2019 OR Firewall pass through
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LTG4087, Aug 2, 2020.
  1. Aug 2, 2020 at 8:33 AM
    LTG4087
    LTG4087 [OP] Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Going to install Ham radio in my 2019 OR and need to get antenna & power lines run through the firewall. There seems to be a entry gramett on the passenger side the could work. Before I go poking through this, does anyone know where it comes out in the cab?firewall1.jpg
  2. Aug 2, 2020 at 8:35 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Under the dash on the passenger side. Pull the carpet up and locate it.
    shakerhood likes this.
  3. Aug 2, 2020 at 8:38 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I went through a similar location on the driver's side. I poked a small hole with a utility knife and pushed the wires through. Once I got a few inches through, it was easy to locate under the dash. It came through above the carpet.
    Edit: this is on a 4runner. I'm not sure where the wiring harness passes through on a Taco, but I imagine it's similar.
  4. Aug 2, 2020 at 8:58 AM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    okay, thanks for the help. I thought it might be behind the glove box which would be more of a PITA. I'll look around under the carpet. I want to keep the power cable a little bit separated from the antenna to avoid interference and since there's two nipples this might work out.
    Thatbassguy likes this.
  5. Aug 2, 2020 at 9:45 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    There’s another one on the driver side that’s easier to access. Don’t try to use the little pokey grommet, it’s a pain. Just cut a small hole in the rubber and push the cables through. On the driver side, it comes out just below the steering column near the fuse box, easy to work with.
  6. Aug 2, 2020 at 9:48 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Use the 3/4” grommet up and to the right. Way easier. There is carpet behind it, just poke a hole and run your wires in via coat hanger or something. The 3/4” grommet can always be replaced should you need to. That other larger main harness grommet for all intents and purposes cannot.
    there is a similar 3/4” grommet on driver side near the brake booster region. It’s actually easier since there isn’t a bunch of ECU equipment behind it. You can stick your head in the driver foot well and actually see your wires coming through.
    tacoma_ca likes this.
  7. Aug 2, 2020 at 9:53 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I used the lower "nipple" because it seemed it was going to be easier to access the wires inside the cab. You'll need to remove the passenger side kick panel to get to them . . .
  8. Aug 2, 2020 at 10:02 AM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    I've got too much stuff on the drivers side which I'd need to remove to work with that entry point plus everything will be terminating on the passenger side so it just make sense to me to go through there.
  9. Aug 2, 2020 at 11:15 AM
    jruiz555
    jruiz555 Well-Known Member
    i missed the whole acronyms or something, what does OR stand for? i been living inside this whole year.
  10. Aug 2, 2020 at 11:24 AM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Off road.
    There are service spots in the harness to run wires though, they're the nipples people are talking about. They are very much there on purpose.
    It's in your best interest to get some black butyl and seal up where you poked holes. Pull wire back a little, goober on the butyl, very slowly pull the wire through a bit extra, then push to settle it where it should really be. That's the easiest, fastest, most reliable way to seal it up. The butyl remains sticky and pliable for a very, very long time. Ever pull a door foil / moisture barrier on a 25 year old car and get that black goop everywhere? Butyl. It's magic. It can also be another version of car herpes and track everywhere, so be careful. Strong isopropyl alcohol will clean it up. Strong, like 92%.
    Interbeing likes this.
  11. Aug 3, 2020 at 11:55 AM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Thanks, That's exactly where it comes out. Under the kick panel which is perfect since I will then continue to route the cable under the front passenger seat where the radio body will sit. I ran a coat hanger through to see how it will work and although it's pretty tight I think I can get the RG58 coax through there but not with a connector on the end. I'll have to run it through as a bare cable and then install the PL259 connector once it's through. Kind of a PITA soldering on the truck floor but surely doable. I'll run the power cable through the other nipple and I guess I'll need to cut the inline fuses off and then re splice them back on.
    DES2009[QUOTED] likes this.
