2023 Tacoma SR5 4x4 Skid Plate Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Reagan2791, Jul 6, 2023.
  1. Jul 6, 2023 at 10:40 AM
    Reagan2791
    Reagan2791 [OP] Well-Known Member
    South Georgia
    2023 Celestial Silver Metallic DCSB SR5 4x4
    Removed front air dam. Technology Package: - [ ] Blind Spot Monitor - [ ] Color Keyed Rear Bumper Dealer Add-Ons: “Predator XP Package” includes: - [ ] Predator Step Tubes - [ ] Blackout and XP Badging - [ ] Black Chrome Exhaust Tip - [ ] 265/70R16 Goodyear Duratracs - [ ] TRD PRO Wheels Window Tint Phone Cable Charge Package w/ Two Rear USB Ports Completed: Steering Wheel Cover AVS Wind Deflectors TufSkinz Red Glove Box Lettering Clazzio Seat Covers Tufskinz Red Accent Strip On Order: OEM Door Sill Protectors & Lettering
    I’m interested in removing the front air dam from my truck and replacing the factory skid plate with something more aesthetically pleasing. From what I understand, the TRD Pro skid plate is a simple install with no modifications necessary and comes with the hardware. However, when I look it up on Toyota online parts site, I get a notice that it may not be compatible with my 2023 SR5. Can anyone confirm if it will work?
    Secondly, given that my truck isn’t a TRD, I’m not sure how I feel about a TRD stamped plate (although it did come with TRD Pro wheels, so I guess it doesn’t matter). Are there any other 3rd party quality aluminum skid plate options that are a simple install with no mods needed and the correct hardware?
  2. Jul 6, 2023 at 11:40 AM
    beaverpelt
    beaverpelt Well-Known Member
    STL
    2023 Tacoma TRD OR
    You can check out Cali Raised and RCI skid plates
  3. Jul 6, 2023 at 11:40 AM
    JTScribe52
    JTScribe52 Well-Known Member
    Dan
    2018 SR5
    rolled93slc likes this.
  4. Jul 6, 2023 at 11:43 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    It may give that message because some parts are only available to those with TRD Pro trims and require a TRD Pro VIN to acquire. I don't think that's the case with the skid plate though.
  5. Jul 6, 2023 at 12:26 PM
    Reagan2791
    South Georgia
    I had seen that one and I like it but it also mentions (twice) that it’s for TRD Off Road and PRO ONLY). Seems they wouldn’t bother to repeat themselves or capitalize the “only” unless it doesn’t work on an SR5.
    edit: now I know. It’s because you have to remove the front valance so it requires a “modification” but user responses on Amazon confirms it works.
    33yrsoftoys likes this.
  6. Jul 6, 2023 at 12:27 PM
    JTScribe52
    Dan
    2018 SR5
    Could just be marketing speak. If you do a search for SR5 on the Amazon listing you will see reviews from multiple people who installed it on them.
  7. Jul 6, 2023 at 12:34 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    It's because of the air dam. The TRD skid won't fit with the air dam on. As long as you take it off it will bolt up fine.
    TRD stands for Toyota research and development. Good for all trims.:thumbsup:
    LeakyAC likes this.
  8. Jul 6, 2023 at 3:27 PM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Just repaint the TRD letters on the TRD skid plate.
  9. Jul 6, 2023 at 3:33 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Removing the air dam will affect fuel economy slightly. It's a trade off....either it looks better to oneself, or just accept a 1 mpg hit in fuel mileage. With the air dam removed I noticed more wind noise at highway speeds to.
  10. Jul 6, 2023 at 3:41 PM
    Glenny
    Glenny Well-Known Member
    Glenn
    penns valley PA.
    2023 LR trail edition
    none I still have a warranty ;-)
    look up skid plate for 2023 trail it’s just black
  11. Jul 6, 2023 at 3:52 PM
    33yrsoftoys
    joel
    mid Michigan
    You're right it is a tradeoff. The TRD skid doesn't just look better, it offers much more protection offroad. Approach angles are greatly improved too. That makes it a good trade, at least it does for me.
    zoo truck[QUOTED] likes this.
  12. Jul 7, 2023 at 5:45 AM
    HueyMech
    HueyMech Active Member
    Bill
    TX
    2023 Tacoma TRD Sport
    Put one on mine yesterday. Easy peasy. Got mine from BAM. Carefully pulled the letters off and painted. Reinstalled them with 3M tape. skid plate.jpg
  13. Jul 7, 2023 at 7:04 AM
    Reagan2791
    South Georgia
    The wind noise might be a concern for me. I’m almost all highway miles. It’s 36-37 miles to my work daily. I may just leave it as is for now.
  14. Jul 7, 2023 at 1:05 PM
    KorbenMyMan
    KorbenMyMan Active Member
    E Tex
    2018 Tacoma SR5
    Way too many to list
    Removed my air damn before getting bigger tires. I had no increase in wind noise and my mpg remained virtually the same, at least until I got the bigger rubber lol. I wouldn’t let those things worry you. If anything you could take it off when you have time, go for a drive and put it right back on if you find any issues.
  15. Jul 7, 2023 at 2:01 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I put one of the off brand knock off trd Plates on my 2020 sr5 4x4. Honestly it's looks fine and it's very thick strong metal. The only flaws I can complain about is a few of the edges could have been milled smoother and installing it was unnecessarily a pain because the bolt with spacers were pre-installed installed on the plate but two of the pairs were in the wrong position making it not line up. But someone on this forum knew that when I posted about it. After correcting that the thing bolts up perfectly. I find the hatch to access the oil filter very convenient compared to removing the thin metal pan they ship with the truck during in oil change.
