.223 & 5.56mm
Discussion in 'Guns & Hunting' started by YayAreaTaco0311, Sep 14, 2011.
  1. Sep 14, 2011 at 4:14 PM
    YayAreaTaco0311
    YayAreaTaco0311 [OP] Motivator
    California
    '09 TRD 4x4 O/R Supercharged
    OEM TRD supercharger, OEM wheels painted black by me, yellow sidemarkers, arb bumper, LED interiors, roll-n-lock, 5% rear windows, mudflaps removed, protector alarm, mobile trace, blacked out front Toyota emblem, debadged, & tree air freshener.
    Hey all,
    I just brought a DTI-15. On the side it says 5.56. My question is, can it also fire .223?
    I've heard different answers. Some say you can fire both, others say it will explode in the barrel.
    thanks
  2. Sep 14, 2011 at 4:16 PM
    11BSSG
    11BSSG Well-Known Member
    33°28'18"N /-86°48'2"W
    07 4X4 A/C 6 Spd
    Front-Billy 5100'2 @ 2.5, Rear- Wheelers 1.5" AAL w/ Billy 5100's, 17" XD Addict's, 285/70-17 Nitto TerraGrappler AT's, 20% Tint, UWS Low Pro Toolbox, N-Fab Nerf Steps, K&N, Black Head Lights, Hard Wired GPS, XM Onyx, Hardwired Radar Detector, Ultraguage, Thule Mtn Bike Lock, Sleeved Fog Light Housing, Black Emblems, Satoshi/Color Matched grille, Misc. Security Upgrades.
    Yes, you can go with 223 and 5.56 if it is marked 5.56. If I had more time, I could get into all the details and recommend hours or reading on the subject, but in short, it is fine. (Get ready for an age old debate to start if some of the other gun nuts chime in.)
    FYI, I have built multiple AR's and have never had a problem shooting 223 out of a 5.56 weapon.
  3. Sep 14, 2011 at 4:16 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
    Wouldn't that be like shooting a 20 gauge shell in a 12 gauge shotgun?
    Edit: nevermind..
  4. Sep 14, 2011 at 4:17 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    you can safely shoot .223 in a rifle chambered 5.56 the reverse is not true. but .223 may not be as accurate in a 5.56 as it would be in a .223. hope that helps
  5. Sep 14, 2011 at 10:50 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    ahhhhhhhh its the same:anonymous::D
  6. Sep 14, 2011 at 10:56 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    The .223 Remington is a sporting cartridge with the same external dimensions as the 5.56x45mm NATO military cartridge. (someone correct me if i am wrong) It is loaded with a .224" diameter, jacketed bullet, with weights ranging from 40 up to 90 grains, though the most common loadings by far are 55 grains.
    The primary difference between .223 Remington and 5.56 x 45 mm is that .223 is loaded to lower pressures and velocities compared to 5.56 mm. .223 Remington ammunition can be safely fired in a 5.56 mm chambered gun, but the reverse can be an unsafe combination. The additional pressure created by 5.56 mm ammo will frequently cause over-pressure problems such as difficult extraction, flowing brass, or popped primers, but in extreme cases, could damage or destroy the rifle.
  7. Sep 15, 2011 at 2:33 AM
    11BSSG
    07 4X4 A/C 6 Spd
    What he said. There are a few more details, but I'd say you hit the nail on the head.
    Below: My latest build, chambered in 5.56, but mostly shot 223 out of it. Whatever ammo I can find the best price on. Mostly doing close quarter combat drills with it, so I'm not worried about 30+ meter accuracy.
  8. Sep 15, 2011 at 2:51 AM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    PreRunner SR5 TRD Sport
    Bull bar, wet suit seat covers, Accessory meter repair, Fog Lights with stick on, console lock.
    http://www.winchester.com/lawenforcement/n...aspx?storyid=11
    straight from the site;
    223 Rem VS 5.56mm
    There are a lot of questions about these two cartridges. Many people think they are identical - merely different designations for commercial and military. The truth is that, although somewhat similar, they are not the same and you should know the differences before buying either cartridge.
    * The cartridge casings for both calibers have basically the same length and exterior dimensions.
    * The 5.56 round, loaded to Military Specification, typically has higher velocity and chamber pressure than the .223 Rem.
    * The 5.56 cartridge case may have thicker walls, and a thicker head, for extra strength. This better contains the higher chamber pressure. However, a thicker case reduces powder capacity, which is of concern to the reloader.
    * The 5.56mm and .223 Rem chambers are nearly identical. The difference is in the "Leade". Leade is defined as the portion of the barrel directly in front of the chamber where the rifling has been conically removed to allow room for the seated bullet. It is also more commonly known as the throat. Leade in a .223 Rem chamber is usually .085". In a 5.56mm chamber the leade is typically .162", or almost twice as much as in the 223 Rem chamber.
    * You can fire .223 Rem cartridges in 5.56mm chambers with this longer leade, but you will generally have a slight loss in accuracy and velocity over firing the .223 round in the chamber with the shorter leade it was designed for.
    * Problems may occur when firing the higher-pressure 5.56mm cartridge in a .223 chamber with its much shorter leade. It is generally known that shortening the leade can dramatically increase chamber pressure. In some cases, this higher pressure could result in primer pocket gas leaks, blown cartridge case heads and gun functioning issues.
    * The 5.56mm military cartridge fired in a .223 Rem chamber is considered by SAAMI (Small Arm and Ammunition Manufacturers Institute) to be an unsafe ammunition combination.
  9. Sep 15, 2011 at 2:58 AM
    LGE RAW
    Rob
    Dothan
    There is also the Wylde chamber that melds the two:
    A Wylde chamber, which is a mix between .223 and 5.56. The 5.56x45 NATO is NOT exactly the same as a .223 Rem. The 5.56 spec allows for slightly longer chambers for higher pressures. The .223 has a tighter chamber around the neck and is shorter which allows for a bit better accuracy. You can shoot .223 ammo in a 5.56 chamber, but it is DANGEROUS to shoot 5.56 (surplus for instance) ammo in a .223 chamber. What the Wylde chamber does is allow for 5.56 ammo with slightly tighter chamber for better accuracy. So you can shoot both 5.56 and .223 safely with good accuracy.
  10. Sep 15, 2011 at 4:28 AM
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - 3" OME Lift, UCWMS
    UCWMS; OME 3" lift/OME 885 springs; OME 90000/60091 shocks; Diff drop Spacers; Light Racing UCAs
    Yes you can shoot .223 out of a 5.56 chambered AR, but not vise-versa. If your weapon was marked with .223, then it is not recommended that you shoot 5.56 due to higher cylinder pressures that could cause potential problems.
  11. Sep 15, 2011 at 10:17 AM
    YayAreaTaco0311
    California
    Thanks all, that helps a lot!
    No wonder .223 ammo is always cheaper than 5.56 at Wallyworld. They also got this brand named Wolf, which I was told to stay away from...
  12. Sep 15, 2011 at 12:15 PM
    11BSSG
    07 4X4 A/C 6 Spd
    Wolf=no good
  13. Sep 15, 2011 at 1:00 PM
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    ^ this - dirty as fuck, cheap casings that can shave off when cycling, and overall garbage rounds...
  14. Sep 15, 2011 at 6:42 PM
    meeestirg
    meeestirg Well-Known Member
    D15, CA
    you CAN use .223 in a 5.56 chambered barrel.
    you CANNOT use 5.56 in a .223 chambered barrel.
    i herd the reason being that 5.56 was created for the military. and .223 was for civilians. if the military was to ever need to loot ammo from a city, town, etc... after a natural disaster or during the zombot apocalypse, they would not need to sort out .223 and 5.56, they can just use either or. i guess 5.56 only being for the military didn't stick and we are allowed both.
  15. Sep 15, 2011 at 6:51 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    lets see how many more times we can all say the same thing
    :p
    Ive never shot wolf but I have used steel cased ammo in two different AR's with no problems. Ive used brown bear, monarch, and Hornady with zero issues. When running steel case ammo I run the gun pretty wet, idk if that helps but I know it wont hurt
  16. Sep 15, 2011 at 8:01 PM
    11BSSG
    07 4X4 A/C 6 Spd
    :deadhorse::fenforcer:
    I had to......
  17. Sep 16, 2011 at 6:18 AM
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    Hornady is manufactured/loaded right here in The Heartland in Grand Island, Nebraska - just down I-80 from me! Been by their plant a few times over the years. They make some high quality ammo.
  18. Sep 16, 2011 at 6:37 AM
    LGE RAW
    Rob
    Dothan
    The steel cased ammo has a coating on it that will gum up your AR. It is a PITA to clean out and will cause jams and misfires after a few mags. You can shoot it if you like, but you will have to clean the crap out of your AR immediately or you'll regret it!
  19. Sep 16, 2011 at 7:00 AM
    GP100
    GP100 Well-Known Member
    Paul
    RI
    '06 TRD Offroad
    To the OP, I'm not familiar with your particular gun. You say the gun is marked 5.56 on the side. The side of what? The lower receiver or the barrel? The markings on the barrel is what I'd go with. Lower receivers can handle multiple calibers.
    In case nobody has explained the difference between 5.56 and .223... :)
  20. Sep 16, 2011 at 7:02 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    No steel casings of any size by any manufacturer at any time in any American made gun I own. It's just not worth the trouble. Brass only.
    You can, however, run anything that you can get to cycle in an AK 47 without it jamming or stopping until you run out of ammo.
