2020 Tacoma 8” non jbl speaker/amp upgrade
Discussion in 'Audio & Video' started by legodog, May 18, 2020.
  1. May 18, 2020 at 3:04 PM
    legodog
    legodog [OP] Member
    Dan
    2020 Tacoma TRD Off Road Cement Grey
    Hey I am looking at upgrading the speakers and adding a amplifier to my 2020 Tacoma with the 8 inch screen non jbl system. I would like to keep stock head unit. I bought these items
    Speakers:
    Kicker 6x9 44KSC69304
    Morel Tempo Ultra 602 Integra
    Metra 72-8104 speaker wiring harness
    Amp:
    Pioneer GM-D9605
    Line Out Converter:
    Audio Control LC7I
    Sound Deadening:
    Noico 80mm
    Wiring kit:
    KnuKonceptz Kolossus 4 Gauge OFC kit
    Curious if I missed anything for booking up to stock head unit, I don’t have the pioneers SP input harness anymore.
  2. May 26, 2020 at 9:15 PM
    pbandnv
    pbandnv Active Member
    2020 Tacoma SR5 Access Cab
    How are you hooking up the line out converter ? Are you cutting the factory wiring harness or did you find an aftermarket harness plug?
  3. May 27, 2020 at 11:39 AM
    legodog
    legodog [OP] Member
    Dan
  4. May 27, 2020 at 11:55 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    2020’s don’t use the 1761 harnesses anymore
  5. May 27, 2020 at 12:54 PM
    legodog
    legodog [OP] Member
    Dan
    Is there a different part number now then? Or do I have to go a different route with that?
  6. May 27, 2020 at 2:05 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    The Taco Toons 2018+ Camry add-an-amp harness is the only option I currently know of. Which stinks because it’s like $40. But it works
  7. May 27, 2020 at 2:14 PM
    pbandnv
    I’ve been following the other thread about this— this one from amazon has been verified to work in the 2020 but is $55. Looks cleaner than the taco tunes one I think. I’m still thinking about saving the money and just tapping into the factory wiring harness. Just want to make sure I know the correct color wires for the rear speakers. I already have a LOC from my old car that works perfect anyway.
    https://www.amazon.com/gp/product/B087Z1794K/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
  8. May 27, 2020 at 2:16 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    This piece and the taco tunes harness have two very different purposes. This piece is a basic LOC tapped into the front speaker wires, for adding a subwoofer amp. The taco tunes harness is for adding a 4ch amp to the factory radio
  9. May 27, 2020 at 3:29 PM
    pbandnv
    The one from Amazon seems to also have a power line output— do you know if that one is constant power, or does it turn off and on with the head unit?
    I’m only wanting to add a sub.
  10. May 27, 2020 at 3:35 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Turns on and off with the head unit
    if you’re just adding a sub, the one from Amazon is what you want
    pbandnv likes this.
