2019 tacoma SR engine question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Jun 12, 2019.
  1. Aug 7, 2019 at 7:16 AM
    #41
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    My 2016 SR5, 2.7 I traded nor my 2019 SR, 2.7 makes that knocking noise. (Does not.)
  2. Aug 7, 2019 at 7:17 AM
    #42
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    larsonfan....my 2019 SR, 2.7 makes that knocking noise
    yours makes same knocking sound?
  3. Aug 7, 2019 at 7:43 AM
    #43
    CusterFan
    No Sir it does not make the knocking noise.
  4. Aug 7, 2019 at 8:49 AM
    #44
    kiki111
    Tacoma 2.7L SR
    found...t-sb-0316-17
    talling about vacuum pump knocking noise....but it says 2016-2018 models only....well see.....
  5. Aug 7, 2019 at 8:59 AM
    #45
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thats for the V6 I believe
    CusterFan likes this.
  6. Aug 7, 2019 at 9:39 AM
    #46
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Can't you just unplug the pump and start the engine and see if the noise persists?
    AKGSD likes this.
  7. Aug 7, 2019 at 9:47 AM
    #47
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I’ve not heard these vacuum pumps, but that doesn’t sound normal to me!
  8. Aug 7, 2019 at 9:48 AM
    #48
    kiki111
    Tacoma 2.7L SR
    At this point from what I read and the advice you guys are giving me it's not the vacuum pump making a noise... but it does sound like something that is turning on... since it doesn't do it when you first start the engine
  9. Aug 7, 2019 at 12:43 PM
    #49
    kiki111
    Tacoma 2.7L SR
    okay went back to dealership pulled a random Tacoma 2019 2.7 L just like mine and the engine noise was exactly the same. The only difference was mine seems slightly louder... outside that they both sounded exactly the same
  10. Aug 7, 2019 at 1:27 PM
    #50
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Good to here. No need to worry now
  11. Aug 7, 2019 at 1:32 PM
    #51
    kiki111
    Tacoma 2.7L SR
    regardless.... I would hate to think you buy a new truck and you're one of those guys that has problems and gets a lemon
  12. Aug 7, 2019 at 1:33 PM
    #52
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    Must be all the bath salts in that Florida air
    SR-71A likes this.
  13. Aug 7, 2019 at 1:37 PM
    #53
    kiki111
    Tacoma 2.7L SR
    The only question I have is I wonder what the hell it is that turns on... it's definitely not the vacuum pump... noise generates on the same side as mine and everything
  14. Aug 7, 2019 at 2:32 PM
    #54
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I listened to the noise again. I think it maybe the VVTI controller on the intake cam. If you had access to a Techstream you can activate it and see if the engine makes the noise. Toyota only started using a VVTI on the cam intake side for the 2.7 starting in 2016.
  15. Aug 7, 2019 at 3:46 PM
    #55
    kiki111
    Tacoma 2.7L SR
    would that be the drivers side....noise comes from the drivers side..you hear it more on the drivers than the passenger side....somewhere behind the throttle body area
  16. Aug 7, 2019 at 5:36 PM
    #56
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    It would be on the driver's side at the front of the motor. It attaches to the cam shaft which runs the length of the motor.
  17. Sep 6, 2019 at 9:06 AM
    #57
    westside4
    westside4 New Member
    Calgary
    2013 Tacoma 4x4
    leveling kit
    I had the same issue. In gear, with foot on the brake, you can really hear it. Brought it in this morning, and they ordered a vacuum?? Ive got a 2018 trd v6. Hope this helps.
  18. Sep 22, 2019 at 7:38 PM
    #58
    Caleb13
    Caleb13 Active Member
    Grey metallic SR 2.7 Tacoma manual trans
    I have your same exact noise after a few minutes of idling did you ever find out what was wrong or was the knocking sound normal?
