2020 Taco's with factory Roof Racks...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vo0Do0, Nov 11, 2019.
  1. Apr 15, 2020 at 4:36 PM
    #141
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Yep, I would say about 1/4"
    Jon
  2. Apr 18, 2020 at 1:32 PM
    #142
    NMTaco175
    NMTaco175 New Member
    New Mexico
    2020 Army Green Tacoma TRD Pro w/ MT
    Just in the nick of time! I was searching the forum looking for guides / tips on installing the OEM rack on my 2020 (DoM 11/19), and minutes before beginning the install, I came across this thread. While disappointed, I'm sure glad I didn't figure the problem out the hard way--thanks to all who have contributed here!
    Now, let's hope TRDShop.com does the right thing and accepts the return...
    Malvolio, AKGSD and Jtoeps like this.
  3. Apr 18, 2020 at 1:40 PM
    #143
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    they went from tool 1 to tool 2. The only thing different was the location of the punch out for stamping. Everything else down the line stayed the same, and before it stayed the same. All they did was revert to the tooling they already had from the prior year.
    likely this took 5 minutes and zero dollars to do it this way. Everyone with a 2020 built before this though doesn’t get a resolution.
  4. Apr 19, 2020 at 6:19 AM
    #144
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    I hadn't heard that it was just the previous position and haven't been back in this thread since I made the comment. I based that off the statement that it was moved because of the updated 3rd brake light design. My employer has a tendency to undo things in the most complicated, bureaucratic way possible. So much for "the Toyota way" :rofl:
    GarlicFarts[QUOTED] likes this.
  5. Apr 19, 2020 at 1:42 PM
    #145
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    The question remains - WHY DID THEY MOVE IT IN THE FIRST PLACE?
  6. Apr 19, 2020 at 2:52 PM
    #146
    GarlicFarts
    Lil Rhody
    because of a leaky 3rd brake light I thought.
  7. Apr 19, 2020 at 3:45 PM
    #147
    dpippel
    Phoenix, AZ
    Only speculation. I haven't seen any documentation to prove or disprove that this was the reason. And if it was, why did they move it BACK to the old position on the roof?
  8. Apr 20, 2020 at 6:12 AM
    #148
    Tbar71
    Tbar71 Active Member
    Troy
    Pace, FL
    2020 Cement Tacoma Limited
    If mine says 02/20, is that Feb 20th or must Feb of 2020?
  9. May 4, 2020 at 6:19 PM
    #149
    Fade135is
    Fade135is Active Member
    Feb 2020
  10. May 5, 2020 at 3:40 AM
    #150
    T@coTim
    T@coTim Well-Known Member
    Tim
    Has anyone tried modifying the cross bar so it would clear the antenna, or is it made of some kind of cast material?
  11. May 11, 2020 at 8:58 PM
    #151
    jacobswx
    jacobswx Well-Known Member
    Colorado
    2020 Cement Tacoma TRD Off Road
    Anyone hear end up modifying the antenna?
  12. May 12, 2020 at 8:01 AM
    #152
    jacobswx
    Colorado
    Alright, think I’m gonna go ahead and buy the OEM roof rack and just cut the antenna to make it fit. Is $260-$280 a good deal for the roof rack? Several dealerships are selling them for that in my area.
  13. May 12, 2020 at 8:28 AM
    #153
    Fade135is
    Ive seen it done on the second gen. Please keep us posted on how it works out on the 3rd gen.
  14. May 12, 2020 at 8:52 AM
    #154
    dpippel
    Phoenix, AZ
    Good luck! Please post your results here when you get a chance. Thanks!
    T@coTim likes this.
  15. May 12, 2020 at 1:39 PM
    #155
    T@coTim
    Tim
    I’d like to see that as well
  16. May 12, 2020 at 3:21 PM
    #156
    jacobswx
    Colorado
    Well, I’m used to someone else being the test rat for this stuff while I reap the rewards later on. Guess it’s my time to chip in for TW. Going to pick up the rack tomorrow, will update in this thread.
  17. May 12, 2020 at 3:29 PM
    #157
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    Any reason why you would want to spend that kind of money on a roof rack that has limited use, and many incidents of failure? There are many alternatives available that can provide you a much more usable rack. Not to mention doing some kind of hack to make it work.
  18. May 12, 2020 at 3:31 PM
    #158
    jacobswx
    Colorado
    I’m all ears if you have an alternative that isn’t 2-3x more expensive.
    Edit: And don’t need to drill into the truck.
    dpippel likes this.
  19. May 12, 2020 at 3:43 PM
    #159
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I think rhino racks make some tracks that fit in the factory spots? Not sure what they cost though...
  20. May 12, 2020 at 3:51 PM
    #160
    Interbeing
    Austin, TX
    Martin Off Road is under $500, and gives you a full aluminum rack with proper T-slot rails, options to add more rails as needed, and cutouts for LED lighting, should you choose, and also use the existing roof attachment points. It may be a few more dollars, but you will only have to buy it once, and have a very safe and usable rack that will last for the life of the truck, without having to perform some type of hack to make it fit with the fin.
