2019 Tacoma limited disappointment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chipofsc, Apr 28, 2019.
  1. Apr 28, 2019 at 4:14 PM
    Chipofsc
    Chipofsc [OP] Active Member
    2019 limited
    i have been driving a 2005 Trunda since new and received very good service. When time come to replace it I decided to go with the Tacoma because I didn’t have a need for a large truck anymore. Kids were gone and I sold my landscape business so I wanted a smaller truck. Easier to park. I wanted a limited model and they are hard to find. I found a used one so I took to for a test drive. It was a 2017. Drove find ams had a smooth ride. Very quiet inside. My local dealer received a 2019 limited one in silver with black leather. I made an offer and they took it. Basically I bought it without test driving it. Two things I don’t like. The cruse control will drop the transmission down two gears and run the RPMs up to 4500 when it needs to speed up. I can maintain speed using my foot without racing the engine so hard.
    Also the transmission likes to get in high gear too quickly. Running. 45 it’s in six gear and when you accelerate it Boggs until the transmission can down shift enough gears to speed up. If I drive it in sport mode it’s much better but you have to hand shift if you go past fourth gear. I shouldn’t have to drive it like this. I have a Lexus LS 350 that is smooth as glass. Toyota has the ability to make it shift properly but they are saying that’s the way it is. I love Toyota cars but very disappointed in the new Tacoma.
  2. Apr 28, 2019 at 4:21 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Apr 28, 2019 at 4:22 PM
    erikarthur
    erikarthur Well-Known Member
    Erik
    WI
    I does take a little while to learn but the transmission still goes to 6th way too easily imo. Mine isn't too bad after 13K but it's pretty flat around here in MN. I have a 2018 Limited. Another option is to just drive it in S5 most of the time or look at something like OVTune or ShiftSensePro. The ECT button also seems to make the transmission shift less sucky as well.
  4. Apr 28, 2019 at 4:24 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Hope you start to like it and can enjoy it for the long term.
    In before this turns into a dumpster fire!
  5. Apr 28, 2019 at 4:25 PM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    It’s gets better IMO ... mine was the same til 2-3k miles . I also use S4-S5 with ECT on sometimes too .
    StayinStock likes this.
  6. Apr 28, 2019 at 4:27 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    As in 2k to 5k miles, it will get better but if you think it will be snappy, it won't, and yes 6th by the time your doing 35
    StayinStock and Comato$e like this.
  7. Apr 28, 2019 at 4:28 PM
    epluribusunom
    epluribusunom Well-Known Member
    Luke
    '16 White SR5 4x4
    Just get OVTune and be done with it. Best investment/mod I've done to my truck hands down.
    bigmw, SandyTaco4x4, TFly and 11 others like this.
  8. Apr 28, 2019 at 4:29 PM
    Guntaco
    Guntaco Well-Known Member
    2017 TRD Offroad
    Just push the ETC button and it’ll help a lot with the transmission sucking.
    TnShooter and mgmdclb like this.
  9. Apr 28, 2019 at 4:29 PM
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Like the other guys said, give it some time. It’ll either grow on you or you’ll hate it even more.
    Enjoy the truck :D:D
    Edit: I do really like mine now, the cruise is always like that on mine still. That’s where the power is on these motors, gotta wind em right up and they will pull.
    Shveet likes this.
  10. Apr 28, 2019 at 4:29 PM
    Guntaco
    2017 TRD Offroad
    I had my Tacoma for 15K miles and it never stopped being dumb with shifting.
  11. Apr 28, 2019 at 4:30 PM
    docems
    docems New Member
    Art
    2019 white 4 door limited short bed
    None yet..
    My 2019 limited was the same but after 1200 miles it is getting much better
    Sgt.Tee and StayinStock like this.
  12. Apr 28, 2019 at 4:32 PM
    Comato$e
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Maybe you need the TSB ? I have a early 18’ an it definitely helped.
  13. Apr 28, 2019 at 4:33 PM
    jerkwithkeyboard
    had mine from 2016, and had 2 ECU updates done, but yours is a 2017 and i think one was in 2018. much better after TSB. Perfect ? no, livable ? yes
    Lucifer1 likes this.
  14. Apr 28, 2019 at 4:34 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    What he said.^^^
    I drive in s5 all the time and it drives alot better.
    Give it some time, it takes some getting use to.
    Kilokato and GillyLink like this.
  15. Apr 28, 2019 at 4:35 PM
    Shellshock
    Iowa
    Time for 4.88s :spending:
  16. Apr 28, 2019 at 4:35 PM
    cricketfire46
    cricketfire46 If it ain't broke, I can change that TTC#231
    Daniel
    Gilmer TX
    2019 DCLB OR
    My transmission got better at about 1500 miles. It is still a little quirky but either I got used to it or it got better.
    Sgt.Tee likes this.
  17. Apr 28, 2019 at 4:36 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    You know what to do
  18. Apr 28, 2019 at 4:39 PM
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    4.88s + OVtune= :)
    jholc21, xxTacocaTxx and n6vmo like this.
  19. Apr 28, 2019 at 4:43 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    It gets better after the learning phase is over. I love my 16 limited 4x4 but purchased the OVTune last Friday because I want to a little more performance out of the truck.
    n6vmo likes this.
  20. Apr 28, 2019 at 4:44 PM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    OK - Now What?
    GillyLink likes this.
