2021 Tacoma Brake controller wiring harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco20212017, Apr 2, 2024.
  1. Apr 2, 2024 at 4:39 PM
    Taco20212017
    Taco20212017 [OP] New Member
    Hi, I bought a Tekonsha 90195 P3 Electronic Brake Controller and 3031-P wiring harness. After I connected it to the brake controller port, the wiring harness burned. Now I cant start the truck. Can you guys check and tell me any issues with the wiring harness?
  2. Apr 2, 2024 at 6:38 PM
    caribe makaira
    Caribbean, Puerto Rico
    Check your towing wires and connector under the Taco and under the tailgate area. Could've been a short, got wires hot.
    Stevie17 likes this.
  3. Apr 2, 2024 at 6:43 PM
    caribe makaira
    Blue at vehicle side is fused power 40 amps (always juiced/hot)
    Black is to trailer electrical brakes
    Green is Dash/Tail illumination (Brake controller)
    White with Black stripe is ground (Brake controller)
    Violet is Brake signal input (Brake Controller)
  4. Apr 2, 2024 at 6:46 PM
    caribe makaira
  5. Apr 2, 2024 at 7:20 PM
    caribe makaira
    The wiring from the Taco is correct. The wiring from the Towing Brake module (visually) seems incorrect. I do not think the dealer will cover the meltdown.
    Chew likes this.
  6. Apr 2, 2024 at 8:19 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Warranty is cover manufacturing defects, sorry, this is not one of them. It’s tough enough to get them to cover what they should.
  7. Apr 2, 2024 at 8:29 PM
    caribe makaira
    wire colors do not mate. But colors do not necessarily correlate to the circuit they are attached to. (Worker could've inserted first color he saw, not following assembly guide)...
  8. Apr 2, 2024 at 8:36 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I have this older style... the 902502 and I just plug into my 12v and away I go.
    Was a bit surprised when I first hooked up the little camper to the truck, plugged in the 7 pin, plugged to the 12v, and
    it worked right off the bat. Not as slick as the new-fangled setups but it works like a champ.
