20k miles... What service should I be doing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoJersey, Jul 21, 2012.
  1. Jul 21, 2012 at 12:15 PM
    SoJersey
    SoJersey [OP] South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Just rolled 20k miles on my 2012. I've greased the driveline and changed the oil like normal.
    What else should I be doing (if anything) or what service should I be doing soon? Diff fluids? Tranny fluid? Air filter? Blah blah blah.
    Thanks.
    Ps If you know of a thread going over this, feel free to link it.
  2. Jul 21, 2012 at 2:34 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    guess no replies means i have nothing other then what i have been doing to do.
  3. Jul 21, 2012 at 2:36 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Your service manual has a specific list of all scheduled maintenance
  4. Jul 21, 2012 at 2:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd change the trans and rear end oil to synthetic, asap.
  5. Jul 21, 2012 at 2:45 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    ok, will do.
    what weight in the trans? and diff? limited slip additive in my oem locker rear? (i'll be using amsoil)
  6. Jul 21, 2012 at 2:45 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  7. Jul 21, 2012 at 2:57 PM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    every 5k i change the oil and rotate tires.
    -lube the zerks if you are an OR
    -check your ATF
    -test of change your spark plugs
    -coolant flush at 25k
    -check your alignment
    -check the color of your brake fluid
  8. Jul 21, 2012 at 3:01 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Manual trans? No limited slip? No additive. [​IMG] For both trans and rear end.
  9. Jul 21, 2012 at 3:19 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  10. Jul 21, 2012 at 3:26 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    I have a v6 auto trans trd o/r
  11. Jul 21, 2012 at 3:28 PM
    OffroadToy
    what about the 5,000 mile/6 month oil change interval to be covered under warrenty? Did they change that? :confused:
  12. Jul 21, 2012 at 3:34 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    He's asking about beyond just the oil change.
  13. Jul 21, 2012 at 3:44 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Change out the rear end lube; you'll be glad you did.
  14. Jul 21, 2012 at 4:01 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    I do my own shit to our vehicles.
    As for the rear fluids, how many quarts of 75-90 should I get to do the front an rear ones? And do I need any additive for either? Locker in rear.
  15. Jul 21, 2012 at 4:21 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You can find fluid amounts in your manual. IIRC its like 3 and 2 or something. No, no additive.
  16. Jul 22, 2012 at 9:19 AM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    no additive front or rear?
  17. Jul 22, 2012 at 9:30 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    So I can help you understand...
    Since you have an open front there is nothing there but gears, all you need is regular fluid.
    With your locker in the rear you have a locking collar, a shift fork, and then essentially regular gears. The locker requires nothing special, just needs normal lubrication.
    If you have a mechanical limited slip you would need an additive as you would have clutches or discs with friction material that need special additives to work properly.
    With an auto LSD I believe they require no additives as you have no clutch packs the work is all done by braking and a computer. How that works similar to the tire that has least traction will spin on an open differential. The computer senses one wheel spinning at a high RPM and automatically applies the brakes to just that wheel. With the way a differential works this means the other tire will now spin as it becomes the tire easiest to spin. Basically anyway...
    So no, you need no additives front or rear. A lot of fancier gear oils include additives in the gear oil itself btw, but this won't harm a normal differential.
