2019 tacoma (Truck stalled) help/ideas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ano'ai808, Jul 12, 2020.
  1. Jul 12, 2020 at 2:37 AM
    Ano'ai808
    Ano'ai808 [OP] HoloHolo Kalaka
    Ano'ai
    Kahului
    2019 TRD sport
    2.5 fox 3-4in front/rear Dirt king fab LCA/UCA Locked rear bumps OME leaf pack ARB air 15%-5%tints
    So guys I have a 2019 tacoma 4x4 sport. Drove it today for about 20 min. Turned the truck off..... on my way back home 10 min in the drive. Check engine light came on and truck just had no power. I had instantly no throttle response no anything. Motor ran a little rough for a bit. Pulled over turned it off. Waited a bit then turned it back on and same problem.
    Plugged it into my scanner that I hold in the truck and got code p0191 and p0087. I saw that this is a sensor for my fuel pressure. I do have lights on the truck and an alarm and a beefy stereo so I hope thats not the problems I have no clue. Any ways I took the positive clamp off waiting for a bit and put it back on and started it up and drove perfect after that and made it home. Can any one shed some light on this or how to fix it so this won’t happen again. Has anyone had this same problem with 3rd gen? Thanks guys
  2. Jul 12, 2020 at 3:18 AM
    vwarwar
    vwarwar Member
    Vitor
    Tacoma 19
  3. Jul 12, 2020 at 3:21 AM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Fuel pump. Known issue
    specter208 likes this.
  4. Jul 12, 2020 at 3:44 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Wow another fuel pump failure.
  5. Jul 12, 2020 at 3:55 AM
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    That sounds like the fuel pump, your model year falls on the recall years, you might want to check the VIN.
    Anyone know why a 2018-2019 have fuel pump issues (recall) but not the 2016-2017?
    I would've thought they use the same fuel pump unless they changed something significantly.
    Modesto Tacoma likes this.
  6. Jul 12, 2020 at 9:00 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Maybe different supplier . Just a guess
    Skydvrr and specter208 like this.
