2019 transmission fluid level
Discussion in '3rd Gen. Tacomas (2016+)' started by bob10kat, Jul 7, 2020.
  1. Jul 7, 2020 at 11:45 AM
    bob10kat
    bob10kat [OP] Member
    2019 Tacoma 4X4 TRD off road
    Does any one know of 2019 Tacoma TRD off road 4x4s having low transmission fluid levels, like some the earlier 3rd gen did? The dealer told me the 2019 models have a sensor that tells if the transmission fluid level is low. I only have 5600 miles on it and it has started ruff up and down shifts in parking lots and low speeds.
    Thanks in advance.
    Barn
  2. Jul 7, 2020 at 12:08 PM
    Shellshock
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    Pretty sure there’s a sensor in all the trucks but it has to be very low for it to actually go off. It doesn’t check to see if its filled to spec, its if it is severely low
    G8R_Taco likes this.
  3. Jul 7, 2020 at 12:08 PM
    G8R_Taco
    G8R_Taco Fruit Bowls All Around
    FLA
    2019 TRD OR 4x4
    Mine was almost half a quart low when I checked it at 500 miles. No shifting issues in my case. 16k now. You may want to take it in since there seems to be an issue. If it’s low enough to cause shifting issues, get it documented.
    Lucifer1 likes this.
  4. Jul 7, 2020 at 12:59 PM
    eraser
    eraser Well-Known Member
    Vancouver Island, BC
    2017 TRD OR
    I would insist on getting it checked if you are experiencing shifting issues. And yea, get it 100% documented.
    G8R_Taco and Lucifer1 like this.
  5. Jul 7, 2020 at 1:04 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    You can skip the dealer and check yourself. Links to the how to are in the maintenance sticky. Its easier than it looks at first.
  6. Jul 7, 2020 at 1:27 PM
    eraser
    2017 TRD OR
    This is what I ended up doing because I had to "see it for myself". Bit of a faf but not that bad.
  7. Jul 7, 2020 at 2:23 PM
    Amanelot
    Amanelot Member
    Texas
    Pardon my Muricaness, but what is a "faf"
  8. Jul 7, 2020 at 2:41 PM
    eraser
    2017 TRD OR
    faf = hassle, more or less.
    Amanelot likes this.
