2019 Brake Controller Hookup
Discussion in 'Towing' started by Jack61, Aug 2, 2019.
  1. Aug 2, 2019 at 4:20 PM
    Jack61
    Jack61 [OP] New Member
    2019 Tacoma TRD Sport
    Just traded a 2012 Tacoma, with a factory furnished pigtail connected to a P2 brake controller, based on the Generic Wiring Diagram from Prodigy. The 2012 had a connection receptacle behind the driver's side kick panel. The new 2019, with the towing package, also has what looks like brake controller pigtail receptacle behind the driver's side kick panel, but the salesman claims that the 2019 towing option does not include a pigtail. What am I missing here?
  2. Aug 2, 2019 at 4:55 PM
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    He might be referring to the "pigtail" wire to the controller. The connector for that wire is behind the kick panel.
  3. Aug 3, 2019 at 10:02 AM
    Jack61
    oly61: Thank you for your response. My problem was my living in the past. When I bought the 2012 Tacoma, a typical hookup was to splice wires from 2 pigtails. Toyota included a 1-plug wiring harness with 5 wires attached to the plug, which they referred to at the time as a pigtail. The plug for the Toyota pigtail fit into a receptacle behind the driver's side kick panel. Four of these wires I then spliced to the corresponding 4 wires on the controller pigtail. When I picked up the 2019 yesterday, I was surprised not only that no Toyota pigtail came with the towing package, but also that no one at the dealership understood what the hell I was talking about.
    I think I'm back on the straight and narrow. Just bought a Tekonsha Custom Wiring Adapter, which should do the trick.
    oly51 likes this.
  4. Sep 4, 2019 at 7:14 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    You should be good to go. Tekonsha makes plug and play pigtails for their controllers that fit Toyota, as well as most other vehicles. No splicing necessary.
  5. Sep 5, 2019 at 5:59 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I just swapped over my Prodigy P2 from my 1st gen to my new 2019. I used an adapter pigtail form ETrailer for like $11. Was a 10 minute install job.
  6. Sep 29, 2019 at 10:38 AM
    planohog
    planohog Well-Known Member
    Seabrook, Texas
    2019 taco 4X4 v6 TRD OR
    3&1 lift, tire,wheels, bakflip G2. Front Cam,A/C,rock leds,internal leds.
