2023 Tacoma LED bulb
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinoytim, Dec 1, 2022.
  1. Dec 1, 2022 at 5:19 AM
    pinoytim
    pinoytim [OP] Member
    Tim
    2023 Tacoma SR DC 4WD
    Has anyone had success finding quality H11 LED bulbs for the 2023?
    I suspect that the bulbs are the same as the 2022, but no suppliers are showing anything for the 2023 as of yet.
  2. Dec 1, 2022 at 5:20 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Nothing changed so they should work fine
    TacoPacific likes this.
  3. Dec 1, 2022 at 5:23 AM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    i went HIDs. more wires than an LED bulb but you don't have to gamble buying some LEDs to find out they are not "skinny" enough or they don't throw that far.
  4. Dec 1, 2022 at 5:25 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    There may be quality bulbs out there, that doesn't mean they will work for your headlamp assembly.
    If you are interested in understanding why LED bulbs make your light output worse in your factory headlamps, here is a really good read.
    https://www.tacomaworld.com/threads...ctor-headlights.589465/page-281#post-27035644
  5. Dec 1, 2022 at 5:30 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Where did you purchase those and what brand are they, easy to install?
    cammerv8[QUOTED] likes this.
  6. Dec 1, 2022 at 6:05 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I went with Diode Dynamics SL1s which for me was a huge improvement over the stock Halogen and the GE Mega 130s. LEDs like these have come a long way, no issues blinding on coming traffic, the throw is great, see better and farther. Been great for me for the last 4 years. These aren't the junk LEDs off Amazon.
    cammerv8 and pinoytim[OP] like this.
  7. Dec 1, 2022 at 6:10 AM
    pinoytim
    Tim
    Thanks...I will check into those... personally I have had great success with LEDs in my Civic, Accord, Colorado... very good throw, brighter white light, for me it's a safety issue as I don't see well when driving after sundown.
  8. Dec 1, 2022 at 6:14 AM
    RYE793
    RYE793 Well-Known Member
    2022 Lunar Rock SR5 Trail
    VaToy, My3rdTacoma and cammerv8 like this.
  9. Dec 1, 2022 at 6:24 AM
    cammerv8
    Bed inlays stickers
    i got the kit from Amazon i got some Innovited 35W HID kit i got mine in 6000k but to match the normal DRL it should be 5000k. i got 2 kits 1 for the low beam and 1 for the fogs.
    they are fairly simple to install:
    • remove stock bulb
    • replace with HID bulb
    • connect stock light connector to input on the ballast
    • connect ballast to HID bulb
    • either find a place to stick the ballast o better yet use the supplied bracket to mount it in one of the fender holes.
    no flicker, no lights on the dash for missing bulb. they just work as normal. for hi-beam i would suggest a H9 led since they come on instantly, instead of the awesome burn in the HID do when they start from cold.
    My3rdTacoma likes this.
  10. Dec 1, 2022 at 7:19 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    After reading the big headlight thread on here, I went with these from Amazon as crashnburn80 found they perform within a hair of the best performing LED's that he tried in our projectors but cost 1/3 the price. I've used Hikari in several cars and even my snowmobile with no failures. One set is almost 5 years old at this point.
    Hikari UltraFocus H11 H8 H9 LED Bulbs
    https://a.co/gSJC62N
    VaToy likes this.
  11. Dec 1, 2022 at 7:34 AM
    pinoytim
    Tim
    Thanks... the headlamp issue can be a slippery slope, It doesn't seem like an aftermarket benefit for outdated tech like HID, and LEDs technically need to max out at 3000k per DOT regulations for "on-road use. I doubt we will ever see enforcement for the 3000k ceiling, but 6000k does seems a little bright for oncoming drivers.
    I don't really want to blind anyone, even though I have been "laserbeamed" many times. I just can't deal with the yellow dim lamps. I will give these a look.
    Lumens?
    Watts?
    K...?
    DOT?
    who knows....
  12. Dec 1, 2022 at 8:07 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I don't think DOT restricts color temp to 3000k...the OEM LEDs are 6000k if I recall correctly
  13. Dec 1, 2022 at 8:13 AM
    pinoytim
    Tim
    That would be nice...I will check the 6000k.... you know the State Highway Patrols in Ohio are very courteous, but it can be such a bore talking with those chaps...
    If you get my meaning...
  14. Dec 1, 2022 at 8:16 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    LEDs don't melt snow off the housing's face
    RIX TUX and RYE793 like this.
  15. Dec 1, 2022 at 8:56 AM
    atc250r
    Orange County, NY
    The "K" or Kelvin Rating of the bulb is a measure of color, not brightness. Just wanted to make sure you understood what the term means.
    VaToy likes this.
  16. Dec 1, 2022 at 8:57 AM
    RYE793
    It's amazing the amount of emotions the topic of light bulbs can stir up...
    98tacoma27, VaToy, cammerv8 and 3 others like this.
  17. Dec 1, 2022 at 9:05 AM
    atc250r
    Orange County, NY
    VaToy likes this.
  18. Dec 1, 2022 at 9:10 AM
    atc250r
    Orange County, NY
    Agreed, on both sides. Those that think LED is always an improvement and those that think it's always a downgrade and always blinding the crap out of others.
    VaToy, cammerv8 and My3rdTacoma like this.
  19. Dec 1, 2022 at 12:07 PM
    pinoytim
    Tim
    Yea... I guess I'll delay my next post for later, I was going to see if anyone had installed a Phased Plasma rifle in the 40-watt range on their Tacoma yet...
    davidstacoma likes this.
  20. Dec 1, 2022 at 12:08 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I got this vampire system instead
    Idaholandho and Toy_Runner like this.
