2021 Tailgate removal Camera connector covers new part #?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crooked Beat, May 13, 2021.
  1. May 13, 2021 at 4:05 PM
    Crooked Beat
    Crooked Beat [OP] Well-Known Member
    GTA
    2021 Tacoma DCLB SR
  2. May 13, 2021 at 4:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You should have been given those with your Taco? Check the glove box, console, and rear seat storage?
  3. May 13, 2021 at 4:17 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Yes I should have been given those two connectors.
    But the dealer says even though the manual shows them and I need them when I remove the tailgate, I am out of luck if the new Tacoma I purchased did not come with them in the glovebox.
    Do you think I will ever return to that dealership for any service?
    Penny wise and pound foolish.
    All over a $10.63 part that should be included with the vehicle. It must have gotten lost along the way to the dealership.
  4. May 13, 2021 at 4:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Wow. That sucks.
    I would do the same as you. That is just a bad move on their part.
  5. May 13, 2021 at 6:49 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    I did not get the connector covers with my 2021 Tacoma. Furthermore, the ones illustrated in the owner's manual (page 127) are not correct for the 2021 model year. (Toyota went from 4-pin plugs to 8-pin plugs.)
    Being a perfectionist, I decided to buy my own. First I went on ebay and found a set for $14, including the instruction sheet and the ziplock bag. These turned out to be the incorrect older type. Finally I got the correct ones from Cycle Terminal. They are Sumitomo #90980-12519 and #90980-12520 (Toyota part numbers). Total cost $11.65 including postage.
    So now I have the set of connector covers in a little baggie in the glove box, for a total outlay of over $25. Whoopie. It's not clear why these are even needed. You could get the same result by wrapping the loose ends of the cables with tape, when detaching the tailgate.
    I would like to know if any 2021 owner got these with their truck. I suspect that this was an item that Toyota simply discontinued, for a small cost saving.
    Crooked Beat[OP] and piff like this.
  6. May 13, 2021 at 7:10 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Thank you for the part numbers.
    I could get the same result with tape. But I have my tailgate on and off quite a bit and found the white and grey dummy connectors quick to attach and detach and waterproof. Foolproof.
  7. May 13, 2021 at 7:36 PM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    FWIW my '19 didn't come with them either.
  8. May 13, 2021 at 8:14 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    These new 8-pin covers are much harder to put on and take off than the old 4-pin covers. I tried them just to check the fit. This is not something I would want to do routinely.
  9. May 14, 2021 at 1:00 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    For what it's worth, 82824-04050 is the correct part number for the 2020-2021 Tacoma tailgate connector cap set.
    Jeff
  10. May 14, 2021 at 4:28 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    I wonder if the 8 pin covers have anything to do with a power lock tailgate?
  11. May 14, 2021 at 4:29 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Thank you!!!! Item ordered.
