2019 tacoma SR engine question
Discussion in '3rd Gen. Tacomas (2016+)' started by kiki111, Jun 12, 2019.
  1. Jun 12, 2019 at 2:46 AM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    florida
    Tacoma 2019 SR
    Bought myself a 2019 Toyota Tacoma Sr model... notice when engine is running there's a very low ticking noise? is this normal? Of course you can only hear it when you start the car or the car is on idle and there's very little noise! Don't ever recall that on my 2015 taco.
  2. Jun 12, 2019 at 3:07 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    2.7 or 3.5?
  3. Jun 12, 2019 at 3:07 AM
    kiki111
    florida
    Tacoma 2019 SR
    oops....2.7 SR 2019
  4. Jun 12, 2019 at 3:51 AM
    Claudiomartinof
    Just traded a 2.7 for a 3.5
    I had the 2.7 for three years.. i am not a mechanic... I’ve learned that all engines make weird noises... I would check oil and keep going...
    Your 2.7 is bulletproof... I would not worry that much... but go to the dealer if you feel something is wrong...
    CusterFan and BassAckwards like this.
  5. Jun 12, 2019 at 7:41 AM
    Tacomike18
    Tacomike18 Well-Known Member
    2018 toyota tacoma sr 2.7 access cab utility package 2wd MGM
    Yes it ticks a little.
    CusterFan and Taco_Coma like this.
  6. Jun 12, 2019 at 7:43 AM
    kiki111
    florida
    Tacoma 2019 SR
    so its normal
    CusterFan likes this.
  7. Jun 12, 2019 at 7:47 AM
    Tacomike18
    Yes it is. So is 500 to 600 rpm rumble.
  8. Jun 12, 2019 at 8:34 AM
    kiki111
    florida
    Tacoma 2019 SR
    i have no or not noticed a 500/600 rpm rumble
  9. Jun 13, 2019 at 1:43 PM
    kiki111
    florida
    Tacoma 2019 SR
    so I was reading online... so is the knocking I hear some times louder is the fuel injectors cleaning themselves?
  10. Jun 13, 2019 at 1:46 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Likely the injectors firing
  11. Jun 13, 2019 at 2:35 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the Forum !
    The sound you are referring to is the heartbeat of the engine. Perfectly normal. As long as it has a constant beat to it, don't worry. :thumbsup:
  12. Jun 13, 2019 at 2:37 PM
    BassAckwards
    Robert
    09 2.7L PreRunner
    If youre hearing what sounds like a sewing machine ticking away, thats completely normal, nothing to worry about
  13. Jun 17, 2019 at 8:01 AM
    kiki111
    florida
    Tacoma 2019 SR
    toke it to dealer...says sound is normal...comes on after i start the engine like 2 min after....was told it was the vacuum pump....and it is normal sound..... BTW...NO WARNING LIGHTS OR CHECK ENGINE COMES ON!!!! gonna upload a youtube video and link it.....will post when done...
    Paul631 likes this.
  14. Jun 17, 2019 at 8:11 AM
    kiki111
    florida
    Tacoma 2019 SR
    view youtube video.....
    https://youtu.be/HDShSIiXH6Q
    "NOISE" comes on 12 seconds into video!!!!!!
  15. Aug 6, 2019 at 12:13 PM
    JamesTaco91B
    JamesTaco91B Member
    James
    2017 Tacoma sr5
    Did you have it changed did the noise go away??
  16. Aug 6, 2019 at 4:23 PM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    I hope thats not normal. Had 2 2.7's and never heard the 12 sec noise.
  17. Aug 6, 2019 at 4:25 PM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    that doesn't sound normal. take it to another dealership for a second opinion.
  18. Aug 6, 2019 at 4:27 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    When you said "ticking" initially I thought it was normal. Every Toyota 4 cyl I've ever heard has a tick, from my dad's 1980 20R to my 2TR.
    But then I watched the video. The ticking I know doesn't sound like that.
  19. Aug 6, 2019 at 4:31 PM
    Ob1-adobe
    Ob1-adobe Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    The ticking from what I understand is the injectors cleaning themselves.
  20. Aug 6, 2019 at 4:32 PM
    Ob1-adobe
    Sounds like tapping plastic? like its vibrating against something.
