2021 Hummer EV Pickup - 1000hp, 11,500 lb-ft, 0-60 3s
Discussion in 'General Automotive' started by crazychris4124, Jan 30, 2020.
  1. Jan 30, 2020 at 7:33 AM
    crazychris4124
    crazychris4124 [OP] Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    "The bane of environmentalists in the early 2000s, Hummer is recast as an electric-only truck capable of a jaw-dropping 1,000 horsepower, 11,500 lb-ft of torque and a sprint to 60 mph in 3 seconds. “We came to play ball,” a spokesman deadpanned in an interview with Autoblog. Electric range was not revealed.
    GM will build the reborn Hummer at the Detroit-Hamtramck factory in Michigan that was once thought to be set to close. It will be revealed May 20 at an event in Las Vegas."
    https://www.autoblog.com/2020/01/30/hummer-truck-super-bowl-return/?ncid=edlinkusauto00000015
    toucan likes this.
  2. Jan 30, 2020 at 12:38 PM
    crazychris4124
    It’s worth noting this torque figure could very well be the truck’s wheel torque, which is different from what the electric motor actually makes. GM does not clarify which it is at this moment. “Yes, the 11,500 lb-ft number is technically correct from an engineering standpoint,” Roadshow elaborates, “but it’s not the measurement most commonly used. A GMC official told Roadshow the final, SAE-certified number will be released closer to the truck’s on-sale date.
  3. Jan 30, 2020 at 8:54 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    That's a cute torque rating, my tacoma in double low is at 47,521ft lbs at the wheel.
  4. Feb 1, 2020 at 10:09 AM
    crazychris4124
    Most likely the true torque number is 1200-1400. It getting it's it' super bowl commercial on Sunday.
    slander[QUOTED] likes this.
  5. Jun 16, 2020 at 4:02 PM
    crazychris4124
    Hummer getting a t-top
  6. Aug 11, 2020 at 10:14 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Hope they bring it back to the H1 design cues.
    Malvolio and Gunshot-6A like this.
  7. Oct 20, 2020 at 6:06 PM
    crazychris4124
  8. Oct 21, 2020 at 5:44 AM
    skanetic
    skanetic Well-Known Member
    Andrew
    Houston
    2019 Tacoma SR V6 4x4 AT TSS off road
    Softopper, badge overlays, H9 low beams, fog lights with factory stalk switch, intermittent wiper stalk, 265/70/17 AT3W
    Looks bad ass but $$$$
    davidstacoma likes this.
  9. Oct 21, 2020 at 5:52 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I’ve seen videos of it off-road, and more accurate specs online. Looks well engineered, but at $112,000 it’s a wealthy mans ride.
    Malvolio likes this.
  10. Oct 21, 2020 at 5:53 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Torque #s seem a tad inflated but regardless, that poor drivetrain
    Unless each wheel has it's own electric motor people are gonna break em.
    taco.matt likes this.
  11. Oct 22, 2020 at 7:20 AM
    taco.matt
    taco.matt Well-Known Member
    2018 Quicksand TRD OR DCSB
    For whatever reason, GMC provided the total wheel torque instead of motor/engine torque. Accounting for gear ratios, the total motor torque will be around 1000 ft-lb (around the same as heavy-duty pickups).
    Looks like each of the rear wheels has its own motor and the 2 front wheels share a motor.
  12. Oct 22, 2020 at 7:30 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    No kidding. Huh. Might be pretty cool. I wonder who's bright idea it was to market it that way.
    taco.matt[QUOTED] likes this.
  13. Oct 22, 2020 at 7:39 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I watched a 1 1/8" steel winch cable snap like a rubber band during a test of a Deere 944K. It is a hybrid with electric locomotive motors at each wheel. Probably wont be long before the Hummer tug-of-war YouTube videos surface. It's pretty crazy what gets put to the ground using that method of propulsion.
    EdgemanVA likes this.
  14. Oct 22, 2020 at 7:41 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Back to the six figure cues?
