2020 Differential Breather
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ_Tumbleweed, Dec 30, 2019.
  1. Jan 18, 2020 at 6:34 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    :thumbsup:
  2. Jan 18, 2020 at 7:02 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    Another option, fix all the breathers.
    The problem is the stock "vent valve" shutting off the air flow and causing a vacuum in the diff as it cools. Extending the stock style breather valve to the end of a hose doesn't really help much. Adding a "filtered vent" allows the air in the diff to move in and out freely so no vacuum or pressure is formed with temp changes.
    No affiliation with these guys, just a well thought out, complete kit to do all the vents.
    YMMV RON
    https://state48overland.com/collect...ferential-breather-kit?variant=14232721588313
  3. Jan 18, 2020 at 7:22 AM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    First options that popped up when i did a quick search. Your kits a great value! If it had been available when i did mine years ago, i would’ve gone with it for sure.
    DrFunker and Blais03[QUOTED] like this.
  4. Jan 18, 2020 at 7:26 AM
    ls7alex
    Newark
    Taco gang
    This is actually awesome. I had to do a million searches for all these parts years back :anonymous:
  5. Jan 18, 2020 at 8:32 AM
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    I thought that only the rear diff breather was one-way, thus needed to be extended and replaced with a two-way? The rest of the breathers (front diff, TC and trans) were all extended and two-way from Toyota??
