2018 wiring harness for brake controller
Discussion in 'Towing' started by Bretsuaz48, Jan 10, 2018.
  1. Jan 10, 2018 at 3:12 PM
    Bretsuaz48
    Bretsuaz48 [OP] Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    We traded in our 16 and now have an 18. For the 16 we purchased a harness that was just plug and play. Plug one end in to truck and the other end in to the brake controller. We couldn't find the end of the harness under the dash. Took it to the dealership and at first they couldn't find it, but then eventually found it. Now they are telling us that the plug on the harness has changed for 2018 and the adapter we have will not work. Can anyone confirm that the plug from the 16 and the plug on the 18 are different or not?
  2. Jan 17, 2018 at 7:57 AM
    Smcbundy
    Smcbundy Member
    2018 Inferno Tacoma TRD Sport
    All of my other new Trucks and SUV's (Toyota & Ford) have come with a wiring harness with open wire ends to splice into whatever controller wiring you need. My 2018 is the first one to not come with a harness. A couple websites sell the harnesses and claim that they will fit 2016-2018, but I don't know if they are being truthful.
    https://www.tacomaworld.com/threads/2018-wiring-harness-for-brake-controller.528103/
  3. Jan 23, 2018 at 2:34 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    shakerhood likes this.
  4. Jan 23, 2018 at 2:51 PM
    Smcbundy
    Smcbundy Member
    Interesting...Since I just ordered a new brake controller and harness from etrailer this morning, and the CSR said the 3017-P was the correct one for my 2018. I guess we'll find out this weekend!
  5. Jan 23, 2018 at 4:42 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Yeah the plug on the truck side looks exactly the same. Let us know if it works!
  6. Jan 24, 2018 at 9:20 AM
    Smcbundy
    Smcbundy Member
    Haha...the response from etrailer on why there are two parts:
    "Technically they both fit! The difference is that the # 3031-P is replacing the # 3017-P as it was designed with an extra ground wire which allows the harness to function better."
    So...um...why wouldn't you recommend the part that allows the harness to function better? Why would the old part even be linked to the truck anymore?
  7. Jan 24, 2018 at 5:56 PM
    g8rnbft
    g8rnbft Member
    Blair
    2009 Gray Tacoma TRD, leather, sunroof, Bluetooth, 2" lift
    New member here - I just got a 2009 that has the towing package. Owners manual says the brake controller connector is under dash by the hood release - but I haven't been able to find it. Will try again on my back with flashlite - but meantime - does this location match up what others have found??
  8. Jan 24, 2018 at 6:44 PM
    Smcbundy
    Smcbundy Member
    Yes, that general location matches the many other Toyota’s I’ve owned. It is back in the corner. Follow the e-brake up, and it’s hiding up behind it. In fact, it’s easier to get to if the e-brake is disengaged.
  9. Jan 24, 2018 at 6:46 PM
    spye3141
    spye3141 Member
    2017 Tacoma TRD Sport
    Rack-it pipe rack
    I recently bought a Tekonsha P3 and the 3017-P harness. About a week after it was installed, the ground wire on the truck side of the harness melted and eventually led to a $5000 repair that Horizon Global (owner of Tekonsha) covered for me. They sent me their new harness with extra ground wire, which I have not plugged in and tried yet for fear of the part messing up my truck again. That said, be careful about installing the 3017-p in your truck! Tekonsha said they found a short in the P3, but I have yet to be convinced that solves the problem. I have the 2017 TRD sport with the towing package. Anyone else have this happen to them?
  10. Jan 24, 2018 at 6:56 PM
    Smcbundy
    Smcbundy Member
  11. Jan 24, 2018 at 7:00 PM
    spye3141
    spye3141 Member
    Rack-it pipe rack
    No worries, Smcbundy. I hope it goes well for you! I t was a shocker to me, since Tekonsha and Toyota are both so reputable. Still have not gotten a real answer from either of them...
  12. Mar 25, 2018 at 7:57 AM
    skiscience
    skiscience Member
    Erik
    Thanks for the heads up, I was about to install a 3017-P. I am also ordering the 3031-P to be safe.
    OnHartung'sRoad likes this.
  13. Jan 31, 2019 at 5:49 PM
    Denteen
    Denteen Well-Known Member
    D
    Central valley CA
    2018 TRD Sport 4x4 DCSB
    TRD Pro suspension-2nd Gen Frontrunner bed rack Tacowiede radio knobs! Best mod everrrr!!! DSM mount Wheel swap to OR’s. For now... Gone-2005 DC Icon Stage 2 with Rear Resis;ICON 3 leaf AAL installed! Gone-2001 xcab 4x4 4cyl 5spd. Best truck ever...
