235/85r16
Discussion in 'Wheels & Tires' started by DanGer, Oct 22, 2009.
  1. Oct 22, 2009 at 2:13 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    When I finally need new tires, I am considering 235/85R16s. I would rather have a little more ground clearance than a wider tire. My taco is my daily driver, but I wheel on weekends and when I go hunting.
    These are the two sizes I am contemplating
    from the online tire size calculator
    I originally ruled this out because the Bridgestone Dueller Revos in this size were load range E and 52 pounds!
    However the Revo II in this saize are also load range E but are only 42 pounds. This is still a little heavier than I would like but it is much more manageable.
    Now I fully recognize my lack of knowledge and experience with both offroading and tire selection so this is where I hope you guys rip me a new one if I deserve it.
  2. Oct 22, 2009 at 2:33 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Is this on stock rims?
  3. Oct 22, 2009 at 2:34 PM
    98tacoma27
    Ben
    Beech Creek
  4. Oct 22, 2009 at 2:34 PM
    DanGer
    Most likely. I may upgrade but I am not sure yet
  5. Oct 22, 2009 at 2:35 PM
    DanGer
    Lol I realized I grabbed the wrong link and edited at the same time
  6. Oct 22, 2009 at 2:45 PM
    98tacoma27
    Ben
    Beech Creek
    I am drawing a blank on the stock rim width. You have the 16 in. steelies?
  7. Oct 22, 2009 at 2:46 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I am thinking about getting the same size. skinny tires (pizza cutters) roll good on the road are awesome in snow because they cut down and give you good traction, they are good on rocks and even clay but lousy in sand (too narrow). The way i think of it is that the military has always used tall skinny tires on unstapable vehicles (ex. old jeeps, field vehicles, etc.) i have a reg cab 4x4 manual 2.7l and am also afraid this size will kill the power and mpg
  8. Oct 22, 2009 at 2:47 PM
    DanGer
    Yes I believe they are 7" but they may be 8"
  9. Oct 22, 2009 at 2:47 PM
    Yoytoda
    Roland
    completely stock
    stock steelies 16x7
  10. Oct 22, 2009 at 2:47 PM
    DanGer
  11. Oct 22, 2009 at 2:48 PM
    DanGer
    Yup he is correct^^^^^
  12. Oct 22, 2009 at 2:51 PM
    Yoytoda
    Roland
    completely stock
    BTW i ran 235/85-16 on a 2500hd and 2500 suburban and lived on a farm that was greasy clay any time it rained. The skinny tires cut through the muck down to good ground, however, in bottomless pit type mud they suck. Might be a good balance on a Tacoma that wheighs 3000lbs not a 3/4t chevy loaded with lumber or firewood
  13. Oct 22, 2009 at 2:54 PM
    98tacoma27
    Ben
    Beech Creek
    Well, then I say DO WORK SON. They only issue you may have is a little loss in traction. If you are concerned about power loss, I ran 31 10.5 15's on my 98 2.7L. They weighed 44 pounds.
  14. Oct 22, 2009 at 4:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Dude thats a narrow tire...I'd have to see it on a 2nd Gen. I wonder how they'd do in sand lol
  15. Oct 22, 2009 at 4:09 PM
    DanGer
    Probably not well, but most of my offroading is on mountain trails. The only time I ever went on sand was at the beach with my stock tires aired up to 30-something and I did fine haha.
  16. Oct 22, 2009 at 4:11 PM
    ColtsTRD
    Scott
    AZ
    Hmmm, post pics if ya get em :cool:
  17. Oct 22, 2009 at 4:15 PM
    TacoSter
    TacoSter Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
    i went with 265/70/17 ---- 31.6" diameter and it corrected our speedometer f up that toyota created. it runs dead nuts accurate now.
    Toyota claims plus or minus 10% is allowable torerance
    best part... the speedo is perfect.. the odometer runs less.. about 30 miles for every 300
  18. Oct 22, 2009 at 4:16 PM
    DanGer
    I will but it may be a while. I can't afford them until these bastards wear out. They are at 30K
  19. Feb 27, 2010 at 1:28 PM
    rick_s
    rick_s New Member
    Virginia
    '10 4x4 4cyl SR5
    Has anyone found any pics of these tires on a 2nd gen? I've been searching here and on a few other forums but haven't seen anything yet.
  20. Feb 27, 2010 at 7:09 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    My guess is plus only. Otherwise they might have some liability in a speeding case (speedo indicated 70 but he was really travelling 77). If they error on the plus side, you'd indicate faster than you're really going.
    That and I've never heard of anyone complaining that their speedo indicated too slow.
