2020 Tacoma Access Cab SR/SX Bed Light Mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tgregory6852, Dec 17, 2020.
  1. Dec 17, 2020 at 5:07 AM
    tgregory6852
    tgregory6852 [OP] Retired Aerospace Engineer
    Upstate New York
    2023 Tacoma Access Cab, SR
    Dealer under coating. OEM Tacoma bed mat, Weather tech mud flaps and Window Deflectors. Also added bed lights and switch.
    I apologize for my ignorance as I’m new to the Mod world.
    The above Taco didn’t come with a cargo light switch in the dash. However it is wired for the lights in the bed wall under the tail lights.
    I ordered the below components based upon a note in the Amazon listing for the EOM light kit.
    Part Number Part Name
    PT857-35200 Bed Lighting Kit
    90080-87026 Fuel Pump Relay
    84267-0C020 Switch
    Note: I ordered these items from oempartsorce.com for around $80.00 plus shipping. Much better pricing than Amazon or eBay!
    I assume the cab is wired for this switch option as there is a vertical plug in the dash where I’ve seen the cargo switch on other versions of Taco’s.
    Now to my ignorance.
    1) I assume I can just push out the plug and there will be a harness there for it?
    2) Where does the relay plug in? I checked the main fuse/relay box under the hood but didn’t see a notation for the cab light/switch circuit?
    3) Will the vehicle automatically recognize the new parts and update the system so I can access the options for it in the system settings?
    4) Should I disconnect the battery before installing these components, and what consequences would that cause?
    Please review and advise at your convenience!
    Thanks,
    Tom
  2. Dec 17, 2020 at 6:39 AM
    SR5TacoMike
    SR5TacoMike Well-Known Member
    2020 Tacoma SR5 V6 4X2 Metallic Grey Crew Cab Short Bed
    Interesting, I did not know this was an option. I too have a 2020 taco and I would like to do this too.
    SJBrown likes this.
  3. Dec 17, 2020 at 7:11 AM
    tgregory6852
    Upstate New York
    Go on YouTube and search on Tacoma mods. You’ll find hundreds of video’s.
    It’s addictive!
    Good luck
  4. Dec 17, 2020 at 10:29 AM
    caribe makaira
    Caribbean, Puerto Rico
    1- Only you can be sure when blank is pushed out.
    2- upload_2020-12-17_14-25-40.jpgit's in the cab, not the engine bay.
    3- There's no magic/programming for the bed & cargo lamp on an SR. (it'll work)
    4- You should anytime you mess with the electrics and electronics of the vehicle. SR has no reset features after battery disconnected. It'll run rough until it relearns the engine settings again.
    P.S. Slot for switch should be horizontal. Unless you're OK with viewing the writing sideways (switch won't fit anyway) or use a Tundra switch.
    SJBrown likes this.
  5. Dec 17, 2020 at 11:24 AM
    tgregory6852
    Upstate New York
    Ok thanks, I’ll check out the relay location. Is it identified as such?
    My bad on the switch. There is a horizontal one.
    Tom
  6. Dec 17, 2020 at 11:27 AM
    caribe makaira
    Verify that the relay terminals are there...(inside the relay slot)
    NotYourDAD and SJBrown like this.
  7. Dec 17, 2020 at 11:33 AM
    caribe makaira
    A few members in the Forum had issues with the wire coming from the bed behind the tail lamps were not connected from the engine side to the cab. You should verify that also.
    SJBrown likes this.
  8. Dec 17, 2020 at 1:03 PM
    tgregory6852
    Upstate New York
    Ok will do.
  9. Dec 18, 2020 at 10:15 AM
    tgregory6852
    Upstate New York
    Ok. Can’t get the plug out. Difficult to get to from behind. There is a harness with a couple plugs on it in that area. Will need the switch to determine which one would be correct. Also, I assume I should be looking on the drivers side for the relay block? I didn’t see one it see what is there below.
    Please advise.
    SJBrown likes this.
  10. Dec 18, 2020 at 10:22 AM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Bed light switch connector looks like this but is black. It should be tucked into a plastic housing.
    For the relays check behind that kick panel in your images.
    *Edit: Also one thing to note is you probably won't have a switch blank for the horizontal bed light switch. You may need to order it aftermarket or get a different panel. @MESO sells panels for that side and can cut a bed light switch opening for you.
    SJBrown likes this.
  11. Dec 18, 2020 at 10:50 AM
    tgregory6852
    Upstate New York
    Ok. I did have the kick panel off but didn’t see the relay block. It’s got to be there somewhere as the vehicle has heated side mirrors as noted in the schematic above.
    Also, there is a horizontal blank on the dash. Can’t get the plug out.
    Thanks!
  12. Dec 18, 2020 at 11:03 AM
    tgregory6852
    Upstate New York
    Ok. What’s the best way to get that out without damage?
  13. Dec 18, 2020 at 12:16 PM
    tgregory6852
    Upstate New York
    Gotta love YouTube if you know what to look for!! Worked like a charm.
    Thanks!
  14. Dec 18, 2020 at 12:22 PM
    tgregory6852
    Upstate New York
    Caribe Makaira
    Can you provide a more detailed location of the relay block. Is it behind the left kick panel?
    Thanks,
    Tom
  15. Dec 18, 2020 at 1:49 PM
    caribe makaira
    If you found the cab fuse panel then the location you need is above and to the left.
    But if you removed the cubby, you should see the relay location right in the background.
  16. Dec 18, 2020 at 1:53 PM
    tgregory6852
    Upstate New York
    Ok I’ll check.
    Thanks
  17. Dec 18, 2020 at 2:15 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    That video makes removing the panel look easy -- one pry at the upper right corner and it pops off. Well, I'm here to tell you -- it's not that easy. I spent a couple of hours prying at various points around the panel and made no progress. Or rather, it seemed like things were about to break. I stopped because I didn't want to damage a brand-new truck. There are 10 clips that need to be released. If you pry the way it's shown in the video, some of those clips are going to break for sure. I need to see the real-world procedures that the professionals use.
  18. Dec 18, 2020 at 3:16 PM
    kmorgan3
    Kyle
    PNW
    That's funny; I've ripped mine off about a dozen times and each time I Just pry at a corner and it pops off. You must have the super strength clip mod.
    caribe makaira likes this.
  19. Dec 18, 2020 at 3:46 PM
    tgregory6852
    Upstate New York
    I took a small pointed pocket knife and stuck in the middle of the right sides the top row of switches. It popped right away. Then moved to the midline and got it to release. It does click a bit on the left side but had no broken tabs.
  20. Dec 18, 2020 at 9:32 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    You guys that are successful in this seem to be using rigid tools (pocket knives, etc.). I was using a flexible spatula in an attempt to go in there and release the clip(s) while prying out. Maybe the secret is to simply pry and not worry about the clips. I'll try it again as soon as I get a chance.
    (When you pry like that you are moving the whole panel slightly to the left. This may be just enough to allow the right-side clips to clear. We'll see.)
