2020 TRD OR rear diff fyi
Discussion in '3rd Gen. Tacomas (2016+)' started by heffergm, Jul 9, 2020.
  1. Jul 9, 2020 at 1:57 PM
    heffergm
    heffergm [OP] Member
    I suspect this has been noted elsewhere, but I'll toss it out there...
    I change diff fluid early on new trucks, because they tend to see a lot of break in debris early on, and this one is no different. Good amount of wear material on the magnet and the fluid looked as you'd expect, even after only 3000 miles. What was a bit more 'exciting' was that I only got ~3.5 quarts out of it, and put ~4.3 quarts back in it.
    While I'm not too concerned about it detonating, it doesn't strike me as ideal, so you might want to change it. It's pretty trivial if you're used to doing oil changes.
  2. Jul 9, 2020 at 1:58 PM
    dand
    dand You can't see me
    Dan
    SE VA
    2020 MBM TRD Offroad MT
    1st stage commencing
  3. Jul 9, 2020 at 2:44 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Sounds like you overfilled it.
  4. Jul 9, 2020 at 2:52 PM
    heffergm
    You can't really overfill the rear diff unless you parked it facing down an incline. It's made to be filled up to the bottom of the fill hole. The stated capacity is ~4.2 quarts.
    Since this is the internet and it's probably irrelevant I probably shouldn't mention that I'm 45 and have been spinning wrenches for the last 30+ years, but hey, what the hell. You only live once.
  5. Jul 9, 2020 at 2:58 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    So if it’s meant to hold 4.2 and you put 4.3 , one it’s overfilled and two unless you tore the diff down and degreased it completely it’s overfilled
  6. Jul 9, 2020 at 2:58 PM
    heffergm
    So we're arguing about 100mL's? Pretend I was never here... I have better things to do. Bye!
  7. Jul 9, 2020 at 3:06 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    Gilbert, AZ
    Black '17 OR
    So that's a bigger sticking point than being underfilled from the factory? Lol
  8. Jul 9, 2020 at 3:07 PM
    Twizted
    Twizted 1GR FE
    Rob
    Free America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    Vagabond Drifter (6' bed) Toytec Aluma 2.5 front shocks with resis 700lb coils Toytec Aluma 2.5 rear shocks 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs OEM Bed Mat Total Chaos Bed Stiffeners Husky Floor Liners (F&R) WeatherTech Window Deflectors Hella Sharptone horns (no relay) BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch One-of-a-kind 1GRFE plate (second iteration) Deaver Stage 3 leaf spings Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops CaliRaised bed molle panels (both sides) CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights EBC Stage 3 pads/rotors BruteForceFab Rear HC w/swingout Relocated backup camera w/DIY bracket ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker
    Don't third gens have independent rear suspension?
    lamjam, CrippledHo, G8R_Taco and 5 others like this.
  9. Jul 9, 2020 at 3:07 PM
    Skydvrr
    Nick
    Gilbert, AZ
    Black '17 OR
    For some reason I have it in my head that the "dirty" oil in the diffs, especially with low miles, is a lapping compound. I always wondered if that's where some of the louder diff whines come from. I'm sure some of the more technical Toyota savvy guys will plumb me up though.
  10. Jul 9, 2020 at 3:07 PM
    Skydvrr
    Nick
    Gilbert, AZ
    Black '17 OR
    No.
    Slashaar likes this.
  11. Jul 9, 2020 at 3:10 PM
    Taco-Obsessed
    Shawn
    San Jose
    2015 4x4 DCLB: Work in Progress
    Never ending
    Welcome to TW and just ignore the trolling, it's all in fun.
    You're right that it has been documented that alot of tacos come off the factory floor under filled with fluids. My transmission fluid was under off the factory line. When I changed it I had to put more in then came out, just like you. Good thing you checked and I applaud you for bringing it to the attention of others.
  12. Jul 9, 2020 at 3:14 PM
    splitbolt
    splitbolt Well-Known Member
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    300mL:p
    DAS Taco, Skydvrr and dand like this.
  13. Jul 9, 2020 at 3:14 PM
    Taco-Obsessed
    Shawn
    San Jose
    Never ending
    Overflow valve o_O
    OP, who is new to TW so it's best practice not to poke fun at yet, has been wrenching for 30 years so he knows what he doing. Therefore it is impossible to overfill it by design.
    DAS Taco, AKGSD, G8R_Taco and 2 others like this.
  14. Jul 9, 2020 at 3:14 PM
    Skydvrr
    Nick
    Gilbert, AZ
    Black '17 OR
    https://www.tacomaworld.com/threads/fluid-specs-and-capacities.607434/#post-20514318
    Looks like you did, overfill, at least a bit
  15. Jul 9, 2020 at 3:17 PM
    Taco-Obsessed
    Shawn
    San Jose
    Never ending
    Is anyone that says he overfilled it actually changed differential oil? :facepalm:
    You'd have to pump more in than immediately screw in the plug as it comes rushing out all around that plug and down your hands.
    trackdaybro and AKGSD like this.
  16. Jul 9, 2020 at 3:19 PM
    Skydvrr
    Nick
    Gilbert, AZ
    Black '17 OR
    Yes, we get how diffs work.
  17. Jul 9, 2020 at 3:22 PM
    Taco-Obsessed
    Shawn
    San Jose
    Never ending
    Well than you know it is almost impossible to overfill it, especially an experienced wrencher, unless you screwed the plug back in as it was gushing out all over you.
    OP was trying to make a point his came under filled off factory line. If I had a new truck I would appreciate someone pointing that out versus learning at 30k.
    FLYH2O, AKGSD and JaCado like this.
  18. Jul 9, 2020 at 3:22 PM
    splitbolt
    NW Arkansas
    Absolutely...
    It's the conflation of quarts and liters I'm harping on.
  19. Jul 9, 2020 at 3:23 PM
    Skydvrr
    Nick
    Gilbert, AZ
    Black '17 OR
    That's the whole point. Book calls for 3.8-3.1 depending on config and he drained 3.5 seems spot on. So apparently it is easy to overfill, assuming his numbers are right.
  20. Jul 9, 2020 at 3:23 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB TRD Sport Manual
    Bilstein 5100's 3rd Gen set 1.55" **failed lower bushing @65,000km Old man emu leafs /shocks Timbrens ubolt flip kit Relentless front bumper Smitty 3rd Gen winch SCS Wheels Duratracs 265/70/17 Big County Customs skid plates Arc One industries rear HC bumper Retraxone XR tonneau Sherpa Roof Rack Yakima load bars Pelfreybilt fuse panel tray Smittybilt Tent Dometic CFX50 fridge Cali raised ditch light mounts Cali raised bed stiffeners
    I just did my 8.75” rear diff today and pulled out 3.8L after jacking the drivers side axle to tilt the last few drops out.
    I overfilled mine till it came out the fill hole, then put the plug in and called it done.
