2022 tacoma buzzing noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheWolfman43, Jan 21, 2023.
  1. Jan 21, 2023 at 7:16 AM
    TheWolfman43
    TheWolfman43 [OP] New Member
  2. Jan 21, 2023 at 8:06 AM
    Swaine
    Swaine Well-Known Member
    2021 TRD OR 4x4
    No and no.
  3. Jan 21, 2023 at 8:20 AM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrochargers, OME 887's 2", Icon 1.5" AAL, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (60w*4), Sound Ordnance M100-2 Amplifier (110w*2), Infinity Kappa 693C Component 6x9 Speakers, Infinity 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, Bed Lights, Rough Country Roll Up Tonneau Cover, KDMAX Tune
    Maybe check to see that nothing’s loose or rattling around in there. Some rattling trim, glovebox organizer, or maybe even the cabin air filter door is loose and could cause that noise. I would start there!
    jerrybear likes this.
  4. Jan 21, 2023 at 8:22 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Never experienced a "buzzing" sound in mine.
    Can't discern it from your clip.
    Does it change when altering the fan speed?
  5. Jan 21, 2023 at 8:34 AM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    yep, pull cabin filter see if anything is in the fan. I also cannot hear it from your clip. I had a kangaroo rat get in mine. when you put it back together run it with out the cabin filter and box open to see if you can isolate it. then put filter back in and ck noise, then paper work then close the box etc.. of course murphys law says it will have nothing to do with the glove box.
  6. Jan 21, 2023 at 8:40 AM
    Rusty66
    Rusty66 Well-Known Member
    Rhode Island
    19' Limited Barcelona Red (01' TRD OR, 97’ SR5 V6, 88’ SR5 22RE)
    Kangaroo rat? WTF? Sounds like a large rodent to me, rodents don't scare me but I don't like the sound of that!
  7. Jan 21, 2023 at 8:43 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    cabin air filter. When I use the aftermarket HEPA filters I get vibrations from the air flow sometimes. I think the HEPA filters are too restrictive and can cause resonance. take out your filter and see if it goes away.
  8. Jan 21, 2023 at 8:56 AM
    jerrybear
    17 off-road
    lol yeah you won't see them in Rhode Island. It's a desert rat. Cute as long as they don't get into the fan behind the glove box. Crawled in there when I was on a hunt. Had no idea until it started to smell. Had to pull the fan/box, take it apart and clean it like nobody's business. Then had to bomb the interior to get rid of the smell. All good now. Did not know until I researched here at TW, but apparently rodents of all types like to crawl into that space.
  9. Jan 21, 2023 at 8:57 AM
    TheWolfman43
    Update on this i took out the glove box and the noise has gone away. At least at the moment.
    also truck only has 3500 miles on it.
    No rats in truck thats someone else.
    does not change when fan speed is changed.
    noise starts when about 1200 rpm to 1700 rpm going over bumps makes it start then it just continues
  10. Jan 21, 2023 at 8:59 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Noise went away and now there’s a terrible smell…. Hmmm, I smell a rat.
  11. Jan 21, 2023 at 10:16 AM
    jerrybear
    17 off-road
    ok good start, is your truck have a lift?
  12. Jan 21, 2023 at 10:26 AM
    jerrybear
    17 off-road
    this again. maybe the bumps are causing shifting of whats in the glove box. Unless you drove it with the box out. I ask about the lift since needle bearing can mimic these symptoms. but i would think you could feel that through the seat, though it can be subtle. i replaced with ecgs, but before that, slight vibrations in varying degrees at certain rpms. bumps would magnify the problem.
  13. Jan 21, 2023 at 11:28 AM
    TheWolfman43
    No lift. Nothing in glove box.
  14. Jan 21, 2023 at 12:15 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    My brother noticed that if he put downward pressure on the glove box, his rattle stopped. He removed the pad above the glove box. He found that there were a few brackets making slight contact with the top of the glovebox and was able to wedge some foam or cardboard between the top of the box and the brackets. If you still have your glovebox out, you may add some felt tape to the bottom of those brackets before reassembling. Sorry I don’t have pics. If that doesn’t fix it, I think I’d explore the A-pillar/speaker cover rattle fix. Good luck!
  15. Jan 21, 2023 at 12:18 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i have a buzzing sound but it's coming from the A-pillar not the glovebox
  16. Jan 30, 2023 at 6:26 PM
    TheWolfman43
    Update on this. I replaced the cabin air filter and i think it is fixed. When i do not have the filter in there is no buzzing noise. So its either the filter or the filter cover.
    TexasWhiteIce and rsimi72 like this.
  17. Jan 30, 2023 at 7:20 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    did you use a normal style or HEPA filter? i find the HEPA filters are noisy, i think they are too constrictive.
  18. Jan 30, 2023 at 7:40 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  19. Jan 30, 2023 at 7:56 PM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    How about the radio? When it's turned on can you still hear the buzzing?
  20. Jan 31, 2023 at 4:39 AM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    I get a buzzing noise coming from the plastics where the diff lock and mts knob is only while moving. I just push on the plastic around there and it stops temporarily. Sounds like buzzing but it just rubbing or rattling a bit. My Tacoma OCD makes it worse my wife says she can barely hear it.
