209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Sep 7, 2018 at 2:50 PM
    #2241
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Slide thru to the mod day on sunday
    El Taco Diablo[OP] likes this.
  2. Sep 7, 2018 at 5:15 PM
    #2242
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    yeah, you can see angelo's dildo "diff" breather mod
  3. Sep 7, 2018 at 5:16 PM
    #2243
    roguegs
    Angelo
    V8 T4R
    LMAO I would never be caught dead with that thing strapped to any vehicle I own or drive
    CalTacoma09[QUOTED] likes this.
  4. Sep 7, 2018 at 7:02 PM
    #2244
    Papadave418
    Papadave418 Well-Known Member
    Dirty Harry lives next door
  5. Sep 7, 2018 at 7:04 PM
    #2245
    Papadave418
    How late will it go to? I’m in Livermore with my kids and might not make it till 2-3pm
  6. Sep 7, 2018 at 7:15 PM
    #2246
    Papadave418
  7. Sep 7, 2018 at 8:39 PM
    #2247
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Prepped and painted the sliders. Getting them welded on next week. Also I'll be switching out to the 883 springs and adding a 1/2" spacer up front. Hope everyone have a good weekend and good mod day. Unfortunately I'll be working or I would be there to lend a hand, 2x.
    foxrcing07 and roguegs like this.
  8. Sep 7, 2018 at 8:40 PM
    #2248
    roguegs
    Angelo
    V8 T4R
    My sliders need to hurry up and get done!
  9. Sep 7, 2018 at 8:51 PM
    #2249
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I guarantee, at least some of us, will still be here at 2 or 3... even if it's just cause we're sitting around bullshitting.
  10. Sep 7, 2018 at 8:51 PM
    #2250
    roguegs
    Angelo
    V8 T4R
    Can we start a running list of what people need to do on the mod day thread?
  11. Sep 7, 2018 at 8:53 PM
    #2251
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Whoa... 883s and a 1/2 spacer? A half inch spacer will give you 1 inch of lift on top of the lift from the 883s.
    That's a lot of lift.
    Taco-Rado Girl likes this.
  12. Sep 7, 2018 at 8:55 PM
    #2252
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Thats a good idea.
  13. Sep 7, 2018 at 9:02 PM
    #2253
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Welded together the base my Aux battery will sit on... and welded it to the fender well. (No, there will not be pictures of this because holy shit, my welds look like garbage... but it's solid and is going to hold)
    Finished re-making the battery tray and hold down.
    Now, need to paint the tray, base and area around the base, and start actually installing the second battery.
  14. Sep 7, 2018 at 9:05 PM
    #2254
    roguegs
    Angelo
    V8 T4R
    Are there more batteries there for me :)
  15. Sep 7, 2018 at 9:06 PM
    #2255
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No... I'm gunna text my guy and see whats up.
  16. Sep 7, 2018 at 9:46 PM
    #2256
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Talked to my guy, there aren't any yellow tops right now. He'll get them as soon as he can.
    Taco-Rado Girl and sd1uh8as like this.
  17. Sep 7, 2018 at 9:47 PM
    #2257
    roguegs
    Angelo
    V8 T4R
    Can he only get Optimas? What about some Odyssey?
  18. Sep 7, 2018 at 10:14 PM
    #2258
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    I thought about that as well. Here’s my thinking on this. 1/2” is supposedly only 3/4” of lift at the most? I still have 2” of rake in the back without the sliders on. I have to consider that when I add a winch it will be at least another 70lbs more and I still need to put on the Trans skid which is another 15?lbs if not more. I also consider that I have a V6 DC 4x4 which is the heaviest configuration for our gen.
    After all is said I want to try the 1/2” spacer anyways since I’m switching out the springs. 1/2” reguires you to replace the 3 top plate bolts with extended ones and to do that you have to remove the springs. So in the future if I don’t want to run 1/2” spacer or maybe go a little smaller it would be easier to remove or replace and leave the extended bolts in.
  19. Sep 7, 2018 at 11:07 PM
    #2259
    roguegs
    Angelo
    V8 T4R
    Anyone have experience with these AGM batteries? https://www.samsclub.com/sams/durac...sel:people-who-viewed-this-item-also-viewed:2
    Specifications
    • 20 amp hour rate:55
    • Battery electrolyte composition: Glass Mat
    • Battery purpose: Starting lighting instrumentation
    • BCI group size: 34/78
    • CA at 32 degrees F: 890
    • CCA at 0 degrees F: 775
    • Freight class: 65
    • Polarity:DT
    • Reserve capacity: 120
    • Terminal type:T040/T041
    • Volts: 12
    Versus Optima Yellowtop https://shop.advanceautoparts.com/p...gclsrc=aw.ds&dclid=CPnUn8Tbqt0CFb8ErQYdq-wPZg
    • BCI Group Size: 34
    • Cold Cranking Amperage: 750 A
    • Cranking Amperage: 870 A
    • Negative Terminal Location: Top Right
    • Positive Terminal Location: Top Left
    • Reserve Capacity: 120 min
    • Terminal Type: Top Mount
    • Voltage: 12 VDC
    Seems to be about the same specs with the Duracell being a little more on the CCA. Also found out that East Penn (Deka) is making these Duracell batts now.
  20. Sep 7, 2018 at 11:18 PM
    #2260
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    I have a yellow top in my Lexus. Couldn’t really tell you if it’s any better from real world use. However I have ran my car with just ACC for a good amount of time and it hasn’t fail to start yet. I did get a free replacement once through autozone but forgot the situation. It’s garage parked so it can’t be from heat? I think it was because I didn’t drive it for awhile or It was just faulty. Speaking of that it’s been almost a month since I drove it, better take it out for a drive. I might need to look into upgrading or getting another battery for a future winch setup.
