2018 tacoma in the shop bad head problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by connell, Jan 10, 2020.
  1. Sep 3, 2022 at 10:46 PM
    #61
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I hope for the best.
  2. Sep 9, 2022 at 6:06 PM
    #62
    Gator_Tacoma
    Gator_Tacoma New Member
    Andre
    2019 Cement Tacoma
    I just got the truck back and it seems to be running fine. I plan on letting the components break in for 1200 miles or so. No rough idling or weird noises so far.
    Canadian Caber likes this.
  3. Sep 10, 2022 at 4:30 AM
    #63
    Olddawg
    Olddawg Well-Known Member
    2017 Taco v6
    I can say the same for me as mine came back a week ago. Only issue was one connector to the coil was loose and I simply pushed it back on. Hope all goes well for you!
  4. Sep 10, 2022 at 4:33 AM
    #64
    Gator_Tacoma
    Andre
    2019 Cement Tacoma
    Actually that reminds me...the windshield washer fluid hose was disconnected and I had to put that back. :)
  5. Sep 10, 2022 at 10:48 AM
    #65
    Olddawg
    2017 Taco v6
    Mentioned only due to everything they took out that was the only item not fully re-installed. Easy fix!
  6. Dec 9, 2022 at 11:49 AM
    #66
    pdeinc
    pdeinc Well-Known Member
    Ken
    2019 TRD 4x4 Sport
    ARE Z topper, Roadmaster baseplate, Remco DS disconnect
    Mine is also having head replaced for #1 burnt valve. 2019, 54k miles, TRD Sport 4x4. Got pictures of injectors, very dirty. Tech recommends having a pressure fuel injector cleaning process done @ 30k or sooner.
  7. Dec 9, 2022 at 11:59 AM
    #67
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    I've got about 126k on my '17 no issues...having to replace my rack but I'm thinking that was due to a hard offroad exit I made one day. even still it held up for a few months after. I've seen some other posts regarding bad valves but those are rare and usually before 25k or so...I think I'm in the clear at 126k, fuel pump seems fine too *shrug. only issue I'm having...I have the ultra white paint or whatever the hell it's called and it's peeling bad on the rear door around the glass...and of course yota isn't addressing/covering that so F me. aside from that if you're running over 100k you're probably in the clear...guess we'll see
    turbosnail and pdeinc like this.
