2020 TRD frame crossmember replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by markwil50, Sep 28, 2024.
  1. Sep 28, 2024 at 6:50 PM
    markwil50
    markwil50 [OP] New Member
    Mark
    2020 Tacoma TRD long bed
    Truck cap, dual roof racks, decked system, 4" lift, new wheels, 33" tires, rooftop tent, awning, Wilwood brake rotors and calipers in front, disk brake conversion in rear.
    Hey everyone, I have a 2020 TRD dual cab with a Rough Country 4" lift on it. I was really wanting to upgrade my lift/suspension to something that could handle more weight and give me more confidence overlanding with a lot of weight(truck cap, tent, awning, fully loaded Decked system, etc.). I decided on some Bilstein's but when I spoke to someone at Shock Surplus I was informed that there were very few options to replacing my Rough Country lift due to the third cross member having been cut to allow the bracket from the lift kit to fit. My question is this: has anyone in this group tried to replace a drop bracket lift kit on a Gen 3 Tacoma? Also, if anyone has, what was done about the cross member? Was it cut out and a new one welded in to replace it? Any info anyone can provide would be greatly appreciated. Thanks.
  2. Sep 29, 2024 at 12:26 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Unless you have the original piece cut from your truck's frame, it'll be difficult to replace that (and have it look decent, anyway). But it can be done. You'll need to cut a member off a junkyard truck, and then carefully trim & grind it so that it fits into the space on yours for welding. Sounds fairly easy, but will be time-consuming (not ideal if you're paying hourly labor and also want it to look good).
    Why not build it around the lift? The lift brackets do not prevent you putting good shocks & springs on it (there are loads of people here wishing they could have 4" lift, but don't want to deal with the crossmember... Here that was already done for you).
    Fox has 2.5s that fit while also eliminating the shock spacer up top, Bilsteins that are set up for stock height will also fit (keeping the spacer), 2.5" or so lift rear leaf springs (Icon RXT for example) can be used together with a 1" or 1.5" block... They were incorrect to say you have "very few options"... (fewer, yes, but not few).
    The rear shocks is about the only place you'll run into this few less options (not everyone has 4-6" lift reservoir shocks, for example). Often, shocks from another application can be made to fit if there's something specific you want.
    Welcome to TW.
  3. Sep 29, 2024 at 12:05 PM
    markwil50
    Mark
    Thank you for the reply and the info, I appreciate it very much.
  4. Sep 29, 2024 at 12:21 PM
    markwil50
    Mark
    So, out of all the Fox 2.5's, which ones would work for this application?
  5. Sep 29, 2024 at 6:15 PM
    4x4junkie
    So Calif. (SFV)
    Fox pt# 883-06-048 (2.5 DSC) or 883-02-048 (2.5 non-DSC) fits the front of yours with the lift (eliminating the shock spacer).
    Fox pt# 985-24-196 is a 2.0 IFP shock that will directly fit the rear.
    Unfortunately a 2.5 rear shock that is long enough is one of those I mentioned that will likely have to come from another application.
    The rear shocks need to be between 26-28" extended, with a 10mm upper stud, and a 32mm width lower eyelet bushing.
    The Fox # 883-26-118 (for a 2nd-gen Tundra) comes in @ 26.83" extended, but I don't have details on the stud dia and eyelet width.
    I'll tag @AccuTune Offroad here, I recall they were modifying Fox FRS Tundra shocks to fit the Tacoma, hopefully maybe they can do the same with the above PES shock since it's right the length you need.
    Barring that, there's some info about fitting Tundra shocks in this thread (the lower mount needs to be modified (ground down) narrower):
    https://www.tacomaworld.com/threads/tundra-rear-shocks-on-a-3rd-gen.659817/#post-23069608
    AccuTune Offroad likes this.
  6. Oct 3, 2024 at 3:16 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Thanks @4x4junkie we had a factory race series rear option for this lift height, but that shock was discontinued.
  7. Oct 3, 2024 at 3:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    Look at the max weight sticker in the door jamb.
    There is more to safe weight management than suspension.
    Yea, folks overload them regularly. But Toyota came up with that number considering driveline and brakes as well.
    Sometimes less is more. Maybe you are a seasoned overlander. If not, actual experience learning the equipment of value to your use is better than jumping full monty.
