2020 Tacoma off-road won’t shift from 4th please help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bulletproofmafia, Jan 2, 2021.
  1. Jan 3, 2021 at 3:59 PM
    #181
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude. Look at what you are writing.
    You just agreed that gears are a torque multiplier right?
    Here's what will happen. Let's say that this cat gets X torque at 5300 rpm. He will lower ration in rear diff thus multiplying torque output. Now transmission will shift to 5th (OD) which will effectively lower rpm. The end result is same torque at lower RPM.
  2. Jan 3, 2021 at 4:00 PM
    #182
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Hence a regear.
    shakerhood, philth, Junkhead and 2 others like this.
  3. Jan 3, 2021 at 4:01 PM
    #183
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    Did your rack come with a lube holder and a year of dealer supplied astroglide? If not I’d go
    back and complain.....that dealer saw you coming a mile away.
  4. Jan 3, 2021 at 4:07 PM
    #184
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes, but then the rear end will multiply torque even more in any given gear, thus putting out more power/torque.
    Bleep100 and hiPSI like this.
  5. Jan 3, 2021 at 4:14 PM
    #185
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Good points, but we’re not dealing with straight gear ratios and the engine power curve here. We’re dealing with Toyota’s mystery shifting logic based on torque and other variables in the 3rd gen that weren’t there in the second gen. And this where I bow out lol
    https://vftuner.com/blogs/news/here...-tacoma-transmission-and-how-we-are-fixing-it
  6. Jan 3, 2021 at 4:18 PM
    #186
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Maybe if the dealer has a competant enough technician they would work with you on labor cost to re- gear. You provide the gears, install bits and pieces.
  7. Jan 3, 2021 at 4:20 PM
    #187
    davidstacoma
    David
    NC
    tacotoe and Junkhead like this.
  8. Jan 3, 2021 at 4:43 PM
    #188
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Guys, I'm an idiot. I didn't read the post title saying his truck won't shift out of 4th and thought his complaint was only the RPMs. I was wrong; a regear will address his complaint and get him out of 4th on the highway. :deadhorse:
  9. Jan 3, 2021 at 5:00 PM
    #189
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    :thumbsup:
    Junkhead, JoeCOVA and tacotoe like this.
  10. Jan 3, 2021 at 5:04 PM
    #190
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Good job on making us all think up new ways to explain gearing :laughing:
    CG256, Junkhead, JoeCOVA and 3 others like this.
  11. Jan 3, 2021 at 5:06 PM
    #191
    davidstacoma
    David
    NC
    Now if we can explain why some folks insist on big tires for looks even though they won’t ever go off-road ...and not just avoid this problem
    CG256, Chew, Rock Lobster and 6 others like this.
  12. Jan 3, 2021 at 5:08 PM
    #192
    0xDEADBEEF
    Figure that one out and you'll destroy an entire industry. :fistbump:
    Chew, Junkhead, philth and 1 other person like this.
  13. Jan 3, 2021 at 5:16 PM
    #193
    philth
    philth .
    Wait.. can someone run down re-gearing again for me?
    What’s the biggest tire size I can run without have to chop/cut/re-gear/get the same or better mileage than stock? Will a re-gear make the truck handle more like a lambo?
    Fun thread! Maybe not for OP though
  14. Jan 3, 2021 at 5:18 PM
    #194
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    I think looks are a valid reason to lift a truck and put bigger tires on it. But you have be willing to accept the compromises that go along with that. I'm not so I rock the stock.
  15. Jan 3, 2021 at 5:20 PM
    #195
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Never underestimate the power of the ''cool factor.'' It has dried up more wallets then a New Orleans stripper bar at Mardi Gras.
    tacotoe, Tttacodan, Chew and 4 others like this.
  16. Jan 3, 2021 at 5:32 PM
    #196
    davidstacoma
    David
    NC
    31.5 inches and not a mm more.
    Agree, folks should do what they want to their trucks, no justification needed. Just dont complain when you go for that big tire look and you suddenly discover you need to regear and your gas milage goes down.
    Fortunately Im past my cool factor years and into the old age years of function and practicality. Wife ended my stripper bar days too, harsh woman, refused to even let me bring a date to our wedding!
  17. Jan 3, 2021 at 5:36 PM
    #197
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    If i could like "vote" more and once i would, but I'm not a ** so i can't..
    Cops around me would say go away little boy and find something else to do.
    PS: Yes he's in 3rd and going faster than he knows .... BUT .... that's his problem not ours.
    VB25, Junkhead and davidstacoma like this.
  18. Jan 3, 2021 at 5:50 PM
    #198
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    OP, is there anyone you know with a 3rd gen equipped like yours that has been regeared, so you could go for a ride with them to compare? Or find a TW member close to you that would volunteer to take you for a ride? Also, I guess if you paid 58 grand for a truck, you can afford the two grand to regear? Isnt re gearing around a grand an axle, not sure...
    tacotoe, Chew and Junkhead like this.
  19. Jan 3, 2021 at 5:53 PM
    #199
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Hopeful the op does not find himself on america’s most wanted. Man is a rebel running 13 over the limit in a baby monster truck.
  20. Jan 3, 2021 at 5:58 PM
    #200
    davidstacoma
    David
    NC
    Lmao not sure where you live but 13 mph over the speed limit on the interstates I drive on isn’t uncommon. I hold it to 9 over or less. Same with most of the drivers I’ve seen in VA.
    Junkhead likes this.
