2018 Tacoma Header Rail Gap Seal Issues
Discussion in 'Toyota Trucks & SUVs' started by Joshuapolok, Dec 4, 2018.
  1. Dec 4, 2018 at 7:30 AM
    Joshuapolok
    Joshuapolok [OP] New Member
    I have been having the worst time trying to weather proof my Leer topper due to the header rail gaps where the side rail meets the header rail. So far I have removed the header rail, put butyl tape underneath it, and filled the gaps with butyl tape. This did stop a lot of water from getting in, but has not completely stopped it from creeping in. After some heavy research on the topic I have found a couple of threads about people filling the gap with Part# 1118059 REV A. I think this foam comes in a kit, but I was wondering if anyone knows where to find this part. Below is the foam ends that match the part number. If anyone has a better idea of non invasive ways to fill the gap (not great stuff or other products that cannot be removed) i'm open to ideas. Thanks!
  2. Dec 4, 2018 at 7:41 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
  3. Dec 4, 2018 at 9:38 AM
    Joshuapolok
    @Rujack that's exactly what I don't want to do. This should fix the leak, but this product is not long lasting nor removable. If no elegant solution presents itself I can resort to this, but I'm trying to go with a better solution. Thanks.
  4. Dec 4, 2018 at 9:46 AM
    Rujack
    :thumbsup:
  5. Dec 4, 2018 at 9:50 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Retrax has those pads with their kits. You could see on getting some or making your own.
    A bead of silicone is what a lot of shops do when they install shells. That should be removable if needed in the future since not sticking to anything porous.
