2020 Tacoma Coolant
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmutk, Dec 16, 2020.
  1. Dec 16, 2020 at 2:08 PM
    mmutk
    mmutk [OP] New Member
    2020 Tacoma 4x4 ext cab
    I have a 2020 Tacoma with a little over 6,000 miles. I got under the hood today and noticed that my coolant is nearly 2/3 gone. I just had a 5,000 mile service where I would assume it was refilled.
    The truck runs fine, no issues with temps or anything else. Should I be concerned I saw no evidence of a leak. It was not running and it is 30 degrees outside. It wasn't down to the LOW mark but it wasn't far off.
    Thanks
  2. Dec 16, 2020 at 2:09 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a low and full, but it fluctuates. I never want the coolant near full because of expansion when its warm. I personally like 2/3rds.
    You're right it should be higher, but its not dire.
    Junkhead likes this.
  3. Dec 16, 2020 at 2:21 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
  4. Dec 16, 2020 at 2:46 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Mine tends to stay right at half or so in the overflow, maybe a little more, and the radiator is full every time I’ve ever checked it.
    I’m the only one doing maintenance and owned it for 2 years and I have never added coolant.
    As long as you’re not seeing leaks on the driveway (it’s red so it should be easy to spot), you are likely fine. Add a little if it makes you feel better but as someone else said, leave some expansion room in the tank.
  5. Dec 16, 2020 at 3:01 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Read your owner's manual before panicking.
    Tullie D likes this.
  6. Dec 16, 2020 at 3:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    Actually the plastic underhood canister (expansion tank is another name) is what you are seeing low.
    If your coolant in the system were 2/3 gone you'd be having a hot time in the old town tonight.
  7. Dec 16, 2020 at 3:14 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Check it at operating temp. If it's 30* out, it will show low if engine is cold.
  8. Dec 20, 2020 at 9:00 AM
    mmutk
    thanks I added some to make myself feel better, but I'm not panicking
