2057 VS 1157 bulbs ?
Discussion in 'Lighting' started by tinker2, Apr 21, 2012.
  1. Apr 21, 2012 at 6:33 PM
    tinker2
    tinker2 [OP] Well-Known Member
    East Of The Big River
    Does anyone know what the difference is between the two bulbs. I'm asking because I have a trailer that has one of each in the tail lights. Need to get new bulbs but don't know which is the correct bulb ?
    Thanks for any input.
  2. Apr 21, 2012 at 11:30 PM
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    Quick search I did indicated that they are compatible, but the 1157 is slightly brighter.
  3. Apr 21, 2012 at 11:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup...
    The 2357 is significantly brighter than the 1157 on the stop/turn... the parking light filament is identical.
    But here's the specs:
    1034 Low = 8.3w High = 23.0w
    1157 Low = 8.3w High = 26.8w
    2057 Low = 6.7w High = 26.8w
    2357 Low = 8.3w High = 28.2w
    But... the 2357 is only rated for 400 hours. The 1157 is 1200.
    The 1034 is only 200 hours.
  4. Apr 22, 2012 at 7:24 AM
    tinker2
    Thanks for the input guy's.
    It' appears the bulbs are compatible, the locking prongs are in the the same place on both bulbs.
    The 1157 is a brass body & a little brighter stop & turn light.
    The 2057 is a stainless steel body, longer life & not quite as bright.
    I believe I'll replace both with the 2057's.
    Thanks for the help.
  5. Apr 22, 2012 at 9:49 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Stick with 1157.
    The 2057 stop/turn is the same as 1157, but the running lights are 2 watts lower.
    Running lights are super important on a trailer... not too many things worse than rolling on the highway and having someone change lanes into your trailer because he couldn't see your running lights.
    Flatbeds are the worst for this and it's almost happened to be a few times!
  6. Apr 22, 2012 at 11:16 AM
    tinker2
    Ok, I had it backwards for the wattage designation. 1157's it is. :cheers:
    Thanks.
