won't activate the brakes bro. If the guy you are drafting (stupid unless wearing a helmet and a five point harness) smacks the car in front of him though, THEN your braking system will activate, about 50X faster than your slow foot. It will allow you to steer also. Finally, when your brain catches up and your slow foot finally gets the signal to push the brake, hopefully you won't get hit.
    Now, cruise control won't work when you are only a few feet behind someone but hey, it sounds like you are a race car driver anyway and they don't do cruise. Good luck man and remember, many of the vehicles out there are already running a version of this safety system, and chances are good that the guy in front and behind you sometime during your commute you are depending on their system! Their computer is deciding when you brake haha.
  5. Nov 27, 2017 at 7:41 PM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    my question is what will pre-collision do on the manual optioned trucks?
  6. Nov 27, 2017 at 7:43 PM
    markmizzou
    Mark
    Missouri
    UHHHH -- I would bet it will try to stop you as it is designed to do!!??
    Riding Dirty likes this.
  7. Nov 27, 2017 at 7:44 PM
    Lvstrng90
    Lvstrng90 Well-Known Member
    2018 Tacoma TRD OF 4dr 4x4 Mag Gry Met
    I’ve been using PCS and it’s pretty nice. Mine doesn’t break the truck if someone cuts me off, it has only braked while using cruise control. It keeps a solid distant between you and whoever is in front of you. I’m not sure if that’s how it is suppose to work but that is what has been happening.
    I’d turn it off if I was driving on ice. But that’s about it.
  8. Nov 27, 2017 at 7:45 PM
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    at the risk of stalling the truck? seems kinda backwards
  9. Nov 27, 2017 at 7:50 PM
    Tacos4ever15
    Tacos4ever15 Well-Known Member
    2015 Pyrite Mica Tacoma TRD Off-road 4x4
    I drive also, you are 100% correct, yes it’s scary as shit when it automatically brakes on you, it’s bs for sure.
    Kinsail48[QUOTED] likes this.
  10. Nov 27, 2017 at 7:58 PM
    markmizzou
    Mark
    Missouri
    if it is like the Subaru system -- use it and you will see that you can set your following distance to one of 4 settings. Also the setting you choose will get a bit longer the faster you go. as far as the emergency braking -- it will only do that if it senses you have NOT braked and a collision will happen -- if you so much as touch the brake, it feels you are in control. When using the ACC (cruise) it will brake as well to slow you down to maintain your chosen following distance. Someone cuts in between (they always do) -- it will slow down again to keep your chosen distance.
    Best advice I can give -- read your manual and get used to the "system" -- I bet you will like it!!
    Also -- look at the book -- I'll bet you it says NOT to use the adaptive Cruise when traction conditions are bad -- Our Subaru book warns the user of this! this is common sense!
  11. Nov 27, 2017 at 8:02 PM
    markmizzou
    Mark
    Missouri
    Until it saves your ass from a collision -- then lets see if you call it BS. A driver turned off in front of my wife --then changed their mind and turned back out -- saved her from a 30mph wreck --NOT BS-- I call that GS (good shit)
    TUDBALL likes this.
  12. Nov 27, 2017 at 8:05 PM
    markmizzou
    Mark
    Missouri
    You don't think a company as big as Toyota can't figure that out before putting it out to the buying public!!?? whatever!!
  13. Nov 27, 2017 at 8:25 PM
    countryttcuzzin
    countryttcuzzin Member
    Darrell
    Exlax City, centeral Kansas
    2007 Tacoma TRO Sport crew cab V6 auto
    Westtin Running boards+ bull bar and Lights,Bilstein Shocks front raised 1 1/2 inchs,Kelly Safari TSR tl 265/70R17 tires, Spyderauto compression headlights and LED tail lights.K+N CAI,Flowmaster CAT/B exhaust, Wood Grain Dash and doors trim,ATC Tonneau cover
    All of this high tech crap is brought to you by the higher educated numb nuts that can't walk and talk at the same time. Train people to drive and know the rules of the road. Turn off all cell phones and tablets and pay attention to what you are doing when driving. This from a driver with just short of 4,000,000 miles under my belt.
    Kinsail48, MrBrooks and Tacos4ever15 like this.
  14. Nov 27, 2017 at 8:37 PM
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    I don't want this garbage. I don't want to learn to understand this garbage. I hate the idea of a machine making driving decisions for me at 55mph.
    I live in Arizona and the companies out here have been beta testing self driving cars for data collection and RandD for companies like Chevy, Volvo, and uber. It's only a matter of time before self driving cars slowly get phased in. Wouldn't be surprised eventually they become mandated.
    Hearing the people clamouring for gun control. Give it 20 years and it will be the same people trying to mandate self driving cars due to auto fatality numbers in the name of life saftey.
    Burns, 02Duck and Tango Bravo like this.
  15. Nov 27, 2017 at 8:41 PM
    #35
    markmizzou
    Mark
    Missouri
    You are correct -- in a perfect world-- this would happen -- but you and I know this is not the case today. The safety stuff is to protect all of the good drivers from the texting and drivers out there as well as protect them from themselves
    Ruggybuggy likes this.
  16. Nov 27, 2017 at 9:54 PM
    #36
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    to the haters... not everyone wants nanny's half-driving their cars for them.
    And don't blame Toyota... I'm pretty sure all this safety BS is federally mandated.
    Jonathan Ward's Icon stuff looks better and better all the time... now just to win the lottery!
  17. Nov 27, 2017 at 10:17 PM
    #37
    tow-coma
    tow-coma Well-Known Member
    Toyota will soon be out of business if the collision system EVER locks the brakes while you are moving.
    Also, the vehicle has lane departure ALERT, not lane departure ASSIST
    Gyrkin likes this.
  18. Nov 28, 2017 at 10:41 AM
    #38
    Tacos4ever15
    Not saying it doesn’t help in certain situations, however, say your going around a curve to the left, there’s a turning lane to go right, your vehicle still sees that car and hits the brakes even though Your lane is wide open, that’s where I call it bs, not good.
  19. Nov 28, 2017 at 5:27 PM
    #39
    markmizzou
    Mark
    Missouri
    Has your vehicle done this? Or this is just a scenario you made up in your mind?
    The Subaru's
    system (closely related to Toyota's -- I would bet as Toyota owns 18% of Subaru) has been very good about differentiating between cars in your lane and those not in your lane, even when going around curves. I have no experience with driving the new Toyotas with TSS -- but there is 3 years advances in tech between our 15 and the new 18's. Our outback tracks cars ahead very well going around curves. It is easy to tell as it beeps whenever it picks up the car ahead and also when it loses the car ahead. The "eyesight system works very well!
  20. Nov 28, 2017 at 5:58 PM
    #40
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    I'm reading all of this and all I can think of is when anti-locks were introduced, the same arguments. My foot is better than the anti-locks blah, blah, now its everywhere and no ones complaining now. I used to say the same, This from an old man that grew up driving a camaro on two ply summer only tires in the dead of winter. Did a few unwanted donuts on the way to school. Scares the bejesus out of ya and luck of the draw. ABS has saved my ass many time as well once I learned proper use.
    Once you know how to use any new system to your benefit, it gets better. When the system come out study it and see if it's for you.
    Just sayin
    Me, I'm sticking with my 13 cause ya know 3rd gen... Like the looks of 3g, just can't get over the power bands.
