2019 2.7 regear options
Discussion in '4 Cylinder' started by 1776Taco, Oct 21, 2020.
  1. Oct 22, 2020 at 12:56 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Damn i wish i could retrofit that in my truck but the shifter and gauge cluster wouldnt work.
  2. Oct 22, 2020 at 1:05 PM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    So the "official" document is wrong, eh? HOW DO WE KNOW WHO TO TRUST THESE DAYS.
  3. Oct 22, 2020 at 1:05 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    The other issue is that the ECU probably needs to be swapped. But the new ECU might not be a direct swap because of dual VVT in the newer 2.7L. So you'd have to answer that question. But mechanical, it's probably a pretty easy swap.
  4. Oct 22, 2020 at 1:06 PM
    jowybyo
    Joe
    Baltimore, MD
    Do you have a link to the official document?
  5. Oct 22, 2020 at 1:08 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    What are 2nd gen with the RA60F ratios?
  6. Oct 22, 2020 at 1:12 PM
    jowybyo
    Joe
    Baltimore, MD
    RA60F (Tacoma 4wd 6 speed)
    4.171
    2.190
    1.488
    1.193
    1.000
    0.849
    Key-Rei[QUOTED] likes this.
  7. Oct 22, 2020 at 1:12 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Sigh, Maybe one day when I’m bored and have a lot of money I’ll attempt to figure it out
  8. Oct 22, 2020 at 1:15 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Toyota has a lower gear ratio of 5.71's but they are weak.
    I have the 3RZ motor, auto trans and currently run 285-75-16's. At 70mph on the freeway, I turn 2750 rpm's with 5.29's.
  9. Oct 22, 2020 at 4:17 PM
    NewMexiMan
    2016 SR 5 Speed
    This document.
  10. Oct 22, 2020 at 4:22 PM
    jowybyo
    Joe
    Baltimore, MD
    Yup I’m certain that is wrong. I know for certain because I just put a 2016 5MT in my truck and I checked the ratios in the transmission before I installed it.
  11. Oct 22, 2020 at 4:34 PM
    NewMexiMan
    2016 SR 5 Speed
    Thank you very much. I've been looking to hear from someone who has physically examined the R156F. Do you know if the differential ratio listed in that document is incorrect as well? Is it actually 4.3, like the 6spd manuals?
  12. Oct 22, 2020 at 4:45 PM
    jowybyo
    Joe
    Baltimore, MD
    That I don’t know. But I’m guessing it has a taller rear gear than the 6MT or the 6AT. Both of those transmissions have pretty tall overdrive ratios.
  13. Oct 23, 2020 at 3:40 PM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    Looking into regear or urd supercharger for my truck.. mines a MT.
    Ritchie likes this.
  14. Oct 27, 2020 at 6:38 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    You ever try going 60 in reverse? Its such a pain when you add 35s.
  15. Oct 27, 2020 at 6:42 AM
    #35
    jowybyo
    Joe
    Baltimore, MD
    Yup, once.
    whatstcp and Wixo[QUOTED] like this.
  16. Nov 3, 2020 at 8:28 PM
    #36
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    I would re-gear first. It solves a lot of problems while introducing few (if any). Supercharging the engine is just putting a big bandaid on the issue and then you have to worry about the kit lasting as long as the motor (or worse, reducing the life of the motor).
    Also, while re-gearing, you can throw in a locker or LSD or both (FR-S/86 LSD Front and ARB AirLocker Rear is a good combo, I've heard).
    jeffmansion[QUOTED] likes this.
  17. Nov 3, 2020 at 8:34 PM
    #37
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Educate me, but I’ve never heard of installing a limited slip diff up front. My understanding is they usually put the LSD in the rear, and a locker up front so when you are unlocked, your steering is not affected when you are driving around town. An LSD up front might do very weird things on wet pavement etc.
    I dunno. Maybe I’m wrong.
  18. Nov 3, 2020 at 8:38 PM
    #38
    Snaeper
    Martin
    Phoenix, AZ
    Well, it was recommended to me awhile back by another Arizona guy here on the forums. I might be mis-remembering it. I believe it shouldn't engage when you're in 2WD though, since there's no power being sent, but I could be wrong.
    I'm gonna eat crow on this until I can find the post.
    Stocklocker[QUOTED] likes this.
  19. Nov 3, 2020 at 9:03 PM
    #39
    Stocklocker
    17TRDORDCSBAT
    Ahah. I had not thought of that. I suppose you are right.
    I know the old Nissan Patrols that are so popular in Australia are typically LSD rear and locked front, but that’s probably because the Nissan LSD has a reputation for being indestructible and really good at what it does.
  20. Nov 4, 2020 at 8:16 AM
    #40
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    my vote is for the blower and an upgraded clutch. The stock one wont last long
