2023 Tacoma LED bulb
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinoytim, Dec 1, 2022.
  1. Dec 2, 2022 at 6:21 AM
    #41
    BillyE
    BillyE Well-Known Member
    My DRL are slightly bluer than the Morimoto LEDs, which are supposed to be 5500K
    cammerv8[QUOTED] likes this.
  2. Dec 2, 2022 at 6:22 AM
    #42
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    i did the change and when i went to adjust the headlamp they have the same cutoff point, and when i'm driving the cut off does not go pass the trunk on the cars on the road.
    even here in the 3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlight you can see halogen on the left and HID on the right. there is a bright spot in the middle of the HID but not something that will glare the oncoming or the in front driver. you have to be more worried if a guy put a lift/level kit and did not readjust for the new height.
    when i wanted and upgrade i did read the thread and it gave 4 options. High power H11 Halogen, H9 mod with high power halogen bulb, HIDs, or really expensive thin LED. and but there is no warning that by changing the bulb somehow the cut off will change
    CrispyTacoLover likes this.
  3. Dec 2, 2022 at 6:24 AM
    #43
    23TacoSR
    23TacoSR Well-Known Member
    My factory bulbs are fine, just city driving. I have way more important things to deal with than aftermarket headlamp bulbs.
    BillyE likes this.
  4. Dec 2, 2022 at 6:27 AM
    #44
    BillyE
    For all the complaining about aftermarket LEDs, I can honestly say the worst oncoming lights for me are Ford OEM LEDs.
    VaToy likes this.
  5. Dec 2, 2022 at 6:34 AM
    #45
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I thought the same thing but in the headlight thread crashnburn80 mentiones the uplight that is built into the projectors is above the cutoff and is much brighter with the HID's because of the brighter light source and that's what is blinding others. He mentioned that it's not a problem with well designed LED's because the light source is at "3 and 9 o'clock" rather than 360 degrees so therefore you actually get very little up light which can cause its own issues such as having difficulty seeing a road sign that's directly over the road.
  6. Dec 2, 2022 at 7:03 AM
    #46
    RYE793
    RYE793 Well-Known Member
    2022 Lunar Rock SR5 Trail
    note to self: never, everrrrrr, bring up LED headlight "bulbs" on this forum again
    CrispyTacoLover, ODSC1, VaToy and 3 others like this.
  7. Dec 2, 2022 at 7:13 AM
    #47
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Maybe just avoid burying your head in the sand when someone knowledgeable speaks up. As much as I love a good anecdotal data point that doesn't make a person's opinion any more true when it flies in the face of the testing results.
    Not that you did this personally, just a general statement on this thread and its vitriol
    vicali, Gutentight, Goodnasty and 2 others like this.
  8. Dec 2, 2022 at 7:21 AM
    #48
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Or oil change intervals!
    This is very active forum with great information. Once you figure out how to sift through a bunch of noise and BS posts you'll figure out who the helpful folks are.
    23TacoSR, Chew and RYE793[QUOTED] like this.
  9. Dec 2, 2022 at 7:25 AM
    #49
    RYE793
    One of the best and most accurate posts I've seen on any forum... Thanks
    Jesse H[QUOTED] and VaToy like this.
  10. Dec 2, 2022 at 7:31 AM
    #50
    23TacoSR
    Oh, but the FREE entertainment!
    Jesse H[QUOTED], VaToy and RYE793 like this.
  11. Dec 2, 2022 at 7:44 AM
    #51
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    The only LED he recommended for low beams is hikari ultra. They have great cutoff, don’t blind anyone and definitely an improvement over stock.
    VaToy and atc250r like this.
  12. Dec 2, 2022 at 8:18 AM
    #52
    RYE793
  13. Dec 2, 2022 at 9:09 AM
    #53
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    skeletron likes this.
  14. Dec 2, 2022 at 10:08 AM
    #54
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rofl:
    Yes!
  15. Dec 2, 2022 at 10:41 AM
    #55
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Which vehicle?
    I seldom drive in the dark anymore. I can't give an accurate assessment. 14th gen F150 with light bending technology don't seem bad. The lower grade reflector LED are probably the worst offenders as the reflector is stationary with no vertical adjustment.
    The only other Ford vehicle I can think of with Reflector LEDs is the Maverick, I haven't noticed what effect the lights have in traffic.
    Ranger with LED sometimes had some glare with their projectors.
    I think all the other trucks have Projector LEDs which shouldn't be to bed.
  16. Dec 2, 2022 at 1:00 PM
    #56
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You need to move on, nobody cares what you have faith in and what your saying. Let it go and let people make their own conclusion. We don't have time for your sarcastic remarks!
    RYE793 likes this.
  17. Dec 2, 2022 at 1:13 PM
    #57
    BillyE
    All 2016+ F-150 and 2017+ Super duty with factory LEDs. The bottom LED is made for a wider pattern, while the top LED is more of a spot. It's always the lower LEDs that are the offenders. Now, it's entirely possible that all of these are leveled trucks that were not adjusted.
  18. Dec 2, 2022 at 1:28 PM
    #58
    atc250r
    Orange County, NY
    @VaToy he is literally ignoring the fact that the resident expert he's referencing has said in that big thread that decently built drop in LED's have too little up light so they actually give less glare. LOL.
    VaToy likes this.
  19. Dec 2, 2022 at 1:33 PM
    #59
    VaToy
    Parts Unknown
    I have only glanced at it a few times. I went off others recommending the DD SL1s, videos, the company's reputation and made the decision to try them out and see for myself. Some just need to move on and let it be.
  20. Dec 2, 2022 at 1:39 PM
    #60
    VaToy
    Parts Unknown
    Ah, the good old ignore feature. Only used it a few times so now onto number 3.
    atc250r likes this.
