2022 TRD Off road - Manual or Automatic???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hypecat, Jan 4, 2022.
  1. Jan 4, 2022 at 4:57 PM
    #61
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Test drive one and see how it feels. I know everybody here can give their opinion, but you really don't know until you drive one. However, I will say the autos can be fine on the test drive, but give it a little bit and you might not like it. I've had several stick daily drivers and really just like to get in my truck, put it in "D", and go. If I want to drive stick, I'll hop in the beater. The 3rd gen automatic can be temperamental; it'll shudder and buck sometimes, or shift in and out. Over time you learn what it'll do and it'll learn what you do. You'll tip in the throttle more as needed and it'll shift how you need.
  2. Jan 4, 2022 at 5:00 PM
    #62
    Cowdog
    Cowdog Well-Known Member
    I actually loved that truck. It had no power windows or any options. It had a full vinyl bench seat and was very plain with hub caps and step and tow bumper. Of all the vehicles I've owned, that's the one I remember the most. I bought it in '84 at age 19. It was only a year old with 15k miles. Now they're called square body trucks. It's rare to even see one here in New England now.
    eurowner[QUOTED] likes this.
  3. Jan 4, 2022 at 5:08 PM
    #63
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    The throttle response of the manual is excellent. At highway speeds, there is no hunting for gears, which contributes to a more engaging driving experience. Neither the MT nor the AT is perfect; it’s a matter of what’s important to you. That’s the “best” choice.
    OZ TRD, 02Duck and PlumpPossum like this.
  4. Jan 4, 2022 at 5:13 PM
    #64
    PlumpPossum
    PlumpPossum Founder
    Caleb
    GSP SC
    2021 TRDORMT | 1986 PICKUP
    I had a 2019 DCLB because I valued the longer bed over anything else at the time. Well fast forward to now and I have a 2021 MT cause the auto was awful IMO and now I couldn’t be happier. It’s a blast to drive and I love how it actually stays in the gear that I want it to be in :D Wish I would’ve just sucked up the shorter bed the first time around.
    So the advice I tell anyone debating this is if you’re even somewhat considering the manual, get it.
    Irons, OZ TRD, jgrider16 and 5 others like this.
  5. Jan 4, 2022 at 5:17 PM
    #65
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    I think there are Manumatics or Autouals options...:rolleyes:... Gear ratios are just barely as important as knowing the engine speed rpm where you achieve the ideal horsepower and torque while driving...overtaking on the Freeway/Highway, towing, hauling, etc... As long as you have kept your radiator and transmission oil cooler with required amounts of fluids, you won't overheat anything driving @ ~4000 rpm. ...opinion from my experience anyway.
  6. Jan 4, 2022 at 7:19 PM
    #66
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    You can push start a manual. :thumbsup:
  7. Jan 5, 2022 at 7:22 AM
    #67
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    I agree with the above, kinda fixed it up a bit tho. Get away from here before its too late. Enjoy whichever you choose. Crawl control only actually works to climb difficult hills. Besides that its never pulled me out of deep mud or sand. I would have gotten a sport instead if it had a rear locker...maybe I should do that, get a sport and put a locker on there.
  8. Jan 5, 2022 at 7:26 AM
    #68
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    depending on what you do off road, an automatic will make it much easier on your overall blood pressure. If youre experienced in manual transmissions and you are an experienced off roader then go with the manual. If you arent experienced in one or the other (or both for that matter) off roading will get exponentially harder.
    And for the record im a moderately experienced off roader and ive owned manuals my entire life until my most recent vehicle simply because I chose to buy a truck that isnt offered in manual transmission anymore.
    All the advice aside, listen to the others on here. It all boils down to preference and feel. Get out there and drive both and decide for yourself. I entered the off road scene several years ago with a manual and the learning curve was extremely steep because when you are climbing over obstacles in a manual it demands your full attention to several different areas at once
    Waynebarkr likes this.
  9. Jan 5, 2022 at 8:16 AM
    #69
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    There is no difference in traction between a-trac and crawl control. The actual difference is crawl control controls your speed using the skinny pedal and the brakes for you. With A-trac you have to do it yourself.
    02Duck likes this.
  10. Jan 6, 2022 at 9:08 PM
    #70
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    So, I am old enough that my first car was a manual shift. Drove large construction trucks with manuals too. Had my manual for six years. It was fun to drive for a while but became a real drag as a daily driver, much worse of a drag if you had any traffic to speak of. The combination of the clutch and the the manual transmission are more expensive to maintain than an automatic.
    Also, a manual is much harder to drive and control in actual off road conditions where you would actually need the low low gearing that people are talking about.
    Definitely go with the automatic especially if you haven't driven a manual for a number of years already. Off-roading is much more difficult in a manual and you definitely don't want to be just learning how to use a manual too.
    I like manuals but they definitely have a lot of down sides which is why they are disappearing from the market.
    As for what the various crawl control modes do, there is a great thread on Tacomaworld here. Once I read it and understood this my enjoyment of off-roading in my Taco went up 1000%:. Third gen automatics have two separate items MTS (or multi-terrain select) and crawl control. Crawl control automatically controls your speed in 4 Lo. I found this to be just "meh"--not very useful. MTS on the other hand lets you select 5 different terrains (from all rock to all sand) and it helps the truck control the transmission to fit each of the terrains--this is really helpful. People confuse these two items with "Atrac" (as they have in this thread) which was on older versions and is not the same.
    https://www.tacomaworld.com/threads/3rd-gen-traction-control-modes-explained.530695/
  11. Jan 6, 2022 at 9:50 PM
    #71
    MGMDesertTaco
    I can pop the clutch for ya, but I ain't pushing. :rofl:
    vivid02[QUOTED] and shakerhood like this.
  12. Jan 6, 2022 at 10:07 PM
    #72
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Mine did that occasionally on the factory fill, I changed to Motorcraft XT-M5-QS fluid and the problem went away. The transmission seems to shift slicker also. This fluid meets the Toyota specifications. Rock Auto had the best price.
    https://www.motorcraft.com/us/en_us...ull-synthetic-manual-transmission-fluids.html
    shakerhood likes this.
  13. Jan 6, 2022 at 10:10 PM
    #73
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Just curious how you figure that a Manual is more expensive to maintain? I have daily driven a manual for the past 36 straight years and only replaced 1 clutch in all that time, outside of that the only maintenance is has been a few lubrication changes.
    Irons, OZ TRD, Chickenfarmer and 4 others like this.
  14. Jan 6, 2022 at 10:28 PM
    #74
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Welcome to the forum :hattip:
    Rather than asking us, ask yourself:
    Do you like to shift
    all day
    every day
    in all situations?
    There is no right or wrong choice, you are the guy sitting in the drivers seat every day (and making the payments), might as well drive what you like.
    doublethebass and shakerhood like this.
  15. Jan 6, 2022 at 10:29 PM
    #75
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    utter nonsense
    I would never have an auto Truck
    Irons, OZ TRD and 02Duck like this.
  16. Jan 6, 2022 at 11:50 PM
    #76
    MentalBill
    MentalBill Well-Known Member
    Bill
    Oahu Hawaii
    2018 Civic, 2015 Tundra, 2022 Tacoma (someday soon, on a boat somewhere)
    Junkhead, shakerhood and 02Duck like this.
  17. Jan 6, 2022 at 11:56 PM
    #77
    eosrory
    eosrory Well-Known Member
    2019 Tacoma TRD OFFROAD Quicksand
    The only reason I chose automatic is that my girlfriend can drive it. Otherwise, I will all into the manual. Cherish the manual!
    Junkhead likes this.
  18. Jan 7, 2022 at 3:06 AM
    #78
    jgrider16
    jgrider16 Active Member
    CO
    2020 DCSB MT. Quicksand. Has some extra goodies.
    Bilstein 5100 lift. SCS Ray10 w/ 33". Toyo RT. RSI SPORTCAP. Stinky children on Carhartt seat covers. Heated cloth seats (Unicorn option?)
    Sounds like you need the new version of the Trail model ... SR5 trim with a rear locker and sweet bronze grille and wheels.
    Wixo[QUOTED] likes this.
  19. Jan 7, 2022 at 3:23 AM
    #79
    jgrider16
    CO
    I just picked up a lightly used 2020 MT TRD-OR after a prolonged search. I was going to order a new pro but didn't want to wait and this truck is Sick (Thanks Montucky Taco).
    I did test drive a TRD PRO auto and it seemed fine. I didn't get to go on any real hills though to asses the gear hunting issues. I think the manual feels a bit quicker (it probably isn't) just because you get to choose when and where you shift to maximize the power band. Mine is lifted on 33's so it's still pretty slow with stock gears. I wouldn't want to re-gear yet, but I'll I'll see how towing and off-road driving go.
    Fuel mileage is still going to suck with either transmission. This truck does not have one of the fancy new 8 or 10 speed units or a DCT or CVT that do show improved economy over a manual.
    I have driven mostly manuals my whole life and generally find them more engaging and entertaining to drive. I live in the mountains though and probably would enjoy it less in city traffic. I like being able to pick and hold my gear going up and down hills and passes, which just doesn't work as well in an auto, despite paddle / button manumatic shifting. 1st gear is low and barely gets you off the line before you are in second. If you haven't driven one, the manual feels pretty old-school compared to a modern manual in a sporty car (my prior GTI for example). When I got it I thought "this feels just like a 15 year old truck ... in all the good ways". The shifter is pretty notchy and it has a long through and there is a noticeable spot when the clutch takes up, which makes the truck lurch just a bit.
    As noted above, MT trucks are going extinct and a manual transmission naturally aspirated basic truck will be pretty "special" in a few years. I'm hoping to keep mine forever, or at least until I can teach my kids how to drive stick on it. Will probably have some kind of fun EV eventually and keep this for camping and wheeling on the weekends.
    Good luck with your decision. People who don't like or understand manuals will say they are archaic and suck, and people who want a manual all have their own reasons. As stated ... go with what YOU want and don't look back.
  20. Jan 7, 2022 at 4:31 AM
    #80
    garander
    garander Well-Known Member
    2019 trd sport dcsb mt
    The manual has hill assist . The 4.30 gearing on the manual is much better for
    A poor aero dynamic , heavy truck with the small 3.5 l . The mapping of the automatic
    Transmissions on modern day midsize trucks , is generally inadequate . # 1 complaint
    In most forums for years . Autos shift for MPGs , manuals are shifted for smiles per miles
    Your criteria for deciding is shortsighted . You can be one of the herd ( autos are everywhere).
    Or you can own a vehicle that’s bound to become a classic .
    Its sad that soon it will very difficult to buy manual shifting vehicles .
    In my opinion its a political decision. The cancel movement wants to remove
    Individuality from the masses . Madison ave has decided that we need
    Massive distractions , ( bells &whistles ) as our primary criteria for buying
    A vehicle . We are bombarded every day as to , why an auto is so much
    Better than a manual . The government wants us , dumb , lazy & compliant .
    I love my 2029 manual sport , 40 k miles . Perfect for the mountain terrain
    I drive in every day.
    I will keep driving it until the wheels or my left leg falls off .
