2021 Lower Dashboard Modification?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mazman73, Dec 16, 2020.
  1. Dec 17, 2020 at 2:00 PM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    I think the supplied cable is 1M, it is terminated with RJ45 and I assume that it's a straight through connection but didn't buzz it out.
  2. Dec 17, 2020 at 2:03 PM
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    I mounted mine behind the left switch panel on the far left side. On the piece of plastic that also touches the door. If that makes sense. Fits snug in there. Just used a little foam tape.
  3. Dec 17, 2020 at 2:45 PM
    s7726
    s7726 Well-Known Member
    2019 DCLB TRD OR Cement
    I think the manual actually mentioned it being an ethernet cable (although the connection is NOT ethernet). So that very well might work. At the least, you could crimp up a custom cable with normal RJ45 gear.
  4. Dec 17, 2020 at 3:06 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Being in IT I'm pretty sure it's ethernet cable. Mine I think was about 3 feet or a meter long. Mine had an angle connector on one end. I'm sure it's just using the 8 pins and it's not actually ethernet. I don't see why you couldn't make something longer or shorter if you want.
    I seen some video on YouTube where some Aussie was installing the control box in the rear cargo area of a UTE and using a long cat5 cable to connect at the dash.
