2019 no tpms!
Discussion in 'Canada' started by eric801, Apr 23, 2019.
  1. Jan 17, 2020 at 9:02 AM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    The TPMS module is installed in the roof. I doubt they would install it if it is not used. I looked into it because I wanted to export my truck to the USA, but I have not so far found a way to retrofit TPMS.
  2. Dec 21, 2020 at 9:02 AM
    icebane
    icebane Well-Known Member
    Ottawa, ON
    I just picked up my Canadian 2021 TRD Sport MT. No TPMS system. I think I have the wiring in the back of where the button should be, but no button, just a plastic cover.
    I like TPMS and would be currious as to what would be involved and how much it would cost to add this.
  3. Dec 21, 2020 at 6:51 PM
    mrCanoehead
    Ottawa
    As far as I could tell, the controller is normally installed in the roof above the driver's head. You'd have to get a controller out of a wrecking yard and take the headliner down to install it. The controller probably has a CANbus connection, so you'd be fishing a cable under the dash somewhere, there's probably an empty socket if you go down there with a flashlight.
    It might just work, but it probably won't.
    I had the bright idea to sell my truck down to the US market and make a profit, sadly it's not possible to import to the states without TPMS.
    You can buy aftermarket TPMS systems that plug into the lighter socket.
    TPMS is pretty much an American thing, not required in Canada as far as I know. It's pretty easy to feel when a tire is low on air.
  4. Dec 22, 2020 at 6:09 AM
    icebane
    Ottawa, ON
    Thank you for sharing this information. I'll see if I can get a part number for this module and then maybe I can get lucky at my junk yard.
